Old 09-05-2010, 08:17 AM   #561
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
The one I looked up was over 700 bucks, I'll look again
Old 09-07-2010, 05:59 PM   #562
toastie's Avatar
1955 22' Safari
Great Lake State , .
Started working on the cabinets over the weekend.
toastie
ID:	110213   Click image for larger version
toastie is offline   Reply With Quote
Old 09-08-2010, 06:28 PM   #563
toastie's Avatar
1955 22' Safari
Redesigning the shower and going back to my original design of using a removable teak flooring. Lowered the drain by over 2 inches by going with different fittings to make it work, should be much cheaper then going with the stainless steel.
toastie
ID:	110313   Click image for larger version
Old 09-09-2010, 05:28 PM   #564
1973 31' Sovereign
Portland , Oregon
Images: 22
Here is one for $278 that looks pretty nice.
RV Adjustable Table Legs,Gas Powered Pedestals
These folks seem to have a lot of interesting furniture and other accessory items too.
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
Old 09-09-2010, 05:45 PM   #565
fastrob's Avatar
1976 25' Tradewind
. , AZ to Maine
Airstreams Are Not Cheap
I like Toastie's practical approach.
Costs are skyrocketing everywhere, any way to save a few bucks on a very expensive hobby.
$90 vs gas powered, $278 plus shipping and I do not see a starter button to get it running, kick start?
"Talk is cheap, Airstreams are expensive," Wally Byam.
fastrob is offline   Reply With Quote
Old 09-18-2010, 07:10 PM   #566
toastie's Avatar
1955 22' Safari
Started working on the shower walls today. Going with 1/2' birch plywood and using aluminum extrusions from Brunner for the corners.
toastie
PureBond® 1/2 in. x 4 ft. x 8 ft. C-3 Whole Piece Birch Domestic Plywood - 833185 at The Home Depot
http://www.brunnerent.com/Tools/Portfolio/frontend/item.asp?type=9&size=0&lngDisplay=0&jPageNumber=3& strMetaTag=
ID:	111142   Click image for larger version
Old 09-20-2010, 12:15 PM   #567
RankAm's Avatar
1956 22' Flying Cloud
Dallas , Texas
Toastie, what did you use for (and how did you install whatever you used) the curved joint between the shower wall and the interior wall of the coach (in the picture on the left in your post 566)?
Congratulations on the great progress you have made.
RankAm is offline   Reply With Quote
Old 09-20-2010, 04:41 PM   #568
toastie's Avatar
1955 22' Safari
Thanks hjairf....For the inside curve wall I went with Stabilit, .090 in. FRP Wall Panel at $25.00 a sheet, seems to be great stuff, cut's great with saber saw and is very flexible. Come's in a assortment of color's and also end caps, division bar, etc. I used small rivets for the end, what you see in the picture, and large head rivets for the large sheet, I used 6, doesn't take many. It a 2 person job, one just to help steady the piece while you pre drill and rivet. The bathroom/shower will be 60" long. Hope this help.............toastie
Stabilit .090 in. FRP Wall Panel 4 ft. x 8 ft. - White - MFTF12IXA480009600 at The Home Depot
Search Results for frp at The Home Depot
ID:	111312   Click image for larger version
ID:	111314   Click image for larger version
Old 10-02-2010, 05:43 PM   #569
toastie's Avatar
1955 22' Safari
Finished the ruff-in of the shower walls and vanity then disassembled, will finish in the basement over winter and reassemble in the spring. Getting ready to finish compounding then polish the interior.............toastie
ID:	112168   Click image for larger version
Old 10-08-2010, 02:41 PM   #570
toastie's Avatar
1955 22' Safari
Will compound 2 more time, (1) compound with wool pad (2) compound with cyclo with fleece wraps. Then polish with cyclo with fleece wraps...........toastie
ID:	112690   Click image for larger version
Old 10-10-2010, 12:48 PM   #571
toastie's Avatar
1955 22' Safari
Added waste hose carrier today...........toastie
ID:	112795   Click image for larger version
Old 10-10-2010, 02:25 PM   #572
Splitrock's Avatar
Sioux Falls , South Dakota
Looks nice. It's all looking like a first class job.
Gary
Old 10-10-2010, 04:33 PM   #573
toastie's Avatar
1955 22' Safari
Gary
Thanks very much, getting to the fun part now.............toastie
Old 10-10-2010, 04:37 PM   #574
toastie's Avatar
1955 22' Safari
Had a great find on a rare 1947 Spartan door handle..........toastie
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
