have fun. Become as conflicted as the rest of us! But OMG, you are fast!
Zep
Like the hanging light over the table, very nice Zep. Things will probably slow down a little, just getting to friggin cold here, we had over 10" snow Sunday.
This is a 2+ year project...........
Starting to compound the inside, this will be the first cut, will replace all rivets with olympic rivets, then shave then to look like the rivets to the 13 panels, than compound second cut.............
Toastie, can you do a little bit wider angle shot. I'm pretty sure I'm looking at the dome, but I'm disoriented. Looks great, btw. I don't think this is going to take you 2 years at the rate you're going.
Zep
Does this help, the reflection is the floor that will be replaced after the prep work.
I'm going to replace the forward plastic end cap in my '77 Safari, so I'm very interested in how your panels fit and how they intersect the window frame. It looks like I could do it with 11 panels and get a good curve. I've got a photo of FLYFHSR's dinnette in his '59 Tradwind and it shows his metal end cap are made from only 5 panels, but they are probably compound curved.
Would you mind posting the dimensions of your end cap panels, just their widths as they join the straight side/top skins and where they join the window frame? Thanks.
Don't give it to him, he needs to figure it out for himself.
Has the floor been replaced yet? Seems like a ton of work before you lay the floor. It sure looks spectacular though/
Highly recommend removing paint and compounding to leave the old floor. You will wreck the new floor with paint drippings and falling paint splatters from scraping, and a black residue from the compounding. Once the new floor is in, will cover the floor with paper, will compound with the cyclo using F7 with wraps, then polish, using nuvite S with cyclo wraps, messy but not as messy using a compound wheel. I Don't consider this work.
Removed wheel wells today and also started removing the belly pan. The wheel wells will be re-fabricated, one will become a small bench in the bathroom/shower room. With belly pan and axle removed, and the shell raised, should have no problems installing the new floor.
Toastie,
Looks great, you're moving fast. At this rate you'll come in under your two year window, but you're smart to plan for the long haul. Sometimes life does get in the way.
Keep at it, I'm impressed.
Dave
To cold to work outside, so I removed some of the window's, and the door, and working on them in the basement. Had a good fine on e-bay picking up
2 Bargman lever with locks in one auction, will have a local locksmith make new keys. Parts will be sent out to be chromed, and hoping to end up with one complete set. Also planning and researching for when the weather breaks here.
