Old 09-01-2010, 06:23 PM   #547
toastie's Avatar
1955 22' Safari
Great Lake State , .
This is my "tentative" shower base with shower seat and with plenty of head room. The shower base can be removed and sent to the local metal fabricator for stainless steel but the problem with that is service to the drain after it is installed. Could cause a major problem in the future.
toastie
toastie is offline   Reply With Quote
Old 09-01-2010, 07:23 PM   #548
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
The shower drain will be in front of the toilet, right? And then extend toward the rear to tie into the black pipe sticking up out of the floor behind the toilet in your previous post? Just trying to picture it all in my mind.
Could you have an access panel cut into the front side of the plywood - the side that's toward the center of the trailer? Hard to see if there would be enough room under the floor of the shower to let you get a hand or tool into the shower drain if you ever needed to. Just a thought.
Chris
Old 09-01-2010, 08:15 PM   #549
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
aww gee - no belly-wrap access port with scuttle hatches above to reach the plumbing?
Old 09-01-2010, 09:31 PM   #550
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
I haven't solved this problem in my design yet - what's your solution for the "TP in the shower" problem? My TP either has to be outside the bathroom, or get wet when I shower!
TX-16
Dave Park is offline   Reply With Quote
Old 09-02-2010, 07:31 AM   #551
Maybe a shelf up above the level of the shower head? This has to have been a problem as long as wet baths (or "shoilets" as my friend with a Winnebago calls them) have been around. Surely there are some solutions out there?
Old 09-02-2010, 09:44 AM   #552
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Tupperware?
Marc
Old 09-02-2010, 09:49 AM   #553
Dave Park's Avatar
2005 22' Safari
Well, I was thinking of lining my shower stall with aluminum sheet, then making an aluminum drip cover for the TP holder. But, being temporarily AS-less I don't have a place to try it out.
TX-16
Old 09-03-2010, 07:01 AM   #554
toastie's Avatar
1955 22' Safari
hey Wabbit, yes, I have access thru the belly pan to drain, that's not the problem, the problem is at the gary tank end. Since this tank is only for the shower, and, if I have a problem at that joint, I can drop the whole tank and replace with new without effecting the whole system. If I do have a leak, the floor should never see water.
toastie
Old 09-03-2010, 04:38 PM   #555
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
In the modern version of the "wet bath" where the toilet and shower are one - there is a shower curtain that is pulled across the door and over the wall with the TP to protect both from getting wet. The door specifically to prevent the water from running under the bottom edge. You could cover the toilet to keep it dry but we never do. Never had wet TP in 4 years.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 09-04-2010, 09:56 AM   #556
toastie's Avatar
1955 22' Safari
Built the table top today, the size is, width 32", length 40". I used 1x3's to form a frame support to prevent swaying. Will install formica and then band with 3/4" polished aluminum edging.
toastie
ID:	110021   Click image for larger version
ID:	110023   Click image for larger version
Old 09-04-2010, 02:29 PM   #557
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Tell me about the table leg support with the lever on it.
Old 09-04-2010, 05:33 PM   #558
toastie's Avatar
1955 22' Safari
It's a hydraulic pedestal table base made by Tracy International......toastie
Old 09-04-2010, 07:24 PM   #559
Aerowood's Avatar
Arvada , Colorado
They don't exactly give those away do they
Old 09-05-2010, 05:52 AM   #560
toastie's Avatar
1955 22' Safari
Well almost, check my post #413, $90.00 with free shipping, very high end.
http://www.airforums.com/forums/f36/...-38289-30.html
toastie
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
