Old 08-09-2010, 08:56 PM   #519
toastie's Avatar
1955 22' Safari
Great Lake State , .
Originally Posted by Wabbiteer View Post
Please say you isolated the bright zinc-plated steel receptacle box from the aluminum!
No I didn't, but I can......why?
toastie is offline   Reply With Quote
Old 08-09-2010, 08:59 PM   #520
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
I'm curious, too. Would the same thing apply to the circuit breaker panel inside the camper? I don't recall it being isolated from the aluminum wall either.
www.nesa.org
Air No. 6427
Old 08-09-2010, 10:34 PM   #521
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Zinc to aluminum contact equals a battery, even though the bright zinc coating on that box is very thin it's bad mojo. Once the corrosion starts then the iron chimes in on high humidity days and its belly pan to outrigger magic crystals.
On my 73 its been so long since I gutted it I don't remember where it was hung - but its a painted steel box, not galvanized, and if it were on the liners they were vinyl coated...
Old 08-10-2010, 07:12 AM   #522
Mine wasn't, and there was some small evidence of corrosion, likely from humidity over the years. I repainted my box and reinstalled with neoprene washers separating steel from aluminum, but really I wouldn't have had to, 45 years and the damage was minimal.
Old 08-10-2010, 09:21 AM   #523
nmbosa's Avatar
Nowhere , Washington
My electrical box wasn't painted, but the Zolatone had been sprayed before the box was mounted so it was effectively isolated from the aluminum.
Direct steel to aluminum contact can produce some impressive corrosion. The PO of my trailer mounted a steel bracket to the outside of the trailer. Granted, that was exposed directly to the rain, but when I took it off, I found it had eaten a dime dized hole clear through the skin and had an area of deep corrosion the size of a softball with much of that area reduced to very thin aluminum. I had to patch the entire area.
Toastie - I'd recommend isolating that box from the skin. Electrical tape or even duct tape to the back of it would probably do a lot to reduce the potential for corrosion.
Norm
Norm and Mary
blog: Captain Wilson's Overlander
nmbosa is offline   Reply With Quote
Old 08-10-2010, 11:19 AM   #524
Baltimore , Maryland
my rule of thumb: NO STEEL TOUCHES ALUMINUM.
Old 08-11-2010, 08:41 PM   #525
toastie's Avatar
1955 22' Safari
This is my very detailed shower plan...........toastie
Old 08-12-2010, 07:35 AM   #526
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
I was thinking about the junction box corrosion issue...Could you use a plastic junction box? I would think that should eliminate any possibility of corrosion. Just thinking outloud.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 08-12-2010, 08:07 AM   #527
Wabbiteer's Avatar
1972 29' Ambassador
Plastic box... I'd hesitate on that since the condition of the external plug and socket at some point in the future could lead to a bad connection and high-temperatures, but a gasket between the two metals, even painting the box, would have a good return on the effort.
Old 08-12-2010, 10:36 PM   #528
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
Household plastic boxes are flame retardant and required to handle temps above where the insulation burns. Personally, in a vibrating environment where wires can come loose, I'd have a tough time deciding if I wanted an insulated box, or a metal one that will probably trip a breaker if contacted, but might not.
What does code say?
TX-16
Dave Park is offline   Reply With Quote
Old 08-14-2010, 09:52 AM   #529
toastie's Avatar
1955 22' Safari
Installed my fresh water fill today, and decided to go stealth. Didn't what to cut another exterior hole plus my fresh water supply will be behind a locked door.
toastie
ID:	108736   Click image for larger version
Old 08-14-2010, 11:54 AM   #530
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Very nice! Bonus - you can see exactly how full the tank is getting!
Old 08-14-2010, 08:28 PM   #531
toastie's Avatar
1955 22' Safari
Started to permanently install the AC today. The new drilled hole to AC is directly over a larger hole going thru the belly pan. The drip pan in line with aluminum and I used plenty trempro 635.
ID:	108773   Click image for larger version
ID:	108775   Click image for larger version
Old 08-15-2010, 02:02 PM   #532
toastie's Avatar
1955 22' Safari
Finished the install on the AC today.........toastie
ID:	108823   Click image for larger version
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 12:11 PM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 06:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 01:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 02:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 07:26 AM
