Old 10-25-2008, 06:49 AM   #201
toastie's Avatar
1955 22' Safari
Great Lake State , .
Originally Posted by Eliminator46 View Post
Looking great Toastie. I had considered pulling off the top, but still a little gunshy. Hoping to accomplish mine without pulling the shell off. Keep it up.
Redesigning the front gray water tank around this drain, will not transfer to back gray tank with pump as stated in previous post, will use gravity to empty tank.
eBay Motors: SCANDVIK 1" BARB HOSE DRAIN KIT - BOAT & RV SINKS (item 310090792300 end time Nov-08-08 08:00:04 PST)
toastie is offline   Reply With Quote
Old 10-25-2008, 01:15 PM   #202
toastie's Avatar
1955 22' Safari
Getting ready to permanently install tanks and floor. Did some touch up welding and painting and also covered the edges of the plywood with trempro 635...................
ID:	70203   Click image for larger version
ID:	70205   Click image for larger version
Old 10-26-2008, 05:48 PM   #203
toastie's Avatar
1955 22' Safari
Had a little hale storm today here in Michigan.................toastie
Old 10-26-2008, 06:48 PM   #204
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
HAIL - very lucky it was small.....
We had one this past spring that if it had passed over the house it would have done real damage to the AS - golfball size. Instead it was 1/2 mile down the road..... Whew.
Great progress, let me know when I can bring the Caravel up for a referb.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 10-26-2008, 08:31 PM   #205
sutter creek , California
Hey Toastie...Just wondering, do you sleep? Do you eat? Do you have a job you go to?!!!!!!!!!! Your doing a great job, I've been following your progress. I can't wait to see what you do for the interior! We hopefully will be doing a similiar, not-so-detailed retro to a 1959 24' tradewind. I have gota lot of great ideas from you, thanks. Keep them coming! By the way, what do you do professionally? Is it some kind of fabrication?
Thanks, Jewelcofsc
jewelcofsc is offline   Reply With Quote
Old 10-27-2008, 11:34 AM   #206
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Looking good Toastie,Getting the tanks and axel all set really seems to take some time,I like your tank hangers. Do the tanks move side to side enough to drop the tanks down,it looks like you welded the rerod in place? My project has come to a standstill for a while,I'm a heating guy and all of my coustomers have been starting there furnaces up the last couple of weeks,so not much a.s. time.How did you decide how big of tanks to go with?I've been reviewing the tank options,trying to keep as much clearance as possibleunder the tanks.Being you from the north also our days working outside are are getting fewer,I was hoping to get my floor back on before the snow hits but we will see,we had some snow yesterday.
It's not worth doing if you're not having fun.
https://tinman54.blogspot.com/
https://www.airforums.com/forums/f228...tml#post616014
tinman54 is online now   Reply With Quote
Old 10-28-2008, 04:32 PM   #207
toastie's Avatar
1955 22' Safari
Thanks tinman54
Yes, the tanks drop right in and rest on the angle iron. I took steel washer welded to the rod ends, not to the frame, the rods can't move, but still can rotate, then welded the angle iron to the rods. To hold the tanks down, I will use 4 small bolts one at each corner, will make sure that the drilled holes are large enough for the bolt to freely drop in, hand tighten only, double nut, I may also wedge the tanks down. So, to remove a tank, I would have to cut the rods, and pull rods out since the rods are not welded to the frame. I original was going to use brackets to fasten the angle iron to the rods, but when torque is applied would twist the angle iron putting stress on the tanks. The main goal here is not to stress the tanks at all, if I can achieve that, the tanks should out live me.
Toastie
Old 10-28-2008, 04:43 PM   #208
Baltimore , Maryland
This thread is like a fine cigar... I just sit back and enjoy, take it in and say very little. Not often I enjoy a good cigar like this. Thank you.
Old 10-28-2008, 06:17 PM   #209
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Thanks for the tank info,I agree with overlander, I really enjoy reading a good thread and pictures to go with just makes it all that much better.
Old 10-30-2008, 06:03 PM   #210
toastie's Avatar
1955 22' Safari
Permanently installed back 2 tanks, here are a few pictures, used plently of trempro 635...............toastie
ID:	70558   Click image for larger version
ID:	70560   Click image for larger version
Old 10-31-2008, 05:07 AM   #211
toastie's Avatar
1955 22' Safari
Thanks clancy
We rarely get hail here in October, nothing to compare what you went through this summer, hope everything is ok.
Toastie
Old 10-31-2008, 06:26 AM   #212
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Originally Posted by toastie View Post
Permanently installed back 2 tanks, here are a few pictures, used plenty of trempro 635...............toastie
Toastie,
The picture in the upper left looks as though you screwed through the flange of the tank... Is that true?
I like the idea of "bedding" the tank flange in tempro. In my set-up I was concerned about the tank shifting, but the tempro would greatly prevent that.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
https://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 10-31-2008, 06:41 AM   #213
toastie's Avatar
1955 22' Safari
Originally Posted by byamcaravanner View Post
Toastie,
Steve
Not screwed, I used 4 small bolts, one at each corner, I made sure that the drilled holes are large enough for the bolts to freely drop in, hand tighten only. I original was going to use brackets to fasten the angle iron to the rods, but when torque is applied would twist the angle iron putting stress on the tanks. The main goal here is not to stress the tanks at all, if I can achieve that, the tanks should out live me.
I really like your refrigerator
Toastie
Old 10-31-2008, 03:17 PM   #214
1967 28' Ambassador
1970 29' Ambassador
...I really like your refrigerator
toastie,
I looked back a little to see that your tanks appear to be built differently than mine... thus the reason for my "bolt" question. the flanges on may tanks are 3" deep and are part of the contents holding portion of the tank. Drilling a hole as you have would have meant I would need to seal the tank where the bolt exited the bottom of the flange. I see now that your flanges are formed by extending the top sheet of the tank thus they can be drilled without penetrating the tank.
Regarding my fridge... I am very happy with the NovaKool. It adds significant functionality with a level of reliability and simplicity not found in the Ammonia charged units. I am also happy that even though I purchased it for our Ambassador, it will fit very nicely under the existing counter in our Globetrotter.
I've immensely enjoyed your posts... thank you.
Steve & the crew
Old 11-01-2008, 06:09 AM   #215
toastie's Avatar
1955 22' Safari
Thanks, Jewelcofsc
Thanks, well, I just woke up, need to lose a few pounds, and I work for one of the big 2 auto companies advance engineering powertrain groups in the Detroit area. I was going to say the big 3 but it looks like Chrysler is going down. The wife is in charge of the interior design and it looks like today we are going retro, we both design as we go and we are constantly changing things, nothing on paper at all.
Toastie
Old 11-01-2008, 06:23 AM   #216
toastie's Avatar
1955 22' Safari
toastie,
After doing some reading about the NovaKool I would like to go with one untill I saw the price......wow......will be looking for a deal.
Old 11-01-2008, 08:14 AM   #217
toastie's Avatar
1955 22' Safari
Applied silicon to the rubber bushing groove and around the edge.
ID:	70619   Click image for larger version
Old 11-09-2008, 12:39 PM   #218
toastie's Avatar
1955 22' Safari
Floor, 1 black and 2 gray tanks are in. Will probably wait for spring to install the belly pan/floor permanently, wheel wells are permanently attached to side walls. Started work on the electrical.
ID:	71128   Click image for larger version
ID:	71130   Click image for larger version
Old 11-09-2008, 02:43 PM   #219
toastie's Avatar
1955 22' Safari
a BIG learning curve is about to start
Went to Lowes today and bought my GE electrical box and circuit breakers.
1) 125 amps TL412C main lug box
1) 15 amp GFCI
1) 20 amp GFCI
1) 15 amp breaker
1) 20 amp breaker
1) 10' of #8 wire that I will run from Marinco 30A 125V to Main 30 amp breaker.
This will be a BIG learning curve for me. Will need to come up with a wiring diagram on paper so I can balance out the question marks below. Then I will go to the 12v system.
Wire 5 will be for the main
Wire 4 to the 20 amp will be only for air conditioner
Wire 3 to the 15 amp will be Intellipower and ?????
Wire 2 to 15 amp GFCI will be kitchen, exterior and ?????
Wire 1 to 20 amp GFCI will be bath, refrigerator, exterior and ?????
ID:	71133   Click image for larger version
Old 11-09-2008, 03:14 PM   #220
Remember, Safety Third
Jim & Susan's Avatar
Catfish Corners , Georgia
125 amps? Wow! Seriously, tho, looks like you're headed down the right path. One thing I did was to add a seperate dedicated 15 amp breaker & circuit just for the microwave. Something to think about if you are going to install one those.
Solve for X, Or is it Y?
www.nesa.org
Air No. 6427
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement spitfyr Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
