Old 11-16-2009, 06:53 AM   #379
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Wow. I'm impressed!
Chris
Old 11-16-2009, 07:23 AM   #380
toastie's Avatar
1955 22' Safari
Great Lake State , .
Originally Posted by Minno View Post
Wow. I'm impressed!
Chris
So was I, will post more pic's in the spring. The other challenge will be the LP/ELEC. hot water tank, suburban LP or 110 volt electric hot water system Suburban RV Water Heaters on Sale. The challenge will be to vent the LP side without cutting a large square hole.
toastie
toastie is offline   Reply With Quote
Old 11-21-2009, 10:27 AM   #381
toastie's Avatar
1955 22' Safari
Working on putting the front trim piece on today. I learned a little trick, you can see the gap in the picture, what I did was to take the palm of my hand and layed it on top of the gap and then slowly, very slowly bend the piece back to take the gap out, then slowly worked myself around with the trim piece.
toastie
ID:	91345   Click image for larger version
ID:	91347   Click image for larger version
Old 11-21-2009, 11:39 AM   #382
Minno's Avatar
1972 31' Sovereign
Is that new trim pieces? Inquiring minds and all that.....
Old 11-21-2009, 05:53 PM   #383
toastie's Avatar
1955 22' Safari
No, its original...........toastie
Old 11-22-2009, 04:27 PM   #384
toastie's Avatar
1955 22' Safari
Before permanently setting the front trim piece, added Trempro 635 to the outside and after setting the trim piece sealed the inside.
toastie
ID:	91392   Click image for larger version
Old 11-22-2009, 05:26 PM   #385
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Looking great Toastie
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 11-22-2009, 05:33 PM   #386
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
thats a great idea to stop water at each layer. I was surprised how many seams on ours weren't factory sealed (which I think led to most of the floor rot). Every horizontal, overlapped seam was not sealed, only end cap and verticle seams. Every one of them leaked. Made panel replacement easier (man that black stuff is hard to remove) though. Boy your belt trim is in great shape.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 12-12-2009, 09:19 AM   #387
toastie's Avatar
1955 22' Safari
Decided to go with a inline Hygienic Self Sealing Waste Valves, has been approved for RV use in the US since early 2007. Dry sealing valve prevents the escape of odors from your waste system into your RV and eliminates the need for check vents. Can be used in a vertical application as well as horizontal. A couple of Class A builders are using them under kitchen sinks to allow for drawers below the sink.
toastie
Old 12-12-2009, 11:44 AM   #388
toastie's Avatar
1955 22' Safari
More info on the Hygienic Self Sealing Waste Valves
Hepworth New Zealand -- HepVo -- Introduction
http://www.hepworth.co.nz/HepVo_NZ.pdf
HEPvO waterless trap install - The Casita Club Forums
Google Image Result for http://www.ascinfo.co.uk/9/resourcefile/08/15/85/HepvOInstallation.jpg
Hepvo Hygienic Self Sealing Waste Valves
toastie
Old 12-12-2009, 12:18 PM   #389
toastie's Avatar
1955 22' Safari
A valvectomy, notice that the ribs must be down in a horizontal ass'y,
Shower, 3rd drain valve mod, valvectomy - a set on Flickr
Old 12-12-2009, 02:40 PM   #390
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
help to see pics
I really want to see some of your Pictures....from the 2008 range...on the door and windows. I get blank pages...GEF.2x2... Not JPEG. On the later pics that are JPEG it comes thru. Have we got a computer whizz available? Can I get these to show? I think your work is super and I'd like to use it as a guide in my next project.
Old 12-15-2009, 04:34 PM   #391
1973 31' Sovereign
Portland , Oregon
Images: 22
No vents needed?
These dry valves look pretty interesting and I am at the stage in my remodel where I am just about to re-plumb my entire drain system. I have a couple of questions about these valves as follows:
I can see that using these dry valves would eliminate the need for p-traps on the shower and the sinks in the kitchen and bath. I can also see that it eliminates the need for vents on the drains themselves. Is the need for additional venting on the gray water tank then completely eliminated?
Presumably I still need a vent on my black water tank since there is no p-trap on the toilet that I can replace with one of these gadgets. Is that a given?
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
Old 12-15-2009, 05:31 PM   #392
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
Tums
Would you not need a vent to relieve the build up of gas? If the the tank is "sealed", then I would think back pressure would interfere with the one way valve.
FC7039 is offline   Reply With Quote
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
