Old 12-15-2009, 06:58 PM   #393
toastie's Avatar
1955 22' Safari
Great Lake State , .
Originally Posted by FC7039 View Post
Would you not need a vent to relieve the build up of gas? If the the tank is "sealed", then I would think back pressure would interfere with the one way valve.
Found this on YouTube, a couple of guys tested the backflow resistance of the valve. Perhaps you can visualize that as the backpressure increases it places more force on the membrane to remain closed. That is, as demonstrated in the YouTube video, until the backpressure becomes sufficient to force the entire membrane to reverse itself.
YouTube - Fanny trap tested to destruction
toastie is offline   Reply With Quote
Old 12-15-2009, 08:12 PM   #394
Images: 59
I have the same concern about backpressure. If you have a sealed tank with no external vent, then any fermentation in the gray water tank would exert backpressure on the downstream side of the valve and prevent free drainage of the shower.
A few inches of backpressure on the tank side of the valve could cause a few inches of backup in the shower.
Not a problem if you also have a regular tank vent. Or if you keep the pH of the graywater high enough to prevent fermentation.
Otherwise, might be a problem.
Old 12-16-2009, 04:02 PM   #395
toastie's Avatar
1955 22' Safari
All of my tanks will be vented to the atmosphere, the shower will have its own gray water tank. The reason that I going with the Hepvo is space, I'm micro managing the space.
toastie
Old 12-16-2009, 08:43 PM   #396
Bothell , Washington
re-build
toaste, i have read all your post tonite. wow, that is all good stuff. way to go. your AS will be better then new and better then the new ones. AS should take notice. anyways, great job, great post, very interesting. thanks, can't wait to see the finnish of this.
Outlaw
Outlaw is offline   Reply With Quote
Old 12-16-2009, 10:19 PM   #397
1973 31' Sovereign
Portland , Oregon
Images: 22
I was thinking some more about this and I think that you are right about still needing to vent the tanks.
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
Old 12-22-2009, 11:03 AM   #398
toastie's Avatar
1955 22' Safari
Thinking about running the sewer hose through the sewer hose holder kit, then, permantanly fastening the hose to dump valve and design it that the kit can pivot. Any other ideas out there with pictures?????
toastie
ID:	92852   Click image for larger version
Old 12-22-2009, 11:29 AM   #399
memgrove2000's Avatar
Elkhart , Indiana
Send a message via AIM to memgrove2000
http://
Mike
Have a great day!
TAC # IN 1 Air#27922
memgrove2000 is offline   Reply With Quote
Old 12-22-2009, 11:57 AM   #400
toastie's Avatar
1955 22' Safari
Mike
That's is a great idea, I knew that there had to be something out there in this multi billion dollar rv business, thanks for sharing.
toastie
Old 12-22-2009, 04:27 PM   #401
Elkhart , Indiana
And now for the disclaimer: I have only seen this on you tube. I do not own one or sell them. I just remember seeing the video a while back and your post reminded me of it. That being said I would want to hold one and fidget with it before purchasing. I think that they may hang too low for safe travel. I think if it were me I would find a way to "wrap" it in aluminum so it would match the rest of the trailer.
Mike
Have a great day!
Old 12-22-2009, 06:55 PM   #402
toastie's Avatar
1955 22' Safari
After watching a few of there videos on the web I noticed that they
are using double o'rings which would make for a poor design.
O'rings are normal used on stationary parts, not on parts
that rotate and telescoping.
toastie
Old 12-22-2009, 07:50 PM   #403
toastie's Avatar
1955 22' Safari
Here is another design that I found on the web. Leaning toward this design, cheaper.........
toastie
ID:	92889   Click image for larger version
Old 12-22-2009, 08:04 PM   #404
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
That's brilliant!! Very easy modification, easy to undo later... I like that. Would work well on early 60's tanks that dump straight down out the floor
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 12-22-2009, 08:11 PM   #405
toastie's Avatar
1955 22' Safari
Plus the hose should give you plenty of flexibility for pivoting.
Old 12-23-2009, 05:39 AM   #406
Baltimore , Maryland
I suggest your keep that stinky slinky outside of the trailer though. They do wear out and a split in the hose might not be too pleasant inside the rig.
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
