Old 07-26-2010, 04:28 PM   #505
toastie's Avatar
1955 22' Safari
Great Lake State , .
Originally Posted by Jabba View Post
Very well thought out installation. I really like how you are hiding the vent behind the license plate, neat. Are you going to mount the unit on rubber washers to help isolate it further or doesn't it seem to telegraph thru the floor?
Thanks very much, very happy with the installation. Will go back and fine tune to bring the noise down, Dave Park came up with some great ideas also. The noise level according to Frigidare at high is 54.8 dB, seem to be a lot less noise then the roof top on my 65 Caravel.
toastie
toastie is offline   Reply With Quote
Old 07-27-2010, 05:48 PM   #506
toastie's Avatar
1955 22' Safari
Removed side louvres and did a test run and it did reduce the noise level. Also drilled a drain hole and ajusted the side duct work.
toastie
ID:	107610   Click image for larger version
Old 07-28-2010, 12:54 AM   #507
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
Excellent!
I have done that on a window unit before, and it increased the airflow too, so the unit also ran a little less and drew a little less current.
It's also nice that not having the A/C on the roof lowers the center of gravity a little more.
I am thinking of doing something similar with my next project, but near the wheel cover. I'll credit you then
TX-16
Dave Park is offline   Reply With Quote
Old 08-08-2010, 08:54 AM   #508
toastie's Avatar
1955 22' Safari
Started working on the shower today and below pictures show my final drain setup to gray water tank, going with HepVo waterless trap and a touch-toe stopper kit. I have 2 gray water tanks, one will be used for the shower only.
Hepvo Waterless Valve
toastie
ID:	108319   Click image for larger version
Old 08-08-2010, 11:06 AM   #509
Dave Park's Avatar
2005 22' Safari
Is the elevation of the shower pan vital to you? Can you shave 1" off the stopper assembly to lower from 4.5" to 3.5"?
TX-16
Old 08-08-2010, 03:48 PM   #510
toastie's Avatar
1955 22' Safari
No need to lower, will be using 2 X 6 for the shower base. There will be a removal panel for service.
toastie
Old 08-08-2010, 03:53 PM   #511
Dave Park's Avatar
2005 22' Safari
With the floor of the pan elevated 6" will you have comfortable headroom? Just making sure...
Nothing worse than getting it all in, then going for a shower and bonking your head on the side wall.
TX-16
Old 08-08-2010, 04:20 PM   #512
1969 27' Overlander
Adel , Iowa
Originally Posted by toastie View Post
Starting to compound the inside, this will be the first cut, will replace all rivets with olympic rivets, then shave then to look like the rivets to the 13 panels, than compound second cut.............
OK.. What are Olympic rivets and where do you get them?
airstrmkids is offline   Reply With Quote
Old 08-08-2010, 04:27 PM   #513
Dave Park's Avatar
2005 22' Safari
Normally, riveters have access to both sides of the piece, and use buck rivets. If access is only from one side, you would use a pop rivet, which is left with an unattractive hole. Of more concern to an airstreamer, it lets water in.
Olympic rivets are a special type of pop rivet that leaves the center aluminum shaft in place when popped. This shaft can then be shaved down, so the rivet then appears to be a standard buck rivet.
TX-16
Old 08-08-2010, 04:45 PM   #514
toastie's Avatar
1955 22' Safari
Hope this helps..........toastie
Olympic Rivets
Old 08-09-2010, 04:04 PM   #515
toastie's Avatar
1955 22' Safari
Marinco power Inlet is a good product on the outside, but hooking the wires up on the inside is a pain, very poor design. This is how I handled mine.
toastie
ID:	108446   Click image for larger version
Old 08-09-2010, 06:44 PM   #516
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Ah, we just installed one of those. Haven't hooked it up yet. Thanks for the info, Toastie. That will come in handy (someday).
Kay
Old 08-09-2010, 07:34 PM   #517
toastie's Avatar
1955 22' Safari
Kay
Thanks very much Minno, got the idea from markdoane, http://www.airforums.com/forums/f449/marinco-electrical-connection-58288.html#post769103 . What I know today it would be a very simple installation to install wire's to the Marinco then fasten Marinco to trailer, the set screws are perpendicular to the wire inputs.
Old 08-09-2010, 07:48 PM   #518
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Please say you isolated the bright zinc-plated steel receptacle box from the aluminum!
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
