Old 06-12-2008, 09:26 PM   #99
Originally Posted by 62overlander View Post
I quit, anyone want a 1962 overlander? Half restored, half polished?
Ummmm... yeah?
Old 06-13-2008, 05:12 AM   #100
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Originally Posted by utee94 View Post
Ummmm... yeah?
Hey Marcus,
Don't get your hopes up... Frank "quits" almost daily LOL!
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 06-13-2008, 08:38 AM   #101
A 7th year newby
IndyAnne's Avatar
1968 24' Tradewind
Indianapolis , Indiana
Images: 8
Send a message via Yahoo to IndyAnne
Dang! Beautiful work! I love the door-in-the-door on those earlier models. Wonderful shine. Someday... maybe. I'll just be happy this summer to get the old white roof paint off and try to get a lot of the road grime off. Too much going on inside to take the time on the skin. You're an inspiration!
Anne
Indianapolis, IN
TAC IN-7
1968 Airstream Trade Wind
2005 Chevy K1500 crew, reg. bed, 4WD, gas
IndyAnne is offline   Reply With Quote
Old 06-13-2008, 06:25 PM   #102
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Originally Posted by toastie View Post
Thanks, had to do the inner door outer skin twice, the first time, I stood back and said Aerowood would not approve the rivet job, so I ripped it off, and try-ed it again, not perfect but I'm happy with it.
Oh, some people are so self-critical, you're killing me.... It looks GREAT. I only wish I had your talents. Keep up the great work - one day I'd like to see it in person at a rally. Again, WOW......
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 06-13-2008, 11:46 PM   #103
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
Some people do an outstanding job and then there are those who go above and beyond that. Those are the ones I love to look at but don't park anywhere near it so folks can't compare my work to the others. Sigh, you are building an incredible trailer. The finished product will be gorgeous.
Barry
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
safari57 is offline   Reply With Quote
Old 06-14-2008, 10:06 AM   #104
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
The door has been the most time consuming so far, but I'm almost done.
Wait until you get to the %^*!$#@ Hehr windows! They are a royal PITA!!!
In order to re-screen them or replace the gaskets they must be totally removed from the trailer. In order to remove them, you must also remove the drip caps...that's a lot of rivets! Going out to finish ours today...hopefully!
Shari
Old 06-14-2008, 04:31 PM   #105
toastie's Avatar
1955 22' Safari
Great Lake State , .
Shari
I know what you mean, I have done 2 so far, to me, its not work. Do you have a thread started, would like to follow................
toastie is offline   Reply With Quote
Old 06-14-2008, 05:11 PM   #106
InsideOut's Avatar
1956 22' Safari
Images: 108
Yes, http://www.airforums.com/forums/f91/...tml#post572776 Ours is one year newer...but the same trailer & projects!
I hope to post pics of the windows later this evening...we just got back from buying two pieces of glass - one window had a BB hole, the other was broken around the edges once we took it apart.
The part of the windows that I think is work is riveting them back on with the new gaskets...to keep the gasket in place & even is definitely work! That and getting rid of all the silicone the PO used in place of the trim at the glass.
Shari
Old 06-15-2008, 05:43 AM   #107
toastie's Avatar
1955 22' Safari
Originally Posted by n2batr View Post
Nice job on the lockset. It will look super on that door. If I'm looking at the brackets you added correctly looks like you have these screwed to the lock housing and ? soldered or welded to the aluminum sheet. If not how are they attached? I have these same locksets. My doors have wood brackets which were inserted to hold the housing in place . These did a marginal job and as the wood shrank/rotted the housings have loosenedsomewhat. As I will be rebuilding the doors I am following your fine progress with interest. Ed
Ed
First I used trempro 635 to set the bracket, let it set overnight, that will
give a temp. set plus keeps the water out. The brackets is what holds it to the door. The brackets are made out of aluminum and are bent to where when they set on the bracket and when the stainless screw are tighten forms a compression, the clamp load is created from the head of the fastener. The bend in the bracket is higher than the brackets to the door giving you that compression.
Steve
Old 06-15-2008, 08:39 AM   #108
toastie's Avatar
1955 22' Safari
Now that I'm 95% done with the door, my attention will be toward the window's.
What was Airstream engineer's thinking when the came up with the Hehr Standard
Backframe Gasket, to remove the whole window frame just to install a gasket.
Going to install gaskets, screen, polish the window frame, drip cap without removing
the window frames or drip cap.
ID:	62351   Click image for larger version
ID:	62353   Click image for larger version
Old 06-15-2008, 08:53 AM   #109
monocoque's Avatar
1975 29' Ambassador
San Antonio , Texas
Hey Steve, I've really been enjoying your recent progress. Keep up the great work. It's really an inspiration.
Todd
“Complications arose, ensued, were overcome...savvy?”
- Captain Jack Sparrow
monocoque is offline   Reply With Quote
Old 06-15-2008, 10:57 AM   #110
InsideOut's Avatar
1956 22' Safari
Images: 108
How? Especially the screens??? I can see the gasket...maybe (still have to drill out three sides of rivets), but the screens? How will you be able to crimp the screen over without getting a screen roller to the sides between windows numbers 1 & 2 and 2 & 3? We sure couldn't figure out a way to do it with much success ~
But then, our dripcap was covered in %#$@*! silicone so tit had to be removed anyway and with the panel replacement too...we were halfway to having the windows out ~
Shari
Old 06-16-2008, 07:19 PM   #111
toastie's Avatar
1955 22' Safari
Instead of designing a tool to apply the screen to the frame without removing the window frame, I decided to build new screen frames. All materials came from Home Depot, and it appears that it will work. The trim around the screen frame will be new and that is when I will set the screen frame so that appears that the screen frame is built in, but easy to remove to repair a tear. Where I had to cut the screen for it to set flush (see picture) against the frame will be glued with a very strong industrial instant glue and should prevent and tear.
ID:	62468   Click image for larger version
Old 06-16-2008, 07:23 PM   #112
InsideOut's Avatar
1956 22' Safari
Images: 108
Hmmm...interesting. Thanks ~
Shari
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 12:11 PM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 06:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 01:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 02:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 07:26 AM
