Old 05-31-2010, 11:21 AM   #463
pbearsailor's Avatar
Port Hadlock , Washington
When you have a belly pan that looks that good, you really should have a way of turning the trailer over, so people can see it.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 06-03-2010, 11:56 AM   #464
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Originally Posted by toastie View Post
I used 5052 0.04" on all of the belly pan, will go with 0.032 on the next restoration.
Looks great!
What made you decide on .040"? My understanding is that .025" is the stuff to use for belly pan material.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 06-03-2010, 03:35 PM   #465
toastie's Avatar
1955 22' Safari
Great Lake State , .
Originally Posted by byamcaravanner View Post
Looks great!
Thanks, the suppler is very close to the house and all he had was 0.040 at a good price. 5052-H32 has the highest strength in the NON-heatable alloys, has higher fatigue strength than most alloys, excellent corrosion resistance, and has excellent workability.
toastie
toastie is offline   Reply With Quote
Old 06-03-2010, 03:38 PM   #466
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
My .040 choice was sealed by 60 inch widths...
Old 06-06-2010, 06:47 AM   #467
toastie's Avatar
1955 22' Safari
Originally Posted by malconium View Post
That is a very interesting approach to mounting your water heater. I hope the exhaust isn't hot enough to melt the paint on your license plate. Will you be mounting it a little away from the body?
Malcolm
Malcolm
Since my hot water operates on both gas or electricity and after talking to friends that have the same heater decided to go only electric.
toastie
Old 06-07-2010, 08:23 PM   #468
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
Finished the belly pan today except for around the tanks, that will be the very last thing that I do, probably will do some local camping before closing off to test for leaks. I used 5052 0.04" on all of the belly pan, will go with 0.032 on the next restoration.
toastie
Excellent work!!! Did you make those end belly wraps using the originals as templates or free hand from scratch? I am going to need to make new end belly wraps fr my '55 Safari and don't have complete pieces to work from as templates. It is a bit intimidating, but if you got those that nice without templates I will be more encouraged that I can do something almost as nice.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 06-08-2010, 06:29 PM   #469
toastie's Avatar
1955 22' Safari
Thanks Joe, yes, I used the old templates as a very rough guide, highly recommend electrical shears as shown in the below picture for fine tuning cuts.
14 Gauge Swivel Head Shears
toastie
ID:	104462   Click image for larger version
Old 06-08-2010, 07:33 PM   #470
1962 22' Safari
2016 30' Classic
Images: 41
I am hoping to get ready to start replacing exterior panels and bellypan on my '55 Safari during our July shutdown. I might be interested in borrowing your "templates" if they have not been thrown away (not sure how usable the remaining pieces on my trailer might be). I might also like to talk to you about how you did your bellypan replacement. I can't remember - did you also replace some exterior skins? If so, I might like to talk to you about that too.
Great work!
Joe
WBCCI/VAC #6768
Old 06-08-2010, 08:30 PM   #471
toastie's Avatar
1955 22' Safari
Great work!
Sorry Joe but all of the old belly pan has been trashed, not replacing any of the outside panels.
toastie
Old 06-12-2010, 08:36 AM   #472
toastie's Avatar
1955 22' Safari
FanTastic fan
Replaced the front Hehr vent with a new FanTastic fan from http://www.vintagetrailersupply.com/Fan_Tastic_Fan_p/vts-414.htm and from a distance you can't tell the difference. The 55 year old sealant was in very bad shape, had to be a source of leaks, will be replacing the other 2 vents.
toastie
ID:	104684   Click image for larger version
Old 06-12-2010, 08:42 AM   #473
Baltimore , Maryland
Toastie, you are all about stealth when adding the modern into the vintage... I have been told that the original Herh cover fits over the fantastic cover. I have not tried it yet, but saw it on this forum.
Old 06-12-2010, 08:48 AM   #474
It's easy.
Old 06-13-2010, 03:17 AM   #475
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
toastie
Looks good.
I'm about to do the same and have read install threads where they used the closed cell foam gasket that came with the fan and threads that say they didn't (and shouldn't) (and of course the factory says you should). What was your method?
MarkR
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 06-13-2010, 04:39 AM   #476
toastie's Avatar
1955 22' Safari
Originally Posted by MarkR View Post
Looks good.
MarkR
Thanks MarkR
I saw no need to use the foam or there screws, used Olympic Bulb-Tite Rivets. I was very liberal with the trempro 635, used paint thinner to clean up the excess trempro.
toastie
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
