Old 11-15-2011, 06:12 PM   #855
toastie's Avatar
1955 22' Safari
Great Lake State , .
It all starts with the water inlet, went with a Perko marine type all chrome on the outside. This in turn connects to a double check valve just inside the inner skin and then connects to the water supply line and over to the water tank for pressure filling. Using stainless steel braided water lines to feed the other side, they run under the AC ductwork.
toastie
ID:	145285   Click image for larger version
toastie is offline   Reply With Quote
Old 11-26-2011, 01:24 PM   #856
toastie's Avatar
1955 22' Safari
Started compounding today, going with a different technique, seems to be MUCH faster. Thanks InsideOut "It's a girl!!!" thread.......
We got everything at Caswell's
(1) - GA58 Grinder/Buffer Adapter
(4) - SSCW1220 Spiral Sewn Cotton Wheels
(2) - LCW1240 Loose Cotton Wheels
(1) ea. - BRBC5 Brown Tripoli Bar & White Rouge Bar
(1) - WR995 Wheel Rake (for cleaning & fluffing the wheels)
toastie
ID:	145974   Click image for larger version
Old 11-26-2011, 03:51 PM   #857
SafariSteve's Avatar
1956 22' Safari
Gresham , Oregon
toastie
Thanks for all these links! I'll be compounding this spring and was going with Nuvite G6, and it's worked well in the few areas I've tried it on, but those bars and cotton wheels look interesting.
Your work is very VERY nice. Thank you!
-Steve
SafariSteve is offline   Reply With Quote
Old 11-26-2011, 04:59 PM   #858
toastie's Avatar
1955 22' Safari
-Steve
Thanks Steve, went with (2) SSCW1220 Spiral Sewn Cotton Wheels and I was shock how fast it worked. Mounted the WR995 Wheel Rake (for cleaning & fluffing the wheels) on a board for easy cleaning. I found this video on youtube showing how the system works, and it works that fast.
toastie
Old 12-03-2011, 12:14 AM   #859
MontanaAIR's Avatar
1958 22' Flying Cloud
Billings , Montana
We got everything at Caswell's ...
toastie
This really has got me thinking! I thought I had a plan for polishing (Nuvite)! I've been polishing windows with a bench buffing wheel, compound and polishing bars and have had incredible results. Why not translate some of that to the rest of the trailer! Thanks Toastie, you inspired me to try something new!
"The one who says it canít be done should never interrupt the one doing it."
MontanaAIR is offline   Reply With Quote
Old 12-03-2011, 06:35 AM   #860
toastie's Avatar
1955 22' Safari
Thanks, using the brown bar with (2) spiral sewn cotton wheels to cut the heavy stuff, then going with nuvite “C’ with spiral cotton wheels with great result. (first cut). For my final cut, trying the loose cotton wheels with white bar or nuvite “C”, done. Want to eliminate the cyclo polisher with cotton wraps and nuvite “S”.
toastie
Old 12-26-2011, 09:25 AM   #861
toastie's Avatar
1955 22' Safari
Added a mid century spring tension pole light.............toastie
ID:	147624   Click image for larger version
Name:	l2 - Copy.jpg
Old 12-27-2011, 02:01 PM   #862
Ottawa , ON
Marvellous, Toastie, just marvellous! If you had two like that you could turn them into an expensive lounge!
Old 12-27-2011, 07:24 PM   #863
toastie's Avatar
1955 22' Safari
Thanks Aage very much, the pole light serves 2 purposes, one is we like the light, two, to keep you from hitting your head on a very sharp corner on the above cabinet which I have hit very hard twice.
thanks again toastie
Old 12-27-2011, 07:50 PM   #864
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
... hitting your head on a very sharp corner on the above cabinet which I have hit very hard twice.
There is a song Coal Tattoo. I have hit my head many times on the door opening going in and out. There needs to be a song for our aluminum tattoos.
FC7039 is offline   Reply With Quote
Old 12-29-2011, 03:52 PM   #865
toastie's Avatar
1955 22' Safari
Saved the bathroom/shower for last, have changed the design at least a dozens times. Decided to go with a copper floor, great deal from a local business on scrap copper, plus very easy to work with, for the cabinet, the boss hasnít decided yet.
toastie
ID:	147805   Click image for larger version
Old 12-30-2011, 12:07 PM   #866
worldinchaos's Avatar
1959 17' Pacer
Long Beach , California
Saved the bathroom/shower for last, have changed the design at least a dozens times. Decided to go with a copper floor, great deal from a local business on scrap copper, plus very easy to work with, for the cabinet, the boss hasn’t decided yet.
toastie
No comments yet?!?! Well i will start vy saying that is gorgeous. Have always loved the idea of copper mixed into these aluminum beauties. Nice job.
- Peter (and Marie)
TAC CA-15
1959 Pacer 18' Renovation - Knight in Shining Armor
Our Adventure Blog - Documenting our backpacking, hiking, camping, and Airstreaming
(still updating, haven't gotten to the Airstream trips yet)
worldinchaos is offline   Reply With Quote
Old 12-30-2011, 12:14 PM   #867
1981 31' Excella II
New Market , Alabama
Is the copper coated with anything to keep it shiny?
Perry
Old 12-30-2011, 12:24 PM   #868
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
toastie
I love the copper too. Were you able to install it as one piece or did you need to solder seams? It seems like it would be possible to fold a soft metal like copper as one piece and overlap/fold up the corners to keep it water tight. Also, what gauge of copper did you use?
Thanks for posting the great pics.
Tim
timzog is offline   Reply With Quote
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 12:11 PM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 06:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 01:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 02:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 07:26 AM
