Old 11-15-2010, 06:12 AM   #589
toastie's Avatar
1955 22' Safari
Great Lake State , .
Originally Posted by kevinb View Post
Just got my 40 lb tanks fitted w/new valves and filled w/gas for 104.00, pretty good deal,but the circular bar the tanks set in is bent so I made need a new set up (for the 64 tw) How do you like yours and where did you get it?
By the way got the bal jacks at camping world like you suggested still on sale for 69.99 a pair plus used a 50.00 gift cert in the mail so 2 pair for 100.00 pretty cool huh? So thanks for the tip on the jacks.
kevin
kevin
I had to buy the complete propane rack ass'y; bought from General RV for under $30.00, that didn't include regulator or hoses. You should be able to find a replacement rod from your local RV store. I really like the Bal scissor jacks, it solves so many problems, storage, tire changing, leveling, safety. I was going to use a power drill to lower and raise but decided against it, the jacks have ball bearings and are very easy to lower and raise, plus I don't have to take a drill. I added my new wheels yesterday and rising the trailer was very smooth and took no effort at all to raise. My goal is to be able to change a tire without opening the trailer door or tearing into the TV.
toastie
toastie is offline   Reply With Quote
Old 11-15-2010, 02:13 PM   #590
1973 31' Sovereign
Portland , Oregon
Images: 22
Originally Posted by toastie View Post
kevin
toastie
Do you have a link to the rack assembly at General RV? I have tried to find it on their website but it seems to be hiding. I am not finding it under propane categories.
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
Old 11-15-2010, 04:01 PM   #591
toastie's Avatar
1955 22' Safari
Malcolm
I have the sku number's you will probably will have to call there 1-800 number
LP tank mtg kit 30# ...........08622.........24.95
regulator bracket................1589.............2.95
15" lp gas pigtail................40408............15.95ea.
You can also buy from Propane Regulators
toastie
Old 11-15-2010, 11:37 PM   #592
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
Toastie
Thanks for the assembly info. I wish it was just the rod,but actually there is a 1" piece of flat iron welded to the frame, that is the bent part. May have to cut it off and start over using a base like you show in the photo. You know how it goes nothing is ever easy.
kevin
kevinb is offline   Reply With Quote
Old 11-16-2010, 06:49 PM   #593
toastie's Avatar
1955 22' Safari
Finished compounding with heavy wool pad tonight. I will compound again with cyclo polisher with warps taking the streaks out and then wait until spring to polish. Going to try Harley Davidson glaze for sealing, will apply 3 to 4 times a year to maintain shine.
toastie
ID:	115394   Click image for larger version
Old 11-16-2010, 07:43 PM   #594
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Outstanding Toastie!
bwaysteve is offline   Reply With Quote
Old 11-16-2010, 08:26 PM   #595
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Looks so good, no need for a mirror in there.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 11-21-2010, 05:49 PM   #596
toastie's Avatar
1955 22' Safari
Added a few parts today, fans, lights, manual rotor for a antenna. Learning that mid century original stuff can be pricey. Very happy with the leds from http://www.vintagetrailersupply.com/12V_LED_Puck_Light_p/vts-816.htm
toastie
ID:	115713   Click image for larger version
Old 11-22-2010, 04:32 AM   #597
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Fun stuff! looking good!
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 11-23-2010, 03:13 PM   #598
A 7th year newby
IndyAnne's Avatar
1968 24' Tradewind
Indianapolis , Indiana
Images: 8
Send a message via Yahoo to IndyAnne
Great work!
Thanks so much for keeping the posts going. Very inspiring!
Anne
Anne
Indianapolis, IN
TAC IN-7
1968 Airstream Trade Wind
2005 Chevy K1500 crew, reg. bed, 4WD, gas
IndyAnne is offline   Reply With Quote
Old 11-27-2010, 02:47 PM   #599
toastie's Avatar
1955 22' Safari
Started working on the dinette today. The back cushion and the bottom will be 5" thick and should accommodate about 6 people. Will remove for finish floor install then will permanently install the dinette.
toastie
ID:	116009   Click image for larger version
ID:	116011   Click image for larger version
Old 11-27-2010, 05:06 PM   #600
soldiermedic's Avatar
Florissant , USA
I love your work toastie!
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 12-01-2010, 04:10 PM   #601
toastie's Avatar
1955 22' Safari
Was not happy at all with the fuse block that I had, decided to go with Blue Sea fuse block. Part number 5026
ST Blade Fuse Blocks - Blue Sea Systems
Blue Sea 5026 ST Blade Fuse Block w/ Cover - 12 Circuit - eBay (item 200531624151 end time Dec-13-10 23:14:38 PST)
toastie
ID:	116363   Click image for larger version
Old 12-02-2010, 07:39 PM   #602
toastie's Avatar
1955 22' Safari
Started finishing the 12v system tonight, very happy with the new 12v fuse block. The fuse block came with label.
toastie
ID:	116433   Click image for larger version
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
