Old 11-21-2009, 10:27 AM   #381
toastie's Avatar
1955 22' Safari
Great Lake State , .
Working on putting the front trim piece on today. I learned a little trick, you can see the gap in the picture, what I did was to take the palm of my hand and layed it on top of the gap and then slowly, very slowly bend the piece back to take the gap out, then slowly worked myself around with the trim piece.
toastie
ID:	91345   Click image for larger version
ID:	91347   Click image for larger version
toastie is offline   Reply With Quote
Old 11-21-2009, 11:39 AM   #382
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Is that new trim pieces? Inquiring minds and all that.....
Old 11-21-2009, 05:53 PM   #383
toastie's Avatar
1955 22' Safari
No, its original...........toastie
Old 11-22-2009, 04:27 PM   #384
toastie's Avatar
1955 22' Safari
Before permanently setting the front trim piece, added Trempro 635 to the outside and after setting the trim piece sealed the inside.
toastie
ID:	91392   Click image for larger version
Old 11-22-2009, 05:26 PM   #385
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Looking great Toastie
It's not worth doing if you're not having fun.
https://tinman54.blogspot.com/
https://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 11-22-2009, 05:33 PM   #386
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
thats a great idea to stop water at each layer. I was surprised how many seams on ours weren't factory sealed (which I think led to most of the floor rot). Every horizontal, overlapped seam was not sealed, only end cap and verticle seams. Every one of them leaked. Made panel replacement easier (man that black stuff is hard to remove) though. Boy your belt trim is in great shape.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 12-12-2009, 09:19 AM   #387
toastie's Avatar
1955 22' Safari
Decided to go with a inline Hygienic Self Sealing Waste Valves, has been approved for RV use in the US since early 2007. Dry sealing valve prevents the escape of odors from your waste system into your RV and eliminates the need for check vents. Can be used in a vertical application as well as horizontal. A couple of Class A builders are using them under kitchen sinks to allow for drawers below the sink.
toastie
Old 12-12-2009, 11:44 AM   #388
toastie's Avatar
1955 22' Safari
More info on the Hygienic Self Sealing Waste Valves
Hepworth New Zealand -- HepVo -- Introduction
http://www.hepworth.co.nz/HepVo_NZ.pdf
HEPvO waterless trap install - The Casita Club Forums
Google Image Result for http://www.ascinfo.co.uk/9/resourcefile/08/15/85/HepvOInstallation.jpg
Hepvo Hygienic Self Sealing Waste Valves
toastie
Old 12-12-2009, 12:18 PM   #389
toastie's Avatar
1955 22' Safari
A valvectomy, notice that the ribs must be down in a horizontal ass'y,
Shower, 3rd drain valve mod, valvectomy - a set on Flickr
Old 12-12-2009, 02:40 PM   #390
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
help to see pics
I really want to see some of your Pictures....from the 2008 range...on the door and windows. I get blank pages...GEF.2x2... Not JPEG. On the later pics that are JPEG it comes thru. Have we got a computer whizz available? Can I get these to show? I think your work is super and I'd like to use it as a guide in my next project.
Old 12-15-2009, 04:34 PM   #391
1973 31' Sovereign
Portland , Oregon
Images: 22
No vents needed?
These dry valves look pretty interesting and I am at the stage in my remodel where I am just about to re-plumb my entire drain system. I have a couple of questions about these valves as follows:
I can see that using these dry valves would eliminate the need for p-traps on the shower and the sinks in the kitchen and bath. I can also see that it eliminates the need for vents on the drains themselves. Is the need for additional venting on the gray water tank then completely eliminated?
Presumably I still need a vent on my black water tank since there is no p-trap on the toilet that I can replace with one of these gadgets. Is that a given?
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
Old 12-15-2009, 05:31 PM   #392
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
Tums
Would you not need a vent to relieve the build up of gas? If the the tank is "sealed", then I would think back pressure would interfere with the one way valve.
FC7039 is offline   Reply With Quote
Old 12-15-2009, 06:58 PM   #393
toastie's Avatar
1955 22' Safari
Found this on YouTube, a couple of guys tested the backflow resistance of the valve. Perhaps you can visualize that as the backpressure increases it places more force on the membrane to remain closed. That is, as demonstrated in the YouTube video, until the backpressure becomes sufficient to force the entire membrane to reverse itself.
Old 12-15-2009, 08:12 PM   #394
Images: 59
I have the same concern about backpressure. If you have a sealed tank with no external vent, then any fermentation in the gray water tank would exert backpressure on the downstream side of the valve and prevent free drainage of the shower.
A few inches of backpressure on the tank side of the valve could cause a few inches of backup in the shower.
Not a problem if you also have a regular tank vent. Or if you keep the pH of the graywater high enough to prevent fermentation.
Otherwise, might be a problem.
Old 12-16-2009, 04:02 PM   #395
toastie's Avatar
1955 22' Safari
All of my tanks will be vented to the atmosphere, the shower will have its own gray water tank. The reason that I going with the Hepvo is space, I'm micro managing the space.
toastie
Old 12-16-2009, 08:43 PM   #396
Bothell , Washington
re-build
toaste, i have read all your post tonite. wow, that is all good stuff. way to go. your AS will be better then new and better then the new ones. AS should take notice. anyways, great job, great post, very interesting. thanks, can't wait to see the finnish of this.
Outlaw
Outlaw is offline   Reply With Quote
Old 12-16-2009, 10:19 PM   #397
1973 31' Sovereign
Portland , Oregon
Images: 22
I was thinking some more about this and I think that you are right about still needing to vent the tanks.
Malcolm
Old 12-22-2009, 11:03 AM   #398
toastie's Avatar
1955 22' Safari
Thinking about running the sewer hose through the sewer hose holder kit, then, permantanly fastening the hose to dump valve and design it that the kit can pivot. Any other ideas out there with pictures?????
toastie
ID:	92852   Click image for larger version
Old 12-22-2009, 11:29 AM   #399
memgrove2000's Avatar
Elkhart , Indiana
Send a message via AIM to memgrove2000
I saw this a while ago. It may give you a few more ideas.
Mike
Have a great day!
TAC # IN 1 Air#27922
memgrove2000 is offline   Reply With Quote
Old 12-22-2009, 11:57 AM   #400
toastie's Avatar
1955 22' Safari
Mike
That's is a great idea, I knew that there had to be something out there in this multi billion dollar rv business, thanks for sharing.
toastie
1955 safari, floor, redo
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement spitfyr Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
Recent Discussions
