Old 05-27-2011, 06:48 PM   #757
toastie's Avatar
1955 22' Safari
Great Lake State , .
Originally Posted by hjlairf View Post
Toastie, would you please describe (1) the deadbolt you used and (2) any advice/techniques for others who want to install a deadbolt? Thanks, Hank
Bought from RV Deadbolt (Vintage Trailer Supplies)
It fits doors 1-3/8" to 1-3/4" thick. It has a 2-3/8" backset and a 1" throw. Bolt is only 1/2" wide. However, for this to work on your door, you must be able to drill a hole 15/16" diameter in edge of door for the bolt assembly. Used a belt sander on inner door to contour around the dead bolt. Measure 3 time and cut once..............
toastie
toastie is offline   Reply With Quote
Old 05-28-2011, 11:08 AM   #758
toastie's Avatar
1955 22' Safari
It works...............toastie
Old 05-28-2011, 09:45 PM   #759
1968 26' Overlander
West Richland , Washington
Absolutely AAAAWWWSSSOOOOmmmm
JIMandPJ is offline   Reply With Quote
Old 05-29-2011, 05:25 PM   #760
toastie's Avatar
1955 22' Safari
Determined the height of the toilet and that was done by the plumbing fittings. Once the top goes on it will compress the rubber fitting to the black tank setting the air vent allowing it not to move, allowed
about 1/4” compression, will use silicone to set air vent.
toastie
ID:	131012   Click image for larger version
ID:	131014   Click image for larger version
Old 06-01-2011, 05:55 PM   #761
toastie's Avatar
1955 22' Safari
Worked on the shower today, the cabinet is just a mock up. No plan, just design as I go............
toastie
ID:	131315   Click image for larger version
Old 06-08-2011, 06:49 PM   #762
toastie's Avatar
1955 22' Safari
Since it was over 95 deg’s here in Michigan today, decided to test the 8000 btu air conditioner. The temp in the trailer was over 100 deg's and went to 78 deg’s and was comfortable, however, thinking about going to the 12000 btu unit.
toastie
Old 06-08-2011, 08:25 PM   #763
Central , Mississippi
toastie
I gotta ask...were you in the sun or shade? I've found on my trailers...nobody makes a big enough AC for an Airstream in full sun...
I'm askin because I'm considering using your method of cooling my '63 and getting rid of the big-o-ugly roof unit.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 06-11-2011, 06:26 AM   #764
toastie's Avatar
1955 22' Safari
The sides where partially shaded, the top wasn’t. I’m reworking the door so it wasn’t fully sealed when checking, plus I still need to wrap the duct work outside and inside with insulation, heat was transferring from the duct work, need to isolate duct work from rest of the alum. The air coming out of the unit was 65 deg’s, the 78 deg’s check was at the other end of the trailer. Will tweak and keep the present 8000 btu AC for one camping season, if not happy will go to the 12000 btu unit for more volume, a very easy change, slide out the old, slide in the new. Putting air on top our 1955 Airstream was never an option. Very happy so far............
toastie
Old 06-11-2011, 07:41 PM   #765
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
This may be an odd question. Can rotate your unit in the winter and use it as a "heat pump", or set up the vents to blow th hot in during the winter?
FC7039 is offline   Reply With Quote
Old 06-12-2011, 08:31 AM   #766
toastie's Avatar
1955 22' Safari
Great question, if we where winter campers I would probably run duct work from the hot air main duct, one to the back and one to the front and just close the exhaust out the back (behind the license plate). Would have to come up with a way to direct cold air out, which is very possible or just set the cold air temp up, would have to play around with it, just might give it a try. thanks.............
toastie
ID:	132286   Click image for larger version
Old 06-12-2011, 11:21 AM   #767
toastie's Avatar
1955 22' Safari
Set the drain to the shower today, will let it set up at least 24 hours before continuing. The below grey water tank is only for the shower only.........
toastie
ID:	132294   Click image for larger version
ID:	132296   Click image for larger version
Old 06-15-2011, 03:42 PM   #768
toastie's Avatar
1955 22' Safari
Pick up a pair of Seeburg 1950's jukebox teardrop speaker's.
toastie
Old 06-24-2011, 07:04 PM   #769
baby_beluga's Avatar
1957 16' Bubble
Fort Collins , Colorado
Toastie, great work! Where, may I ask did you find the decorative material for the cabinet doors and a/c. Haven't been able to find it in your thread. I've been looking for something similar with no luck. I wish I had the patience to work with such detail.
baby_beluga is offline   Reply With Quote
Old 06-25-2011, 05:46 AM   #770
toastie's Avatar
1955 22' Safari
Thanks very much, you can find it at Home Depot http://www.homedepot.com/buy/tools-hardware-hardware-fasteners-metal-stock-sheet/md-building-products-1-x2-union-jack-alum-sheet-mill-127929.html , its made by http://www.mdteam.com/index.php/products/aluminum-shapes-a-metal-sheets
MD Building Product also makes the edging that we used for the counter tops, table, etc. We bought the edging off e-bay http://cgi.ebay.com/6CT-3-4-x-8-Alum...item3c9ec53594
toastie
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
