Old 10-21-2009, 05:02 AM   #323
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
Cape Coral , Florida
You definetely want to use rubber grommets. Having a wire short out inside the wall is not a good thing. You might consider McMaster Carr. You can get a bag of 25 for $10 or $11 rather than the unit price at the nearest big box store. While you are shopping, I found a step drill to be very useful.
dieseleagle is offline   Reply With Quote
Old 10-22-2009, 04:31 AM   #324
toastie's Avatar
1955 22' Safari
Great Lake State , .
What size did you use for the 12 gauage romex.......thanks vey much
toastie is offline   Reply With Quote
Old 10-22-2009, 05:09 AM   #325
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
I used a combination of 5/8 ID and 3/4 ID. The smaller for one run, the larger for those places where I ran 2 or 3 through the same hole.
Old 10-22-2009, 08:28 AM   #326
RankAm's Avatar
1956 22' Flying Cloud
Dallas , Texas
Any thoughts on how many grommets would be needed for a complete rewire (of a 56 22 foot Flying Cloud)?
Hank
RankAm is offline   Reply With Quote
Old 10-22-2009, 08:43 AM   #327
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Another though would be NOT running the AC wire with the DC wire together on the same runs, or tied together. keep them separated. This will minimize the "Noise" in the DC runs. Also do not ground the AC and DC on the same grounding studs
Kip
Old 10-22-2009, 04:07 PM   #328
toastie's Avatar
1955 22' Safari
Hank
I don't have a clue, but I did order 40 from McMaster Carr today.
toastie
Old 10-22-2009, 04:43 PM   #329
toastie's Avatar
1955 22' Safari
Kip
Will separate the wires......thanks
Old 10-23-2009, 06:16 PM   #330
toastie's Avatar
1955 22' Safari
All lighting will be LED Puck and LED Rope except for one antique table lamp. The Puck Lights draw only 65mA that's approximately 1/2 the power of a single incandescent automotive type bulb.
ID:	89594   Click image for larger version
Old 10-24-2009, 09:56 AM   #331
Aerowood's Avatar
Arvada , Colorado
Toastie
Where did you get the puck lights at, and if you don't mind how much $$$$ for each?
Kip
Old 10-24-2009, 10:09 AM   #332
toastie's Avatar
1955 22' Safari
Toastie
Kip
Kip
Bought them at 12V Warm White LED Puck Light
toastie
Old 10-24-2009, 01:18 PM   #333
toastie's Avatar
1955 22' Safari
This is my wiring plan, all comments are welcome.
Wire 5 will be for the main
Wire 4 to the 20 amp, will be only for air conditioner
Wire 3 to the 15 amp, will be only for Intellipower; will be pluged into a GFI receptacle.
Wire 2 to 15 amp GFCI will be only for microwave and refrigerator.
Wire 1 to 20 amp GFCI will be all exterior and interior receptacles and switches.
Old 10-24-2009, 08:50 PM   #334
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
I wouldn't put all interior and exterior receptacles and switches on one circuit breaker. If you should happen to have a short on that circuit, you would lose all usable power in the trailer. Plus all on one it would be easier to overload and trip the breaker accidentally. I'd prefer two 15A circuit breakers staggered around the trailer so you would still have some power if you lost one circuit. Make them both 20A's if you are concerned about plugging in some large load like a 200W inverter.
Unless you are planning to include a 1500W microwave, you may not need to dedicate a circuit breaker to it and could share it with some receptacles and switches to keep from having to go to a 6 breaker box.
And regarding the microwave circuit breaker, I assume the fridge you would be sharing with it would be a 2-way (LP and AC only) with the 12V feed low current only for the circuit board. If you intend a 3-way that could be run entirely off 12V, you'd want to add a switch so that only the fridge or only the microwave could be powered at one time to keep you from blowing the circuit breaker when both were on simultaneously.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 10-25-2009, 05:15 AM   #335
toastie's Avatar
1955 22' Safari
Joe
Our fridge is a 3-way and we haven't picked out a microwave yet but
need to plan for a 1500W. Looks like I need to separate the fridge from
the microwave. If I replace the 15 amp GFCI with (2) 15 amp breakers, one
for the fridge and one for the microwave and have them plug into a gfi receptacle
Toastie
Old 10-25-2009, 11:03 AM   #336
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Originally Posted by toastie View Post
...Our fridge is a 3-way and we haven't picked out a microwave yet but need to plan for a 1500W. Looks like I need to separate the fridge from the microwave...
When's the last time you checked the 115V power needs of the fridge? Last time I looked at my 30-yr old model in the Overlander it was 125 watts, or about 1 amp. I don't think you need to put it on a separate circuit. Your microwave, even if a big one, is probably less than 1200 Watts. Theoretically, a 15-amp breaker can supply 1700+ Watts.
I think three 115V circuits are sufficent--one for the A/C and the other two to split circuits, just in case you have a breaker failure that you can't repair immediately or if you use multiple ceramic heaters in the winter. You're hard pressed in an Airstream to use enough 115V power to blow a breaker, unless you've rooted yourself permanently into a park and are using power tools with abandon. The common exception, of course, is the dreaded 1500W hair dryer, so your bath outlet needs to be on the other circuit from the microwave. If you're using more than one ceramic heater, you need to split them, too.
Zep
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
