Old 09-30-2009, 11:53 AM   #301
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
Toastie,
What will be your final floor covering of choice? I'm still going back and forth between Cork vs. marmoleum.
Jaime
1956Safari is offline   Reply With Quote
Old 10-01-2009, 05:46 PM   #302
toastie's Avatar
1955 22' Safari
Great Lake State , .
Originally Posted by 1956Safari View Post
Toastie,
Jaime
Jaime
The "boss" (wife) makes all of those decisions. At first it was marmoleum but decided to go with a floating wood floor. The floor will be a very light blonde color, cabinets will be antique black over red milk paint and the aluminum will be highly polished.
Toastie
toastie is offline   Reply With Quote
Old 10-03-2009, 10:37 AM   #303
1966 22' Safari
Hinsdale , New Hampshire
I'm looking at the patch and wonder how you make the compound curves? The new panel looks perfect.
drowe42 is offline   Reply With Quote
Old 10-03-2009, 10:39 PM   #304
flyrc's Avatar
1960 24' Tradewind
1960 24' Tradewind
Yakima , Washington
How many days did it take to remove all the paint layers? I've spent most of three days stripping paint off the interior of my 56 F/C and only reached the 6' mark. I sure wish I had a soda blaster.
Wally H.
Parts needed
1962 Street side corner tub
range or parts
Dometic 50 or parts
flyrc is offline   Reply With Quote
Old 10-04-2009, 05:27 AM   #305
toastie's Avatar
1955 22' Safari
I removed 3 coats of paint and zolatone was one of them The window trim and lower panels will be replace with new, TIME and the cost of the paint remover lead to that decision, plus I was tired of looking and smelling the stripper. I tryed all strippers, but in the end, Citristrip was the best and it was safer.Took 3 to 4 application of the stripper plus a plastic putty knife. also I used steel wool #4 with a plastic backing handle. This was done in the winter, time wise about 2 weeks.
Old 10-04-2009, 06:23 AM   #306
toastie's Avatar
1955 22' Safari
Took the old pattern and flatten it out, traced it on to new, then cut slits as shown in the picture. Then slowly worked it in, marked it, then slowly started trimming, keep repeating for the perfect fit. The soft aluminum will conform to the trailer. Notice in the picture how thin I made my cuts with the electric shears
ID:	88162   Click image for larger version
Old 10-18-2009, 04:26 PM   #307
toastie's Avatar
1955 22' Safari
Starting to run wires and a BIG learning curve is about to start. Mid to late 1950's Airstreams came with just a basic 110v system no 12 volts. The white wire 14 gauge will be used for the 110V and the yellow wire 12 gauge will be used for the 12 volts system. Let the fun begin.................toastie
Old 10-18-2009, 05:39 PM   #308
Zeppelinium's Avatar
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake , Colorado
Originally Posted by toastie View Post
...The white wire 14 gauge will be used for the 110V and the yellow wire 12 gauge will be used for the 12 volts system. ...
Toastie, take some care with wire colors. In the Airstreams, white was/is ground for the 12V system, and yellow, brown and blue (maybe others--the 70s trailers had 4 12V circuits) were +12V. I recommend running grounds to most loads (lights, water pump, fans, but you can get by using the shell as ground), but definitely run a heavy ground wire between the converter, batteries, and the ground connection at the 7-pin umbilical connector (#10 is sufficient).
House code for 110V is white is neutral (not ground, but should be at ground potential) and black is hot. All my 70s Airstreams have the 110V in Romex (three wires--white, black, and bare copper, which is ground). Since the white and black are inside the Romex insulation, it's hard to confuse them with the 12V wires.
Just be careful not to screw the next guy up by using color codes that make sense to you, but possibly not to others.
Zep
Zep@Charmedquark.net
Old 10-19-2009, 07:33 AM   #309
flyrc's Avatar
1960 24' Tradewind
1960 24' Tradewind
Yakima , Washington
Wire Guage and color codes
[I knew before I looked at the photo that you wee talking about the outer cover colors of the Romex wire you are going to use. When you refer to "yellow" you mean the color on the 12 gauge Romex wire. Its the new color for house wire. It's a quick visual check for inspectors Have fun snaking the wires, Wally H
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 10-19-2009, 09:24 AM   #310
1973 23' Safari
1977 23' Safari
darn, should I be paying closer attention?
Zep
Old 10-19-2009, 09:55 AM   #311
pbearsailor's Avatar
Port Hadlock , Washington
I'll be getting to this step on mine within the next couple of months as well.
Do you guys think it's worth trying to use a multi stranded wire for the AC system instead of solid core? Don't know how hard it would be to source other than using marine grade cable, but it's really pricey.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 10-19-2009, 11:35 AM   #312
1973 23' Safari
1977 23' Safari
Originally Posted by pbearsailor View Post
...Do you guys think it's worth trying to use a multi stranded wire for the AC system instead of solid core? ...
No. I haven't seen a failure in the original solid wire in the 115V systems in any of the four 70s models I've taken apart.
Zep
Old 10-19-2009, 05:03 PM   #313
toastie's Avatar
1955 22' Safari
Zep
Zeb
All yellow 12 gauge romex wire will be going into a 12 volt fuse box and I will be following the diagram shown in picture. My question is how does the break away switch for the brakes and the 7-pin umbilical connector tie into my wiring diagram. Also in the diagram I noticed the green wire going to ground and I do understand that, but what is black wire coming from the battery, does that get grounded also to the trailer.
Toastie
Old 10-19-2009, 06:53 PM   #314
Baltimore , Maryland
I see in the earlier image you bought the 12gauge wire already... You really do not need all that. Romex is actually three wires. A black, a white, and a bare copper. For 12 volt you only need one of the wires to carry the charge. The body is the ground or negative. I find it more reliable for you have two wires one to carry the charge and one for the ground. Boats are wired this way. It keeps the ground wire connection from becoming corroded as commonly occurs on cars and RV's. A spool of white and a spool of black 12 gauge wire would get you the same results. You do need Romex however for the 110 volt lines, using the ground as a modern system has. Probably should have said something earlier. The 12 gauge romex use to be white just like the 14 gauge. They changed the sheathing color in the past few years to make it easier for building inspectors to know what was used.
Old 10-20-2009, 05:23 AM   #315
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
Cape Coral , Florida
I'd use the 12 gauge yellow Romex for the 110 volt system. You need it anyway for the AC unit and probably the microwave. All the other circuits are "might-as-wells" since you have the wire. I've never seen solid core used on the 12 volt system. Generally 12 or 14 gauge multi-strand is used. For the same gauge multi-strand has more amp carrying capacity and is less susceptable to stress breaks.
My electrician friends strongly agreed, like Frank above, that since I had it all opened up I should home-run the ground as well as the hot. It makes sense and should reduce the chances for gremlins down the road, or on the road, as the case may be.
dieseleagle is offline   Reply With Quote
Old 10-20-2009, 09:44 AM   #316
1973 23' Safari
1977 23' Safari
Zep
... My question is how does the break away switch for the brakes and the 7-pin umbilical connector tie into my wiring diagram. Also in the diagram I noticed the green wire going to ground and I do understand that, but what is black wire coming from the battery, does that get grounded also to the trailer.
Break away--you need to tie the break away switch between a line that's always (+12) hot and the brake circuit. The only circuit that's always hot and is available right at the umbilical connector is the trailer charge line.
You could ground the (-) battery terminal to the shell separately, but it's not required. If you tie your converter, battery, and terminal block (-) together with 8 guage, one ground is enough. There may be reasons of redundancy or low ohmic reliability to have more than one ground. Other inputs on this welcome.
Some diagrams show a fuse in the (-) battery lead. I've pondered this and have actually encountered situations where I've disconnected the (+) battery lead at the terminal block and suddenly realized I've got a very dangerous wire in my hand. A (-) lead fuse would resolve this. But that's the only time I can think that a (-) fuse is helpful. This isn't as important for the converter (-) output, since converters today generally have auto-shutdown and they don't have the energy wallop that a fully charged battery can have.
Zep
Old 10-20-2009, 09:58 AM   #317
toastie's Avatar
1955 22' Safari
Frank and dieseleagle
Thanks very much, will go with the yellow 12 gauge romex for the 110 volt and will buy a spool of black and a spool of white wire for the 12 volt. What gauge would be the best for the 12 volt 12 or 14.....
Thanks again
Old 10-20-2009, 10:24 AM   #318
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
Since 12 gauge is preferable for things like the water pump I just went ahead and ran 12 gauge through-out. It's overkill for things like lights, but it all came off the same spools.
Old 10-20-2009, 01:23 PM   #319
12 gauge is good, but 10 gauge can also be used. The 12v does not travel too well through thin wires. My original 12volt wire is stranded orange 12gauge. My new is stranded 12gauge white for positive and black for negative. I also ground to the shell and to the terminal block. I see grounding as a good redundancy....
Old 10-20-2009, 05:11 PM   #320
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
I always get RV wiring mixed up. I thought it was black for positive and white for ground. Well, I just went to red for positive and green for ground. You're right about 12 gauge or better. There was a demonstration on TV last weekend. 12 volt right off the battery through 12 guage and it looked like a toaster oven within seconds.
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement spitfyr Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
