Old 12-16-2010, 10:34 AM   #631
wheelerimage's Avatar
1965 20' Globetrotter
1955 22' Safari
Butte , Montana
Images: 8
Paint removal
Originally Posted by toastie View Post
Next will be paint removal, up to 3 layers..........
Wow. You stripped the paint fast! I just bought a 55 Safari and need to strip it also. What did you use? Someone mentioned CitriStrip if I'm working in the trailer. Or, Aircraft stripper if I remove the panels. Did you use sandpaper? I appreciate anything you can tell me. Thanks!
Scott
wheelerimage is offline   Reply With Quote
Old 12-17-2010, 09:13 AM   #632
I believe Toastie provided some detail on the methods and products he used for stripping, somewhere in this thread.
And that's probably reasonable advice-- citristrip inside, and the nastiest aircraft remover you can find if/when you pull the panels. For me, the citristrip did great at removing multiple layers of latex house paint, did okay at removing the zolatone (took several applications and lots of scraping with plastic putty knives), and was absolutely useless on the baked-on enamel that was used for my overhead lights. The ONLY thing that worked on that baked-on enamel was the aircraft remover, and it worked just about instantly.
Good luck!
Old 12-17-2010, 06:26 PM   #633
toastie's Avatar
1955 22' Safari
Great Lake State , .
Scott
Try this http://www.airforums.com/forums/f36/...t-38289-6.html post 72
toastie
toastie is offline   Reply With Quote
Old 12-18-2010, 02:09 PM   #634
toastie's Avatar
1955 22' Safari
Making progress at 15 deg's............toastie
ID:	117214   Click image for larger version
Old 12-18-2010, 03:23 PM   #635
pbearsailor's Avatar
Port Hadlock , Washington
Makes our high 30's seem really warm!
Really looking great, quality work as always. I continue to steal ideas from you.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 12-25-2010, 10:50 AM   #636
toastie's Avatar
1955 22' Safari
Going with plexiglass for the above cabinets, subject to change of course. From here on this could become expensive, wife has complete veto power.
toastie
ID:	117842   Click image for larger version
Old 12-26-2010, 12:28 PM   #637
1955 22' Safari
Butte , Montana
Images: 8
I finally finished reading this entire thread. Awsome stuff! I didn't see what you are doing for propane heat or insulation. It looked like reflectix in the walls and fiberglass in the door. I saw you put the panel ray vent cover on the outside. Is that just for looks? I have the original heater in my 55 Safari but I think it is butane and not propane and will have to go.
I learned with my 65 Globetrotter restoration that the old insulation is worthless. I am always curious to see what people use. I am thinking of using polyurethane foam for a higher R value and to help seal against water leaks and mice.
Your thoughts ?
Old 12-28-2010, 08:18 AM   #638
toastie's Avatar
1955 22' Safari
Your thoughts ?
Thanks wheelerimage
I put no insulation below the wood floor, I installed stainless steel vents in the belly pan for ventilation. Fiberglass itself will not support mold growth, but the problem with fiberglass insulation is that once it gets wet or damp from improper floor ventilation, it takes a long, long time to get it completely dry. While it's drying, it's holding moisture in contact with the wood floor and the frame that WILL be affected by prolonged exposure. Wet, damp fiberglass insulation will prevent those materials from drying out and mold could begin to colonize.
toastie
Old 12-30-2010, 08:10 PM   #639
toastie's Avatar
1955 22' Safari
Almost done with the mock-up design stage, big change's will come to a end and will get more detailed. Designed the dinette cushions today, the brown tape represent the back cushions. The dinette will turn into a 54"x 72" bed. The back of the dinette will be a shoe rack for 10 pairs.
toastie
Old 12-31-2010, 04:29 AM   #640
thefishman's Avatar
1973 25' Tradewind
Newport beach, Three Rivers(Sequoia national park) and LA , California
Nice!
thefishman is offline   Reply With Quote
Old 01-01-2011, 12:26 PM   #641
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Thanks wheelerimage
toastie
I agree Toastie, There really is no need for insulation in the floor for a camper that is only used in the summer. No matter what type you use it will trap moisture against the floor and frame and give the mice material for there home.
Your finish work is looking great!
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 01-01-2011, 04:28 PM   #642
toastie's Avatar
1955 22' Safari
Worked on the dinette today, should finish next week and will disassemble and start putting the finish floor down.
toastie
ID:	118472   Click image for larger version
ID:	118474   Click image for larger version
Old 01-02-2011, 05:12 PM   #643
toastie's Avatar
1955 22' Safari
Worked on the other half of the dinette today, I had no problems getting the awning pole's in. Next on the list is stereo speakers............
toastie
ID:	118570   Click image for larger version
Old 01-08-2011, 06:05 PM   #644
Kirk T's Avatar
1956 26' Cruiser/Overlander
1957 26' Overlander
Alva , Oklahoma
Buffer
What kind of buffer do you use?
Kirk T is offline   Reply With Quote
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 12:11 PM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 06:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 01:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 02:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 07:26 AM
