Old 06-06-2008, 06:39 PM   #85
toastie
toastie's Avatar
Profile:  1965 17' Caravel
1955 22' Safari
, , Michigan
Installed lock-set today
Installed lock set to the door today. First was to install the housing, had to fabricate a couple of brackets, and I used plenty of trempro 635.
Installed new 5/16 key stock with new torsion spring to handle, when I went to install the handle there was way to much tilt and slop. Took a piece of very strong nylon drilled a 5/16 hole, took 5/16 key stock heated it to red hot and melted the nylon to make the rectangle hole, no tilt or slop now. All part went together and the lock-set works great..........
ID:	61899  Click image for larger version
ID:	61901  Click image for larger version
toastie is offline   Reply With Quote
Old 06-06-2008, 11:39 PM   #86
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Originally Posted by 62overlander View Post
or you can make them aluminum....
like this.
Hmmm...so you gonna buck those rivets Frank????
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
Old 06-06-2008, 11:50 PM   #87
utee94
Profile:  1963 26' Overlander
Shari
Ha!
Can we give him a pass on interior panels? Maybe not...
Old 06-07-2008, 12:38 AM   #88
monocoque
monocoque's Avatar
Profile:  1975 29' Ambassador
San Antonio , Texas
Frank, I want panels like those! Bucked or not...
Todd
“Complications arose, ensued, were overcome...savvy?”
- Captain Jack Sparrow
monocoque is offline   Reply With Quote
Old 06-07-2008, 12:42 AM   #89
monocoque
monocoque's Avatar
San Antonio , Texas
Exactamundo!
Todd
Old 06-08-2008, 05:54 AM   #90
toastie
toastie's Avatar
1955 22' Safari
, , Michigan
door going back together
door going back together..........
ID:	61986  Click image for larger version
Old 06-08-2008, 06:42 AM   #91
62overlander
not the shiniest rivet
62overlander's Avatar
Profile:  1962 26' Overlander
Catonsville , Maryland
I just get more and more impressed every time I look at this thread.....
read my blog at: http://annalumanum.blogspot.com/ or view my photos at: http://picasaweb.google.com/dadofava1966/AnnaLumanum02
WBCCI, VAC, WDCU#7183
62overlander is offline   Reply With Quote
Old 06-08-2008, 07:26 AM   #92
n2batr
Profile:  1958 26' Overlander
Lander , Wyoming
Thumbs up
Nice job on the lockset. It will look super on that door. If I'm looking at the brackets you added correctly looks like you have these screwed to the lock housing and ? soldered or welded to the aluminum sheet. If not how are they attached? I have these same locksets. My doors have wood brackets which were inserted to hold the housing in place . These did a marginal job and as the wood shrank/rotted the housings have loosenedsomewhat. As I will be rebuilding the doors I am following your fine progress with interest. Ed
n2batr is offline   Reply With Quote
Old 06-12-2008, 05:29 PM   #93
toastie
toastie's Avatar
1955 22' Safari
, , Michigan
Almost done with the door
The door has been the most time consuming so far, but I'm almost done.
Need to tweet and add gaskets and plenty of trempro 635. Here are a few pic's.
ID:	62275  Click image for larger version
ID:	62277  Click image for larger version
Old 06-12-2008, 07:28 PM   #94
Aerowood
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
nice work
Old 06-12-2008, 07:31 PM   #95
clancy_boy
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
Originally Posted by clancy_boy View Post
Speechless....... WOW.......
Nothing to add, SPEECHLESS........ WOW........
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
Old 06-12-2008, 07:40 PM   #96
utee94
I'm not sure how many times I can say "beautiful work" but...
Beautiful work.
Old 06-12-2008, 07:45 PM   #97
62overlander
I quit, anyone want a 1962 overlander? Half restored, half polished?
Old 06-12-2008, 07:58 PM   #98
toastie
toastie's Avatar
1955 22' Safari
, , Michigan
Originally Posted by Aerowood View Post
nice work
Thanks, had to do the inner door outer skin twice, the first time, I stood back and said Aerowood would not approve the rivet job, so I ripped it off, and try-ed it again, not perfect but I'm happy with it.
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1958 - 1963 Overlander 5 09-12-2004 01:24 AM
