Old 12-10-2010, 10:39 AM   #617
dznf0g's Avatar
Oswego , Illinois
Originally Posted by Zeppelinium View Post
PEX ring crimp 1/2" elbows -- $0.58 in a box of 25
I got my crimper used from a local plumbing store which was selling one of it's rental units. Sharkbites are great for quick repairs in the field by hand, but in hundreds of crimps, I have had zero failures [so far].
Love da crimper! Anyone seen red and blue copper?
Zep (so, sorta, for the hijack...)
What do these crimpers look like and why are they so expensive?
Old 12-10-2010, 10:55 AM   #618
Roadtrain O--O~(--ooo--)
ebair's Avatar
2000 34' Limited
1979 31' Excella 500
Miamisburg , Ohio
Pex is the way to go, the crimper isn't cheap, but I made up the cost on the first use. My teenage helper and I were able to completely replumb (repex?) a medium size rental house in 6 1/2 hours at a cost that was 1/3 of copper. There is enough left over on the rolls to do another and the AS to boot. Add in the resistance to cold weather bursting and the non-appeal to metal scrappers and it seems the best option.
They look like bolt cutters with jaw inserts for the different size tubes.
Good tools are never cheap, cheap tools are never good
You could always do your project then ebay or CL the tool to recoup most of the cost
'00 34' Classic Limited (LOVSHAC)
'12 3500HD, 4x4 LBZ D/A CC LB
AIR #12881
TAC OH-10
ebair is offline   Reply With Quote
Old 12-10-2010, 05:16 PM   #619
toastie's Avatar
1955 22' Safari
Great Lake State , .
$200 for a good clamp crimp tool, the heads stay in alignment without an additional hand. Good luck.
toastie
toastie is offline   Reply With Quote
Old 12-10-2010, 07:30 PM   #620
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
I bought my "Zurn multi-head crimp tool" through Amazon for $120 - it does four common sizes, has a removal tool and a few extras in the box. It works very well and has never done a bad crimp yet.
It paid for itself after one household job, considering the saved costs, materials and time.
TX-16
Dave Park is offline   Reply With Quote
Old 12-10-2010, 09:13 PM   #621
1973 31' Sovereign
Portland , Oregon
Images: 22
I bought my Zurn tool at Home Depot
My PEX tool is also a Zurn which I bought at Home Depot. The following HD site shows what it looks like and lists it for $94 which is a pretty good value in my opinion.
Multi-head Pex Crimp Tool Kit - QCRTMH at The Home Depot
Happy PEXing,
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
Old 12-10-2010, 09:16 PM   #622
dznf0g's Avatar
Oswego , Illinois
Thanks, folks. Hopefully I won't need on for awhile, but best to be educated.
Old 12-10-2010, 09:21 PM   #623
Dave Park's Avatar
2005 22' Safari
That is not the tool I have. The tool I have comes in a carry case, and contains the Mult-Head Crimp Tool, 3/8" Jaw, 5/8" Jaw, 3/4" Jaw, 1/2" Jaw, Optional Crimp Ring Removal Tool and Crimper Adjustment Tools.
Amazon link
Yours is the basic crimper. The one in this set has a "go/no-go" option that really protects you from improper crimps.
I think that's worth $25 extra alone.
TX-16
Old 12-11-2010, 08:37 AM   #624
toastie's Avatar
1955 22' Safari
This is what I'm go to use to crip my pipes, will have it done in less than a hour, and no leaks, all for under $50.00.......childs play.
toastie
Old 12-11-2010, 09:17 AM   #625
Jabba's Avatar
1955 30' Liner Commodore Vanderbilt
Wayne County , Michigan
Thanks again for sharing your progress. Awesome work, the level of neatness is inspiring!
Are you going to install unions anywhere or go with sweat all the way to the connections?
Jason & Veronica J.
S.E. Michigan
1955 Commodore Vanderbilt 30'
"Hawley"
TAC Member MI-6
2008 Chevy Silverado Ext. Z71 w3.73
Jabba is offline   Reply With Quote
Old 12-11-2010, 10:12 AM   #626
toastie's Avatar
1955 22' Safari
Yes, the design intent to blow the line's out, no need for antifreeze. The trap's are waterless. Also will remove fresh water tank, for winter storage and to sanitize.
toastie
Old 12-13-2010, 06:22 AM   #627
fastrob's Avatar
1976 25' Tradewind
. , AZ to Maine
Waterless Trap
Is a waterless trap like a flap?
"Talk is cheap, Airstreams are expensive," Wally Byam.
fastrob is offline   Reply With Quote
Old 12-13-2010, 08:44 AM   #628
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Hepvo Waterless Valve
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 12-13-2010, 10:45 AM   #629
1973 31' Sovereign
Portland , Oregon
Images: 22
Amazon link
Perhaps the Home Depot item that I selected is not the right one. Mine did include the extra jaws and ring removal tool. It has the blue colored handles just like in the Amazon photo and otherwise looks identical. I thought from reading the fine print on the ad that it said that the Home Depot one has multiple heads and the removal tool. The Photo at the Home Depot site was just of the tool itself and did not show the case and other parts. Certainly $25 extra would be worth the cost if the Home Depot one does not include these extra things. Mine did though and was less than $100.
Malcolm
Old 12-13-2010, 10:52 AM   #630
Dave Park's Avatar
2005 22' Safari
Good to know
Therefore, the good tool set is under $100, and the PEX choice is a little easier
And now back to our originally scheduled toastie...
TX-16
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
