Old 10-10-2010, 05:43 PM   #575
pbearsailor's Avatar
Port Hadlock , Washington
That is a really great looking handle, Toastie!
I had a set of those waste hose castings arrive in the mail a couple of days ago. They're pretty nice.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 10-11-2010, 05:59 PM   #576
toastie's Avatar
1955 22' Safari
Great Lake State , .
Thanks Steve,
If you received the same castings that I did, the thin wall pvc from Home Depot or Lowes will not work, the inner dia is to small, there is a thinner wall that you will need. I found the thinner wall at Tractor Trailer supplies and still had to modify the hose connection just a little to make it work, I really like the set up................toastie
toastie is offline   Reply With Quote
Old 10-15-2010, 09:01 AM   #577
1973 31' Excella 500
Spring Green , Wisconsin
toastie,
I've read your entire thread over the past couple days. It was like reading a good novel.
Thank you for taking the time to share so many pictures, products, resources and so much valuable information.
Your trailer is amazing!! Keep up the good work.
Lew TAC #WI-6
Nobody can help everybody, but everybody can help somebody.
driftless is offline   Reply With Quote
Old 10-15-2010, 09:44 AM   #578
Originally Posted by toastie View Post
Thanks Steve,
Thanks, toastie. That'll save me from some errors I'm sure.
Old 10-19-2010, 05:30 PM   #579
toastie's Avatar
1955 22' Safari
Originally Posted by driftless View Post
toastie,
thanks very much.............toastie
Old 10-19-2010, 05:40 PM   #580
toastie's Avatar
1955 22' Safari
Added Bal 24002D 7500lb per jack heavy-duty steel scissor jacks designed for RV's. They bolt on the frame with large lag screws, and can lift the trailer to level if necessary. They tuck up out of sight unless you look directly under the trailer, they do run up and down quickly with a socket on the end of a cordless drill.
I could actually raise the wheel up off the ground using the two jacks on one side convienient for changing a tire.
toastie
ID:	113535   Click image for larger version
Old 10-20-2010, 03:29 PM   #581
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
Thanks Toastie one more thing to spend my money on. I had myself talked out of bal jacks but never thought about the ability to easily change a tire so guess Ill bite the bullet. At least Im a long way from that.
Kevin
kevinb is offline   Reply With Quote
Old 10-20-2010, 05:06 PM   #582
toastie's Avatar
1955 22' Safari
Kevin
No problem Kevinb, Bal jacks are made in America and they are a great product. Camping World had them on sale for $69.00 a pair and I called the local General RV store and they matched the price, no shipping cost.
toastie
Old 10-22-2010, 10:41 AM   #583
toastie's Avatar
1955 22' Safari
Added tank holder, lp regulator and tanks today, going to be a very tight fit on the sway bar controls.......toastie
ID:	113779   Click image for larger version
Old 10-29-2010, 07:37 PM   #584
fastrob's Avatar
1976 25' Tradewind
. , AZ to Maine
Beautiful Work
toastie
It is such a pleasure to see your work.
Thanks.
One noteworthy concern is the ability of those jacks to twist a frame, especially by a enthusiastic newbie with a high torque battery powered driver. My frame was minimally designed and has rusted further, being therefore weak. Just a friendly word of caution from an admirer.
"Talk is cheap, Airstreams are expensive," Wally Byam.
fastrob is offline   Reply With Quote
Old 10-30-2010, 03:21 AM   #585
Baltimore , Maryland
I too would second that notion.
Old 10-30-2010, 05:42 AM   #586
toastie's Avatar
1955 22' Safari
Thanks.
Thanks very much Fastrob for your kind words. The frame between the front and rear scissor jacks seems to be in great shape, in the below pictures you can see that a piece of angle has been added and was surprised that not all 1955's has this piece. I do agree that when leveling, raise very slowly one side, level and stabilize.
toastie
ID:	114193   Click image for larger version
Old 11-09-2010, 05:46 PM   #587
toastie's Avatar
1955 22' Safari
steel wheels, baby moons and tires
Went with new Dexstar black steel wheels, baby moons and new tires. They sold the wheels and baby moons as a set. The tires are Maxxis M8008 225/75/15 E/10 rating.
Chrome Baby Moon Hub Cap
M8008 ST Radial
toastie
Old 11-14-2010, 08:32 PM   #588
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
Just got my 40 lb tanks fitted w/new valves and filled w/gas for 104.00, pretty good deal,but the circular bar the tanks set in is bent so I made need a new set up (for the 64 tw) How do you like yours and where did you get it?
By the way got the bal jacks at camping world like you suggested still on sale for 69.99 a pair plus used a 50.00 gift cert in the mail so 2 pair for 100.00 pretty cool huh? So thanks for the tip on the jacks.
kevin
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
