Old 01-09-2011, 09:25 AM   #645
wheelerimage's Avatar
1965 20' Globetrotter
1955 22' Safari
Butte , Montana
Images: 8
In post #72, you said you stripped the interior paint using #4 Steel wool with a plastic handle. Where did you get steel wool with a handle? I am gleefully stripping the paint in my 55 Safari. I have not been able to find steel wool with a handle. Lowes has Gator brand synthetic steel wool with a plastic handle. Thank you for this amazing thread!
wheelerimage is offline   Reply With Quote
Old 01-11-2011, 04:21 PM   #646
toastie's Avatar
1955 22' Safari
Great Lake State , .
Originally Posted by Kirk T View Post
What kind of buffer do you use?
This is what I used..........toastie
http://www.perfectpolish.com/
toastie is offline   Reply With Quote
Old 01-12-2011, 11:33 AM   #647
2008 27' Classic FB
Plymouth , Massachusetts
amazing thread
Toastie,
My hat is off to you. I love the thread, best one I've come across with so many good and detailed pics, really explains the process. I just bought a '54 Cruiser but won't be picking it up until May, 2011. I just finished building an aluminum airplane a few months ago and miss not having a project. The Airstream is a natural progression and will allow me to use all the skill and tricks I picked up building the plane...plus I already have the tools. You can see the trailer by clicking on the link below and going to the Airstream page. As I rehab/remodel this thread will be my guide...it's the best!!
With the questions above regarding paint removing has anyone considered a soda blaster? That's my plan, messy but beats dealing with chemicals and it's very easy and no damage to the aluminum. Harbor Freight sells a cheap one for $100 and one 40 lb bag of the media should do it :Search results for: 'soda blaster'
Check out youtube for how it's done, removes the paint but no damage to the metal:
Don...
2008 27FB Classic
My Airplane Construction Website:
http://www.donsbushcaddy.com
NTRPRZ is offline   Reply With Quote
Old 01-13-2011, 06:09 PM   #648
toastie's Avatar
1955 22' Safari
Originally Posted by NTRPRZ View Post
Toastie,
Don
First, welcome to the forum and thanks very much for your kind words. The soda blaster looks like a money and time saver, will give it a hard look on the next project. The '54 Cruiser looks great and I hope you start a thread to show your progress with plenty of pictures. Your plane looks fantastic, great job.
toastie
Old 01-13-2011, 06:14 PM   #649
soldiermedic's Avatar
Florissant , USA
Harbor Freight sells a cheap one for $100 and one 40 lb bag of the media should do it.
I purchased that unit from Harbor Freight with a 50 lb bag of media. This was not enough to do even one of the endcaps in my trailer. Also the reservoir is pretty small and needs to be refilled constantly.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 01-13-2011, 07:04 PM   #650
BabyBoomers's Avatar
1963 22' Safari
Tulsa , Oklahoma
But did it knock the bad stuff off without damaging the metal and leave you with a surface that polished well?
BabyBoomers is offline   Reply With Quote
Old 01-13-2011, 07:06 PM   #651
Florissant , USA
I knocked off the stuff yes, but the blasting matted the finish. Didn't try polishing after that.
Steve
Old 01-13-2011, 07:08 PM   #652
1963 22' Safari
Tulsa , Oklahoma
Steve
Sorry, I haven't been here long and learned how to use the tools yet.
So did the HFT soda blaster leave you with a good surface that polished well? I was considering that but think I saw a post from someone who used it to get a satin finish and from some reason I thought it was a good start for polishing.
Thanks. This is a great resource!
Old 01-13-2011, 07:21 PM   #653
1963 22' Safari
Tulsa , Oklahoma
Originally Posted by babyboomers View Post
sorry, i haven't been here long and learned how to use the tools yet.
So did the hft soda blaster leave you with a good surface that polished well? I was considering that but think i saw a post from someone who used it to get a satin finish and from some reason i thought it was a good start for polishing.
... Was not ...
Old 01-15-2011, 10:47 AM   #654
toastie's Avatar
1955 22' Safari
Starting to gather parts for my plumbing, it's just to cold outside to work on the trailer. It all starts with the water inlet, going with Perko marine type (Part #499-DPCHR) which will be mounted to belly pan. This will connect to a Watts dual check valve inside, will have the ability to disassemble, even after installed for cleaning or repair. Then connects to a flojet Model # 2840-100 pressure system, integrated 12V dc Pump and 1.1 gallon accumulator tank system. Provides 4.5 GPM open flow, Shut-Off at 40 PSI. (should work fine with the copper joints) 10 Max Amps. Can be mounted vertically or horizontally.
toastie
Name:	dual check valve.jpg
ID:	119314   Click image for larger version
Old 01-17-2011, 12:59 PM   #655
toastie's Avatar
1955 22' Safari
Worked on the hot water tank today and not wanting to cut a rectangle hole for a LP hot water tank decided to go strictly electrical. In all of our camping we always have at least 30 amp service. Because of space and height restriction decided to go with Suburban sw6de and since the 120V doesn't talk to the 12V and LP components decided to remove them. Will give it a test before permanently installing
toastie
Name:	hot water.jpg
ID:	119535   Click image for larger version
Name:	hot water1.jpg
Name:	hot water2.jpg
Old 01-19-2011, 04:21 PM   #656
toastie's Avatar
1955 22' Safari
Added a valve to hot water drain, the temperature pressure relief and hot water drain will go through the floor. Also added by-pass and unions to hot water tank, should be no problem for removal. The hot tank will set in a pan with drain.
toastie
Name:	hot water5.jpg
ID:	119681   Click image for larger version
Name:	hot water4.jpg
Name:	hot water3.jpg
Old 01-23-2011, 09:23 AM   #657
toastie's Avatar
1955 22' Safari
Getting ready install Formica and polished aluminum counter edging. The edging is
3/4" x 8' Alum Edging by MD Building Prod #67371, 6063-T5 aluminum alloy.
toastie
ID:	119913   Click image for larger version
Old 01-23-2011, 03:00 PM   #658
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
It's been a while since I've checked your thread...I've missed a LOT of progress! (I'm caught up now)
Looks great, from the photos it looks like your workmanship is top-notch.
Nice job of documentation, this thread has (and will continue) served as a good how-to guide for many. I bookmarked several links just catching up today. Thanks!
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
