Old 08-26-2009, 07:36 PM   #281
toastie's Avatar
1955 22' Safari
Great Lake State , .
Originally Posted by utee94 View Post
Looking good toastie, all that new channel is so shiny and nice. That's about the spacing I used, seems to be working just fine.
Thanks Marcus, this trailer was neglected and was in very poor condition when I bought it, and it was exactly what I was looking for.
toastie is offline   Reply With Quote
Old 08-26-2009, 08:01 PM   #282
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
What Truck and Marcus said about the elevator bots. I think I read the other day that you are bolting the shell thru the new U-channel into the outriggers, right? That's pretty much how my 27 footer was put together. I think you'll be fine.
www.nesa.org
Air No. 6427
Old 08-26-2009, 08:04 PM   #283
toastie's Avatar
1955 22' Safari
That is correct, fastener's are being attached to frame..........
Old 09-05-2009, 02:56 PM   #284
toastie's Avatar
1955 22' Safari
Had rear separation and the pictures show why. The frame was repaired and today added a 2" x 3" angle iron bolted to the floor and frame for my rear plate. And like the front will add as many solid rivets that I can, shell to angle iron............toastie
ID:	86667   Click image for larger version
ID:	86669   Click image for larger version
Old 09-05-2009, 03:27 PM   #285
pbearsailor's Avatar
Port Hadlock , Washington
Looks really good, toastie. Back end of my frame looked exactly like yours and I added a steel plate back there. I was putting bolts in there this morning and I'll be riveting the plate in when I get a helper for the bucking bar. Really impressive how much they stiffen up when the fasteners start going in.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 09-06-2009, 08:04 AM   #286
toastie's Avatar
1955 22' Safari
Finally "slow floor replacement" is done, floor is down permanently. Starting to sand the seams, and my question to the forum is:
"What is the best filler to use on the elevator bolts and seams?" Bolts where recessed about 1/8"..........thanks toastie
Old 09-06-2009, 08:53 AM   #287
I'm going to coat the subfloor with epoxy, so I'll be using epoxy with a filler to level out all my holes and seams. Microballoons would be fine; I think I've got a container of West System 407 407 Low-Density Filler that'll work ok. It'll sand smooth very easily.
Old 09-06-2009, 09:13 AM   #288
toastie's Avatar
1955 22' Safari
Steve
Thanks very much, made both a favorite..........
Steve
Old 09-06-2009, 09:58 AM   #289
toastie's Avatar
1955 22' Safari
Almost forgot to cut hole for the shower, sanded off the dim's, luckily I wrote them down on a piece of paper. Have to finish the belly pan before I can start the fun stuff..........toastie
ID:	86679   Click image for larger version
Old 09-06-2009, 03:54 PM   #290
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
ok I really like your shower drain setup . . . that's what I would like to do, but I was under the impression that I must have a trap or I'll be smelling the contents of my grey tank AND I was led to believe that I need larger diameter drain line. Do you have "alternate" information? And, where did you get that shower drain w/the barbered fitting?
Thanks, MarkR
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 09-06-2009, 06:02 PM   #291
toastie's Avatar
1955 22' Safari
Thanks, MarkR
The shower drain comes with a stopper. The gray tank below is just for the shower and bathroom sink and is not part of the other gray water system, plus the shower drain is going to be approx 4" off the floor and
will built my own trap. The small bathroom sink will also have a trap. I bought my drain off ebay, its a SCANDVIK shower drain used on boats.........hope this helps..............toastie
Scandvik Drain & Accessories
Shower Drain
Old 09-09-2009, 03:31 PM   #292
toastie's Avatar
1955 22' Safari
Stainless 7 Terminal Wiring Junction Box for the Bargman, all hardware is stainless, what a slick system.........
Old 09-09-2009, 10:06 PM   #293
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
Cape Coral , Florida
Is the fitting at the end of the clear tube a straight-through barbed transition fitting or it a checkvalve?
dieseleagle is offline   Reply With Quote
Old 09-14-2009, 06:02 PM   #294
toastie's Avatar
1955 22' Safari
No check valve...........
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
