Old 03-18-2008, 05:49 PM   #29
toastie's Avatar
1955 22' Safari
Great Lake State , .
door back together
Been working on the door down in the basement this winter and
starting to put it back together, very easy to compound when door is
disassembled. Have parts out to the chromer, hope to finish soon.............
ID:	56490   Click image for larger version
toastie is offline   Reply With Quote
Old 03-18-2008, 05:57 PM   #30
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I think we are running parallel projects! I posted an update this week (starting at #168) on all our winter projects too. Looking at yours, I got confused and thought I was looking at my pictures - door, hardware, accessories, frame...except for the shiny interior!
Looks good!
Shari
Old 03-24-2008, 10:40 AM   #31
toastie's Avatar
1955 22' Safari
drip cap
Fabricated a new drip cap, took the old drip cap and flatted it out with a rubber mallet, traced it on to a piece of 2024-T3 aluminum. Using a metal brake, bent edge and the part that fasten to the trailer was done by hand.
Then very slowly form to shape using my leg.
ID:	56832   Click image for larger version
Old 03-30-2008, 04:45 PM   #32
toastie's Avatar
1955 22' Safari
Getting ready to install my first completed window and a few of the new running lights...............
Old 03-30-2008, 06:20 PM   #33
drag'nwagon's Avatar
1970 23' Safari
1956 26' Cruiser Overlander
Lambertville , Michigan
Looking great Toastie!!
Dave
TAC# MI-1
Operation "Save Rudy" Strike Team (charter member)
Yes, I am still working on it.
drag'nwagon is offline   Reply With Quote
Old 03-30-2008, 06:54 PM   #34
toastie's Avatar
1955 22' Safari
Thanks Dave, I see that your from Michigan and you also have a full restoration going. Are you planning on going to T.C.T rally in May...........
Old 04-13-2008, 06:45 AM   #35
toastie's Avatar
1955 22' Safari
Replacing back tail lights
Replacing the tail light back to Bargman No.9 Trim Rings, bought the trim rings from Vintage Trailer Supply - Vintage travel trailer parts and supplies! with No. 6 lens also from vintage trailers. Found the housing from
Tractor Supply Company - Combination Stop/Tail/Turn Light which is a perfect fit.
ID:	58089   Click image for larger version
ID:	58091   Click image for larger version
Old 04-18-2008, 04:31 PM   #36
toastie's Avatar
1955 22' Safari
frame repair
My frame is in good shape except for one hole, took (2) 2"x2"x36" angle iron
and weld just under the hole, according to the expert's should be good to go. Removed the old short angle iron shown on the outside, and added new longer for additional support. Will be painting the frame with por-15 then will start the flooring. Decided to go with 5/8" AC plywood, with this restoration weight is a concern, plus the frame flexes very much and didn't want to make it to ridged. Also I plan no insulation under the floor, 3 of the cells will have tanks, black and 2 gray's, so there is no room for the insulation in those cells, and once water does get to the insulation could cause other problems.
ID:	58585   Click image for larger version
Old 04-21-2008, 11:54 AM   #37
toastie's Avatar
1955 22' Safari
POR 15 is a remarkable product
POR 15 is a remarkable product, its going to take about 1 gallon (using 1 quart cans) to complete the job and that is with 2 coats..............
Old 04-22-2008, 06:35 PM   #38
1970 23' Safari
Actually Toastie we met once at the LPPI a couple years ago. My restoration project is going well and I will be pulling it home in the next couple weeks. My family and I will be at the TCT May rally, but with our 74. I look forward to talking with you particularly about electrical.
Dave
TAC# MI-1
Old 04-27-2008, 04:54 PM   #39
toastie's Avatar
1955 22' Safari
marinco
Installed a Marinco 30 amp inlet today, part number 304EL-B, 30SSEL-B, to fasten, I used Olympic rivets, compressed the gasket perfectly.
ID:	59122   Click image for larger version
Old 04-27-2008, 06:13 PM   #40
Baltimore , Maryland
I want to say I am beyond impressed....
Old 04-27-2008, 06:16 PM   #41
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Nicely done..... Great thread.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 05-01-2008, 02:56 PM   #42
1970 23' Safari
Toastie,
I love the Marinco install, I was considering the same one for our '56. Did you have to open the hole up for it?
Dave
TAC# MI-1
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
