Old 05-11-2011, 05:49 PM   #743
Ottawa , ON
Originally Posted by toastie View Post
TAKING A BREAK FOR THE BOOGIE WOOGIE.....TOASTIE
Those folks are truly incredible. I suppose they should be, they've been champions at it for years!
Thanks for the link, Toastie, that's one I hadn't seen.
Old 05-13-2011, 03:39 PM   #744
toastie's Avatar
1955 22' Safari
Great Lake State , .
They are great, of all places Sweden, here is another great one..............toastie
toastie is offline   Reply With Quote
Old 05-14-2011, 08:41 AM   #745
toastie's Avatar
1955 22' Safari
Installed sink and faucet today............toastie
ID:	129791   Click image for larger version
Old 05-14-2011, 03:25 PM   #746
toastie's Avatar
1955 22' Safari
Putting the finish touches on the AC, work's great............toastie
ID:	129824   Click image for larger version
Old 05-14-2011, 03:48 PM   #747
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Looks great Toastie! How is the noise level being that it is between the beds?
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 05-14-2011, 04:28 PM   #748
toastie's Avatar
1955 22' Safari
Thanks tinman54, the noise is about 50% less than the roof top in our 65 Caravel with a Dometic's Penguin AC. When at home, we sleep with a fan on 365 days anyway. It’s a Frigidaire Window-Mounted Slider / Casement Air Conditioner Model: FAK085R7V 14-3/16" W x 20-1/4" H x 24-1/2" D, 8,000 btu, Amps (Cool): 7.2., run very quite for a AC......$329.00. at Best Buy
toastie
Old 05-15-2011, 11:27 AM   #749
toastie's Avatar
1955 22' Safari
Set the primary shower wall and caulk the seam. There will be a shower curtain that will divide the opposite wall.
toastie
ID:	129880   Click image for larger version
ID:	129882   Click image for larger version
Old 05-16-2011, 06:10 AM   #750
toastie's Avatar
1955 22' Safari
Added Reese 26002 Dual Cam HP Sway control, the trunnion spring bars are rated at 600lbs.
Toastie
Old 05-17-2011, 04:24 PM   #751
toastie's Avatar
1955 22' Safari
For my stereo system I will be running everything through this late 1948 to early 50’s jukebox. Changing the labels and doing a little clean up and everything seems to work, 4 plays for a quarter and 1 play for a dime. Next step is to hook it up to my IPod, hope it works.
toastie
Old 05-17-2011, 04:34 PM   #752
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
That is way beyond cool! Make sure it's loaded The King. UhHuh.....
www.nesa.org
Air No. 6427
Old 05-17-2011, 04:36 PM   #753
toastie's Avatar
1955 22' Safari
Have the KING, and 99 other great hits of the 50's.........toastie
Old 05-22-2011, 06:31 PM   #754
toastie's Avatar
1955 22' Safari
Another great time at "TIN CAN TOURIST" 2011........toastie
Tin Can Tourists
ID:	130448   Click image for larger version
Old 05-26-2011, 07:04 PM   #755
toastie's Avatar
1955 22' Safari
My bargman H20-2 keyed lock set works great, however, I just don’t trust it, and and decided to install a new deadbolt today.
toastie
ID:	130755   Click image for larger version
Old 05-27-2011, 10:48 AM   #756
RankAm's Avatar
1956 22' Flying Cloud
Dallas , Texas
Deadbolt
Toastie, would you please describe (1) the deadbolt you used and (2) any advice/techniques for others who want to install a deadbolt? Thanks, Hank
RankAm is offline   Reply With Quote
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
