Old 11-09-2015, 03:12 PM   #1051
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Albert,check out this link: http://www.airforums.com/forums/f44/...ons-35399.html
www.nesa.org
Air No. 6427
Old 11-09-2015, 04:45 PM   #1052
toastie's Avatar
1955 22' Safari
Great Lake State , .
Originally Posted by albert View Post
Yes, I was definitely planning all new plumbing and wiring, after taking off the inside skins.
I guess I'm just hesitant about she'll of, because it's just me and I have no clue how to make it happen. I know it's the right thing to do though. I will probably be keeping this trailer for myself, so I want everything done right.
I did replace partial floors on my ambassador, without she'll off,but it was just partial. Any advise or thread leads to help me out would be awesome. Thank you.
I plan to start a thread on the journey of this trailer as I will have a ton of questions to ask of all of you.
Starting your own thread will be a great start, when I started my thread I also had tons of questions. Learned a lot from Jim & Susan's thread.
toastie
toastie is offline   Reply With Quote
Old 11-10-2015, 08:18 AM   #1053
1957 26' Overlander
Victoria , British Columbia
I did a shell on restoration of my 57 Overlander. This is my thread, might be of use.
I didn't have space for a shell off restoration, but did a complete rebuild - frame to polishing and everything in between. Without the shell off, putting the floor back in is much harder, but possible.
The worst part of the job was the belly pan replacement- the compound corners in particular, so if you can leave what you have in place then that's what I'd advise. If you can't, then keep as much in tact as you can for a template.
http://www.airforums.com/forums/f36/...ion-87899.html
Sparky57 is offline   Reply With Quote
Old 11-12-2015, 08:58 AM   #1054
Originally Posted by Jim & Susan View Post
Yup, great advice, lots of how-tos, and inspiration, in the Major Renovation threads.
Old 02-11-2016, 09:16 PM   #1055
1953 21' Flying Cloud
Laramie , Wyoming
Toastie thanks for documenting everything here, I just spent the last few hours reading this thread and it was worth every moment!
How comfortable are those mattresses now that you've had them a while?
Greenfire is offline   Reply With Quote
Old 02-12-2016, 09:13 AM   #1056
toastie's Avatar
1955 22' Safari
Green fire
Thanks very much, the foam is 5" with 2" memory foam for a total of 7" like it very much, however, wanted 6" foam with 3" memory for a total of 9" just couldn't make that work. The removable covers are great, perfect.
toastie
Old 02-12-2016, 11:25 AM   #1057
albert's Avatar
1970 29' Ambassador
1959 22' Flying Cloud
1957 26' Overlander
Reno , Nevada
Send a message via AIM to albert Send a message via Yahoo to albert
Can I ask how you got the floor out while still having the shell attached?
Originally Posted by toastie View Post
Notice how the u-channel was constructed on this 1955 Safari, electrical
will be upgraded...........
albert is offline   Reply With Quote
Old 02-13-2016, 07:36 AM   #1058
toastie's Avatar
1955 22' Safari
My restoration was a full shell off.....
toastie
Old 02-13-2016, 10:14 AM   #1059
albert's Avatar
1970 29' Ambassador
1957 26' Overlander
Reno , Nevada
Yes, I saw that as I am still half way through your GREAT thread! But, I did notice that you had your floor removed while the shell was still on. This is where I am at right now with one of my trailers, and I am hoping to get the floor out while still having the shell attached. Possible? How?
Old 02-14-2016, 06:40 AM   #1060
toastie's Avatar
1955 22' Safari
My restoration was a shell off (shell braced to control flexing) floor and belly pan removed, framed removed and repaired. What I did with the new floor and what you are seeing was just a test run, making sure fit and finish would work with plumbing, and that the shell would come down using gage pins to frame. There are 4 holes in frame that I used to align shell, floor. Left shell braced to help with alignment until floor was fasten to frame. Hope this make sense.
toastie
Old 03-17-2016, 01:38 PM   #1061
1954 26' Romany Cruiser
jefferson , Oregon
Toastie, how did you attache them? One side lays down on the main frame rail and the other two ends attach to the outriggers right?. ON one of my fenders The side that is over the main frame rail has holes in it but no hole in the frame. Cant figure that one out. Are they just suppose to sandwich between the floor and the frame. thanks
Stanley29 is offline   Reply With Quote
Old 03-17-2016, 01:39 PM   #1062
jefferson , Oregon
Fenders that is
Old 03-18-2016, 08:36 AM   #1063
toastie's Avatar
1955 22' Safari
Originally Posted by Stanley29 View Post
Fenders that is
See post 158, notice the holes on the side of the wheel tubs (fenders) The wheel tubs get fasten to the outside skin with rivets on my model. And yes the tubs set on top of the frame and plywood floor on top. Be careful on your assembly sequence.
toastie
Old 04-15-2016, 09:47 AM   #1064
toastie's Avatar
1955 22' Safari
It's time to re-polish the trailer again, it's been 4 years. Always trying something new when it comes to polishing and I have hit on something that I really like. Went with Bright Work Polish and finding it superior to Nuvite C, very little black residue. Applying Bright Works with Liberon #0000 steel wool by hand. Then using loose cotton wheel 10" from caswellplating.com with the Dewalt.
Liberon is the best steel wool currently on the market. Unlike other steel wool brands, Liberon treats the steel wool after manufacture to remove the oil used in the manufacturing process. Will not crumble.
http://www.caswellplating.com/buffing-polishing.html
http://www.brightworkpolish.com
toastie
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
