Old 06-13-2010, 06:05 AM   #477
toastie's Avatar
1955 22' Safari
Great Lake State , .
Originally Posted by 62overlander View Post
Toastie, you are all about stealth when adding the modern into the vintage... I have been told that the original Herh cover fits over the fantastic cover. I have not tried it yet, but saw it on this forum.
Frank
The central air will be a challenge. Yes, the old Hehr cover will fit over the Fantastic cover, but in my case will just add a good coat of wax to the Fantastic cover every year. To keep that old Hehr cover looking good would require compounding and I just don't know if the Fantastic can handle the torque from the compounding.
http://www.airforums.com/forums/f91/...tml#post364550
Fantastic Hehr Vent- How To - Photo Gallery
toastie
toastie is offline   Reply With Quote
Old 06-13-2010, 11:50 AM   #478
toastie's Avatar
1955 22' Safari
Painted the floor and will finish putting the rest of the interior panels up, polish to mirror finish, then a second coat of paint.
toastie
ID:	104758   Click image for larger version
Old 06-13-2010, 03:52 PM   #479
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
Originally Posted by toastie View Post
.......interior panels up, polish to mirror finish.....
toastie
You going into the traveling tanning bed business?
FC7039 is offline   Reply With Quote
Old 06-13-2010, 05:35 PM   #480
toastie's Avatar
1955 22' Safari
WOW...thats a great idea, twin tanning beds...............
Old 06-13-2010, 05:38 PM   #481
toastie's Avatar
1955 22' Safari
Gave the vent a good compounding today, wish I could find another.........
toastie
Old 06-13-2010, 08:31 PM   #482
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
You have an illness that is yet to be documented. It may become infectious to others. I'm going out to my trailer to clean something............
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 06-15-2010, 04:15 PM   #483
toastie's Avatar
1955 22' Safari
My AC came today, it a Frigidaire Window-Mounted Slider / Casement Air Conditioner Model: FAK085R7V 14-3/16" W x 20-1/4" H x 24-1/2" D, 8,000 btu, Amps (Cool): 7.2. My plan is to turn it into a central air unit, if it doesn't work, I'm out $329.00 and no AC, putting on roof top air is not a option.
toastie
ID:	104897   Click image for larger version
Old 06-15-2010, 05:32 PM   #484
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Frigidaire Window-Mounted Slider / Casement Air Conditioner... My plan is to turn it into a central air unit
Are you planning to set it up to work like a slide-out? (projecting from the side of the trailer when parked and flush when traveling)
...or flush with a plenum for ventilating the compressor?
One nice thing about this unit is that you should be able to power it with one 2000 watt generator.
I can't wait to see how you work it out.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 06-15-2010, 05:58 PM   #485
pbearsailor's Avatar
Port Hadlock , Washington
toastie
Don't remember it looking that good the last time I saw it.
-steve
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 06-16-2010, 07:55 PM   #486
toastie's Avatar
1955 22' Safari
Here's a picture showing the front of AC with panel off. There's a fans in the unit that draws the warm air from inside the trailer over the evaporator coils than out as cold air. The evaporator coils have 132.25 sq. inches of area and the cold air going out is 45.0 sq. inches. I plan to run the cold air thru 3 tubes, 1 to the back 1 in the middle and 1 in the front of trailer. Each tube being 4" dia with 12.6 sq. inches, 3 x 12.6 sq inches = 37.8 sq inches.
toastie
Old 06-19-2010, 04:40 AM   #487
toastie's Avatar
1955 22' Safari
In the below picture, the rectangle will become the plenum, 45.0 sq. inches. The circle's represent the 3 tubes, 4 inches in dia. 37.8 sq inches. Hoping to go with only 2, if not, will go the 3. The tube's will consist of Master Flow 4 In. Metalized R6 Insulated Flexible Duct from home depot.
http://www.homedepot.com/Building-Materials-Heating-Venting-Cooling-Ducts/h_d1/N-5yc1vZ1xjzZapyp/R-100396934/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
toastie
Old 06-19-2010, 08:07 AM   #488
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
The roof mounted A/C has one big advantage - the hot air rises (plus displaced by heavier cool air upwards) to meet the intake...
If you could have a 'thick' partition (hollow) bring the hottest air up near the ceiling into the unit I believe you would really have a good start!
Old 06-19-2010, 09:37 AM   #489
toastie's Avatar
1955 22' Safari
Wabbiteer
Was planning on using the center FanTastic fan from http://www.vintagetrailersupply.com/Fan_Tastic_Fan_p/vts-414.htm
to take the hot air out, or a very small fan inside to mix the hot
and cold together, like a ceiling paddle in a home.
toastie
Old 06-19-2010, 10:24 AM   #490
toastie's Avatar
1955 22' Safari
Started putting seals to the door today and what a pain, the pain is finding seals that will work to a door that will not go back the way it was. Plan to attach a seal to the door as show in the pictures then another seal to the door frame, then another seal to the outter flange of door, and if that works will seal the inner door. These type of doors are very cool, but have leaks written all over them.
toastie
ID:	105187   Click image for larger version
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
