Old 04-16-2011, 10:08 AM   #715
toastie's Avatar
1955 22' Safari
Great Lake State , .
When laying the floor down, I didn’t lay it all the way to the wall’s, this enabled me to use trempro around the full perimeter of the flooring
and interior walls. It wasn’t the money, it's about water control, I’m convinced that all rv’s leak, Prevost, etc, and also mine. I have gone through 22 tubes of trempro635 since the start of this project, and still not finished.
toastie
ID:	127105   Click image for larger version
toastie is offline   Reply With Quote
Old 04-16-2011, 11:59 AM   #716
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Very good idea! I am planning the same, everything outside new or old will leak. There are plenty of threads on here with new 2010-11 trailers that leak.
Your trailer is looking great!
Doug
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 04-17-2011, 07:58 AM   #717
toastie's Avatar
1955 22' Safari
Doug
Thanks very much Doug, so far the only thing that I'm not happy about is the new axle. I went with a straight 5500lb axle which raised the trailer about 3”, the reason was because of dropped tanks. Plan to go back to a 3500” drop axle, the leaf springs on the trailer is rated 3500#...........
toastie
Old 04-17-2011, 12:24 PM   #718
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
Originally Posted by toastie View Post
When laying the floor down, I didn’t lay it all the way to the wall’s, ...
toastie
You chose to not lay the flooring wall to wall and then place the fixtures. Others I have seen lay the complete floor, then add the dinet and other furniture. I am at that point. What were you pros and cons of not laying a complete floor?
Great looking trailer byt he way.
Gene
FC7039 is offline   Reply With Quote
Old 04-17-2011, 04:19 PM   #719
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
toastie
That's interesting about the axle, I was going to do a straight axle to gain a little height and the shop talked me out of it saying the old drop axle was built better. They installed new brakes,back plates, bearings and re-arched the springs which gained about an inch and half in height. It cost about the same as a new axle.
Old 04-18-2011, 06:18 PM   #720
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Toaste - I don't mean to cause any trouble, just some thoughts.....
I'm not sure how much you will gain by sealing the inside - rot/water happens from outside the trailer - especially from the edges of the plywood that tend to suck up water - I think it is more important to soak the edges of the plywood and about 6 inches in from the edge with epoxy.............
Just some friendly thoughts.
Beautiful job - really enjoying watching this thread........
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 04-18-2011, 06:41 PM   #721
toastie's Avatar
1955 22' Safari
Ken J.
Thanks Ken, I did seal both top and bottom of the plywood and also sealed the edges, this is just added protection, or control. I do know that when I do get a leak that it will not go under the finished floor. I have had friends that have had to rip up there floor to trace a leak, its my early leak protection.............
toastie
Old 04-18-2011, 07:06 PM   #722
Ken J's Avatar
Durango , Colorado
Images: 14
Thats cool -
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 04-20-2011, 04:36 PM   #723
toastie's Avatar
1955 22' Safari
Going with a electric heater made by KING, its model KT1210-B, 120v, 1000w, 8.3amp, its a narrow profile heater, 3 1/2" tall and specifically designed for floor saving and wall space.
toastie
ID:	127743   Click image for larger version
Old 04-20-2011, 05:50 PM   #724
Melody Ranch's Avatar
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I did it too
I went with the King also. It fits perfectly....but got to plan to keep items at a safe distance.
Name:	Furnace...King electric.jpg
Old 04-22-2011, 06:50 AM   #725
toastie's Avatar
1955 22' Safari
Installed the heater today, a great little heater, our camping is spring, summer and fall and normally with full hookups...........
toastie
Old 04-22-2011, 09:41 AM   #726
toastie's Avatar
1955 22' Safari
Working on the shower / bathroom today, the shower / bathroom will be built around this shower door, hope it work's out..................
toastie
Old 04-22-2011, 04:18 PM   #727
toastie's Avatar
1955 22' Safari
Framed the shower door today, the finished walls of the shower will set flush with the outside trim of the shower door.................
toastie
ID:	127872   Click image for larger version
ID:	127874   Click image for larger version
Old 04-22-2011, 07:07 PM   #728
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Toastie... I'll be better able to picture it after it's up I suppose... what are you using to line the shower with? Was this a standard door from Home Depot? Will there be a inner and outer "finish" which abuts the studs around the frame?
Marc
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
