Old 09-20-2009, 04:37 AM   #295
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Originally Posted by toastie View Post
Stainless 7 Terminal Wiring Junction Box for the Bargman, all hardware is stainless, what a slick system.........
Don't keep us in suspense... where did you get it?
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 09-20-2009, 05:35 PM   #296
toastie's Avatar
1955 22' Safari
Great Lake State , .
Steve & the crew
Just got back for the fall T.C.T. rally, what a great time.
I bought mine of e-bay with free shipping. Make sure that you get the stainless steel.
Stainless 7 Terminal Wiring Junction Box Way Boat Light:eBay Motors (item 120390769326 end time Oct-07-09 18:16:31 PDT)
You can also buy from Vintage Trailer Supplies but that are out of stock.
7-Way Wiring Box
toastie is offline   Reply With Quote
Old 09-27-2009, 04:34 PM   #297
toastie's Avatar
1955 22' Safari
Started today on the belly pan, have tried all shears and the harbor freight electric shear works the best by far. Raising the trailer 7" really helped also http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92115.
ID:	87782   Click image for larger version
ID:	87784   Click image for larger version
Old 09-27-2009, 04:47 PM   #298
pbearsailor's Avatar
Port Hadlock , Washington
Lookin' good, Toatstie. What aluminum are you using for your belly pan?
Great idea on those ramps--I think I know where I can borrow a pair.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 09-27-2009, 05:28 PM   #299
toastie's Avatar
1955 22' Safari
Thanks Steve
I'm using 5052 0.040 and the ramps are Rhino Ramp 12000 Extreme Ramp bought at Rhino Ramp 12000 Extreme Ramp Set - 2166195 | Tractor Supply Company
toastie
Old 09-27-2009, 05:36 PM   #300
Thanks!!
Old 09-30-2009, 11:53 AM   #301
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
Toastie,
What will be your final floor covering of choice? I'm still going back and forth between Cork vs. marmoleum.
Jaime
1956Safari is offline   Reply With Quote
Old 10-01-2009, 05:46 PM   #302
toastie's Avatar
1955 22' Safari
Originally Posted by 1956Safari View Post
Toastie,
Jaime
Jaime
The "boss" (wife) makes all of those decisions. At first it was marmoleum but decided to go with a floating wood floor. The floor will be a very light blonde color, cabinets will be antique black over red milk paint and the aluminum will be highly polished.
Toastie
Old 10-03-2009, 10:37 AM   #303
1966 22' Safari
Davis City , Iowa
I'm looking at the patch and wonder how you make the compound curves? The new panel looks perfect.
drowe42 is offline   Reply With Quote
Old 10-03-2009, 10:39 PM   #304
flyrc's Avatar
1962 22' Flying Cloud
Yakima , Washington
How many days did it take to remove all the paint layers? I've spent most of three days stripping paint off the interior of my 56 F/C and only reached the 6' mark. I sure wish I had a soda blaster.
Wally H.
Parts needed
1962 Street side corner tub
range or parts
Dometic 50 or parts
flyrc is offline   Reply With Quote
Old 10-04-2009, 05:27 AM   #305
toastie's Avatar
1955 22' Safari
I removed 3 coats of paint and zolatone was one of them The window trim and lower panels will be replace with new, TIME and the cost of the paint remover lead to that decision, plus I was tired of looking and smelling the stripper. I tryed all strippers, but in the end, Citristrip was the best and it was safer.Took 3 to 4 application of the stripper plus a plastic putty knife. also I used steel wool #4 with a plastic backing handle. This was done in the winter, time wise about 2 weeks.
Old 10-04-2009, 06:23 AM   #306
toastie's Avatar
1955 22' Safari
Took the old pattern and flatten it out, traced it on to new, then cut slits as shown in the picture. Then slowly worked it in, marked it, then slowly started trimming, keep repeating for the perfect fit. The soft aluminum will conform to the trailer. Notice in the picture how thin I made my cuts with the electric shears
ID:	88162   Click image for larger version
Old 10-18-2009, 04:26 PM   #307
toastie's Avatar
1955 22' Safari
Starting to run wires and a BIG learning curve is about to start. Mid to late 1950's Airstreams came with just a basic 110v system no 12 volts. The white wire 14 gauge will be used for the 110V and the yellow wire 12 gauge will be used for the 12 volts system. Let the fun begin.................toastie
Old 10-18-2009, 05:39 PM   #308
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
...The white wire 14 gauge will be used for the 110V and the yellow wire 12 gauge will be used for the 12 volts system. ...
Toastie, take some care with wire colors. In the Airstreams, white was/is ground for the 12V system, and yellow, brown and blue (maybe others--the 70s trailers had 4 12V circuits) were +12V. I recommend running grounds to most loads (lights, water pump, fans, but you can get by using the shell as ground), but definitely run a heavy ground wire between the converter, batteries, and the ground connection at the 7-pin umbilical connector (#10 is sufficient).
House code for 110V is white is neutral (not ground, but should be at ground potential) and black is hot. All my 70s Airstreams have the 110V in Romex (three wires--white, black, and bare copper, which is ground). Since the white and black are inside the Romex insulation, it's hard to confuse them with the 12V wires.
Just be careful not to screw the next guy up by using color codes that make sense to you, but possibly not to others.
Zep
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
