Old 03-16-2010, 08:35 PM   #421
toastie's Avatar
1955 22' Safari
Great Lake State , .
Hooked up the inteli-power and 12v system and everything seems to work, the battery was showing 13.42 volts. This is just a temp hook-up, will be going with battery box that meets RVIA code...........toastie
ID:	98233   Click image for larger version
toastie is offline   Reply With Quote
Old 03-27-2010, 06:52 AM   #422
toastie's Avatar
1955 22' Safari
I original bought a 30 gal fresh water tank and because of room and usage decided to go with this 10 gal tank (ROTONICS WATER TANK) Will also be going with a high volume pressure systems which will give me a total of 11 gals. The tank will be place so that it can be easily removed for winterizing and sanitizing...............toastie
ID:	98857   Click image for larger version
Old 03-28-2010, 07:02 PM   #423
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
Toastie,
That Rotonics setup looks great! Where did you come up with it? It looks like something that could work in my '55 Safari in the original location under the dinette bench. What are the dimensions? Does the pump come with it? And if you don't mind my asking, how much was it?
Thanks in advance for the answers.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 03-28-2010, 07:15 PM   #424
toastie's Avatar
1955 22' Safari
Originally Posted by 66Overlander View Post
Toastie,
10 Gallon Water Tank : eBay Motors (item 260574058614 end time Apr-22-10 07:20:58 PDT)
The pump is extra, did you get your trailer moved.....
Old 03-28-2010, 10:42 PM   #425
1962 22' Safari
2016 30' Classic
Images: 41
That eBay tank does not look like the one in your photo.
As for the Safari, it came home on Saturday. I just posted this to my thread: http://www.airforums.com/forums/f338...tml#post830729
Joe
WBCCI/VAC #6768
Old 04-01-2010, 06:33 AM   #426
toastie's Avatar
1955 22' Safari
Found this picture of what looks like a very slick homemade battery box with a vent that would meets RVIA code. Open for comments.............toastie
Old 04-01-2010, 11:14 AM   #427
toastie's Avatar
1955 22' Safari
Decided to go with a Suburban SW6DE. This water heater will operate on both gas or electricity and has electronic ignition. Will be modifying the back door and door frame just a little to make it work...........toastie
ID:	99214   Click image for larger version
Old 04-10-2010, 06:49 PM   #428
toastie's Avatar
1955 22' Safari
Had a ruff time with my running lights and turn signal last week and determine that I had a grounding problem. After reading and talking to some friends that own trailer business and a frame that has 3 coats of paint decided decided to go this way. Ran a ground right to tongue, tongue to a grounding bar, bargman cable ground to grounding bar, electric brakes and battery to grounding bar, complete design control. Everything is working perfect..........toastie
ID:	99991   Click image for larger version
Old 04-10-2010, 06:51 PM   #429
Good call. If I were planning on redoing my 12V electrical, I'd run everything to a separate grounding bus bar as well.
Old 04-10-2010, 06:56 PM   #430
toastie's Avatar
1955 22' Safari
Once the interior panels are in place, will attach grounding bar to panel
toastie
Old 04-11-2010, 07:21 AM   #431
toastie's Avatar
1955 22' Safari
Here's a wiring diagram that matches the bargman 7 way cable.......toastie
Old 04-14-2010, 05:23 AM   #432
Baltimore , Maryland
Toastie, sorry to dilute your thread with my personal question, but where did you buy your marinco power inlet? I seem to recall you got a very good price on it. Would you mind letting me in on the source?
Old 04-14-2010, 06:47 PM   #433
toastie's Avatar
1955 22' Safari
Your question's and advice is always welcomed here. Those where Marinco TV/Phone and where $28.00 with free shipping, they normal go for over $80.00 plus shipping..........toastie
Old 04-18-2010, 05:37 PM   #434
toastie's Avatar
1955 22' Safari
Starting to put the interior panels in............toatie
ID:	100581   Click image for larger version
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
