Old 06-21-2008, 05:21 AM   #113
toastie
toastie's Avatar
Profile:  1965 17' Caravel
1955 22' Safari
, , Michigan
A very lucky find
Found and a complete front window, frame and all, what a lucky find.
ID:	62635  Click image for larger version
toastie is offline   Reply With Quote
Old 06-21-2008, 03:14 PM   #114
n2batr
Profile:  1958 26' Overlander
Lander , Wyoming
Steve, I have been on vacation for a week. Thanks for the info on the brackets you made. I think I visualize it better now. Nice work on the windows so far. I cleaned and polished mine this past winter. It is a multi-piece job , fairly tedious. Glad I'm done. I have 2 doors to eventually rebuild. When the time comes I would love to draw on your expertise. Ed
n2batr is offline   Reply With Quote
Old 06-22-2008, 07:33 AM   #115
toastie
toastie's Avatar
1955 22' Safari
, , Michigan
Putting the window back together. Instead of using a glue, I used ribbon sealer to seat the gasket. Ribbon sealer is used for auto glass replacement and can be bought at Auto Zone. I cut a small piece and hand rolled it to a longer piece, placed under the window frame, when I closed the frame and applied 3 tiny screws the sealer flatten out to make a perfect seal.
ID:	62667  Click image for larger version
ID:	62669  Click image for larger version
Old 06-22-2008, 03:35 PM   #116
toastie
toastie's Avatar
1955 22' Safari
, , Michigan
Completed front window today...........
ID:	62697  Click image for larger version
ID:	62699  Click image for larger version
Old 06-24-2008, 07:10 PM   #117
toastie
toastie's Avatar
1955 22' Safari
, , Michigan
Before I install the 3 side windows I need to prep around the window openings. First is to tackle the very long drip cap which I left attached to the trailer. I took out in my case 2 end screws, I will replace them with rivets when done. I bent the drip cap up just enough to get a compounding pad and steel wool pads, and went at it. Position the drip cap back into place then started with 0000 steel wool pads to clean around the drip cap and around the window openings. The one picture showing under the drip cap was polished.
Name:	what a mess.jpg
ID:	62824  Click image for larger version
ID:	62826  Click image for larger version
Name:	looking better.jpg
Old 06-29-2008, 04:03 PM   #118
toastie
toastie's Avatar
1955 22' Safari
, , Michigan
working on my windows
Set my new front window today, used about 3/4 tube of trempro 635, no leaks here. Also working on the side 3 windows and almost done, just 2 more windows to go. Also made a new rear door.
ID:	62989  Click image for larger version
Old 06-30-2008, 07:51 PM   #119
toastie
toastie's Avatar
1955 22' Safari
, , Michigan
2 more windows and 3 vents to go
just 2 more windows and 3 vents to go, then the floor
ID:	63035  Click image for larger version
Old 06-30-2008, 07:53 PM   #120
utee94
Profile:  1963 26' Overlander
Lookin' good, you really just do not mess around do you?
utee94 is online now   Reply With Quote
Old 06-30-2008, 07:58 PM   #121
toastie
toastie's Avatar
1955 22' Safari
, , Michigan
thanks Marcus, I'm 2 years away from being finished.............steve
Old 07-01-2008, 09:33 AM   #122
toastie
toastie's Avatar
1955 22' Safari
, , Michigan
Set the door brackets and back supporting brackets today and did a trial fit on the door, not bad, but I will wait until the floor is in, then will tweak the door for the proper fit.
Name:	supporting door bracket.jpg
ID:	63049  Click image for larger version
Name:	supporting door bracket1.jpg
ID:	63054  Click image for larger version
Old 07-18-2008, 02:34 PM   #123
toastie
toastie's Avatar
1955 22' Safari
, , Michigan
Finished setting the last window today, used plenty of Trempro 635 shown in below picture, cleaned the overflow with thinner. Just a few more hours and I will be 100% done with the windows.
ID:	63999  Click image for larger version
Old 07-18-2008, 05:55 PM   #124
muddy_hollow
muddy_hollow's Avatar
Profile:  1965 20' Globetrotter
1956 22' Caravanner
Mendon , Massachusetts
Wow
The windows look great. Are you buck riveting those back in or are you using Olympics?
I'm doing something similar to your project.... loads of time and patience.
So how many cuts have you gotten on your fingers?
65' Globetrotter 'The Otter'
56' Caravanner 'The Broomstick'
muddy_hollow is offline   Reply With Quote
Old 07-18-2008, 06:08 PM   #125
toastie
toastie's Avatar
1955 22' Safari
, , Michigan
For the windows I'm using olympic rivets with loads of trempro 635. I have gone thru about 5 tubes of the stuff so far attaching the running lights, door stops, door hinges, etc......Today I ran one of the wires to a wire brush down the finger nail about a 1/4 inch.
Old 07-27-2008, 06:07 PM   #126
toastie
toastie's Avatar
1955 22' Safari
, , Michigan
before and after pictures
Here are a few before and after pic's, starting to work on the plans for the interior.
ID:	64575  Click image for larger version
ID:	64577  Click image for larger version
