Old 04-23-2011, 07:16 AM   #729
toastie's Avatar
1955 22' Safari
Great Lake State , .
Originally Posted by 3Ms75Argosy View Post
Toastie... I'll be better able to picture it after it's up I suppose... what are you using to line the shower with? Was this a standard door from Home Depot? Will there be a inner and outer "finish" which abuts the studs around the frame?
Marc
The door is made by Sterling, model 1500D-27S, EZ find H50, was on sale for $89.00 at Home Depot. The interior walls will be covered with Formica charcoal boomerang #6942-58, the material against the the alum. wall is from Home Depot, it’s a vinyl light grey type material, Home Depot uses it in all of there bathrooms, very flexible. The Formica wall will set against the outside wood frame of the shower door and will be flush with outside shower trim.
toastie
toastie is offline   Reply With Quote
Old 04-23-2011, 08:33 AM   #730
toastie's Avatar
1955 22' Safari
Marc
Marc
Here is another picture showing the 1/2" brich plywood the will get fasten to shower door wood frame, the inside birch plywood will have the boomerang formica...........
toastie
Old 04-23-2011, 10:05 AM   #731
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Ahh! That IS what I pictured... I just wasn't sure. Just wondering... if one were to drill big holes in the wood and then cover it up with the formica and inner covering, would the holes telegraph through the laminate and plastic insides? I'm thinking of what could make the walls a bit lighter.. although, I'm sure those walls aren't that heavy.
It's funny, I know there's not that much room in a trailer, but that door makes the walls seems so expansive!
Thanks for the info!
Marc
Old 04-23-2011, 04:34 PM   #732
toastie's Avatar
1955 22' Safari
Looks like it going to go together, the door will be raised about 5”.........
toastie
ID:	127947   Click image for larger version
ID:	127949   Click image for larger version
Old 04-23-2011, 04:38 PM   #733
Ottawa , ON
VERY sleek interior, toastie! Can't wait to see it all finished!
Old 04-24-2011, 06:12 PM   #734
toastie's Avatar
1955 22' Safari
Raised the shower door to be able to service the Hep waterless trap, the trap sets right on top of the shower tank, there will be a removable front panel to service. The 18 gal tank which is in front of the axle is just for the shower only.
toastie
ID:	128025   Click image for larger version
Old 05-07-2011, 07:46 AM   #735
toastie's Avatar
1955 22' Safari
Added the boomerang Formica and hardware to the shower walls today............toastie
ID:	129232   Click image for larger version
Old 05-07-2011, 09:12 AM   #736
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
That's a good solution. Very sleek.
truckasaurus is offline   Reply With Quote
Old 05-07-2011, 10:00 AM   #737
Tool Hoarder
West , California
Nice I love this thread! Great work
marzboy is offline   Reply With Quote
Old 05-07-2011, 02:55 PM   #738
toastie's Avatar
1955 22' Safari
TAKING A BREAK FOR THE BOOGIE WOOGIE.....TOASTIE
YouTube - Dancin' The Boogie - Silvan Zingg (piano), Will & Maéva
Old 05-08-2011, 06:40 PM   #739
toastie's Avatar
1955 22' Safari
Work on putting the shower wall's up today, here is a picture of the inside..........toastie
Name:	insid shower.jpg
Old 05-08-2011, 07:27 PM   #740
1975 Argosy 26
1963 24' Tradewind
Wow Toastie, that looks wonderful! Better than factory fit on the curves too! What will you use to seal the inside to the wall above. I'm also curious, is the shower pan in already? Does the wall fit inside the lip of the pan?
Marc
Old 05-09-2011, 12:12 AM   #741
n8andm's Avatar
Minneapolis , Minnesota
Bargman lock
I am one of many people looking for this door handle, and I just stumbled on this posting. My interior handle is different, and ugly. Can you send me a pic of the refurbished door handle? I need to get my mine better looking/working. Does re-chroming remove pitting?
Originally Posted by toastie View Post
To cold to work outside, so I removed some of the window's, and the door, and working on them in the basement. Had a good fine on e-bay picking up
2 Bargman lever with locks in one auction, will have a local locksmith make new keys. Parts will be sent out to be chromed, and hoping to end up with one complete set. Also planning and researching for when the weather breaks here.
_______________
/.:N8andM.in.MN:.\
|:Silver Streak Jet:|
n8andm is offline   Reply With Quote
Old 05-11-2011, 06:17 PM   #742
toastie's Avatar
1955 22' Safari
Marc
Thanks Marc, to seal the wall above I will use silicone, I found a perfect color match both outside and inside. I can’t go with a pan because the gray tank is directly below, need to be able to service. The plan today is to go with a membrane with a removable teak floor. If I would have know when setting the gray tank, I would have designed the tank with a internal trap built inside the tank, maybe on the next one.
toastie
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 12:11 PM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 06:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 01:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 02:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 07:26 AM
