Old 12-07-2008, 05:26 PM   #253
toastie's Avatar
1955 22' Safari
Great Lake State , .
Originally Posted by Aerowood View Post
Some refers have a ignition lock that turns the gas operation off when the ingnition key on the tow vehicle is energized, and then runs the refer on 12vdc from the tow vehicle battery using the TV to Trailer battery charging circut. The circut has a delay timer that allows the the system to stay on the tow vehicle battery for a specified time with the ignition off so that the gas operation side does not energize when at the gas pump,etc. after the trailer is unhooked the timer will engage and allow the gas operation to start or 120vac operation. A seperate wire has to be run from the TV to the refer for this system to work. I haven't decided if I am going to use this feature or not. This could be what the extra wire is for.
Kip
Kip
Looking over the wiring diagrams on all there models, I think that the blue wire is what they call a "test point", will call Dometic tomorrow.
toastie
toastie is offline   Reply With Quote
Old 12-26-2008, 06:29 PM   #254
toastie's Avatar
1955 22' Safari
travelingvintage.com
Decided to build a website since its to cold to work on Mr. Whipple, will be posting a ton of pictures.
Home Page
Old 12-30-2008, 07:56 AM   #255
toastie's Avatar
1955 22' Safari
Very lucky
We had 45 to 65 mile an hour winds Sunday, a tree fell next to our
65 Caravel, not even a small scratch, very lucky.
ID:	73089   Click image for larger version
Old 12-30-2008, 08:37 AM   #256
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
WOW!!!! you aren't kidding. Glad to hear its ok!
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is online now   Reply With Quote
Old 12-30-2008, 01:10 PM   #257
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Time to buy a lottery ticket - quick before the luck wears off.
Whew, that was a close one.......
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 12-30-2008, 07:07 PM   #258
toastie's Avatar
1955 22' Safari
Bought a ticket today................
Old 12-30-2008, 08:18 PM   #259
Rhonda's Avatar
1956 26' Cruiser Overlander
1970 23' Safari
Lambertville , Michigan
Betcha you changed your undies after that!!
Rhonda is offline   Reply With Quote
Old 12-30-2008, 08:36 PM   #260
toastie's Avatar
1955 22' Safari
You Betcha..............
Old 03-08-2009, 10:46 AM   #261
toastie's Avatar
1955 22' Safari
I have received a few questions on how I'm going to do my screens on the Safari, I was going to cover this later but I will do it know. The screen in the picture's is my prototype just to see if it will work, I bought the frame from Home Depot along with the screen material, the 90 deg bracket's come with the frame, very easy to make up. ( I used my power miter to cut that perfect 45 deg angle) The first thing that I will do is to install new trim around all window's, then cut my screen frames for the perfect fit to each window. When making up the screen you will notice that I cut the screen to fit the window openers, I will place a little piece of aluminum with slot so that the screen will not tear. Open the window opener, slide the screen onto the window openers and slide into position, the screen frame will set againt the new window trim, should make a clean design. will apply some small clips. Hope the pictures help.
Toastie
ID:	76576   Click image for larger version
ID:	76578   Click image for larger version
Old 03-08-2009, 11:20 AM   #262
pbearsailor's Avatar
Port Hadlock , Washington
Thanks Toastie.
That really looks like a much better way to do it than the original.
pbearsailor is offline   Reply With Quote
Old 03-08-2009, 02:19 PM   #263
1958 26' Overlander
Lander , Wyoming
Thumbs up
I like that as an easier replaceable solution. What are the dimensions of the screen frame? 1/4 in thick? They look 1 in wide rather than 3/4. I'll plan on something similar with mine. Ed
n2batr is offline   Reply With Quote
Old 03-08-2009, 03:30 PM   #264
toastie's Avatar
1955 22' Safari
The thickness is 1/4", hope the picture helps..........
Old 03-08-2009, 03:32 PM   #265
toastie-- this is a very good way to update those screens. Those Hehr windows look great, but they have their quirks.
I'm really looking forward to seeing you make more progress on your project as winter passes, your work is truly inspiring.
Old 03-08-2009, 03:43 PM   #266
toastie's Avatar
1955 22' Safari
Thanks Marcus, it's been a very bad winter, and a very bad economy here in Michigan, a 12% unemployment rate and its going to go even higher. We won't even talk about the Detroit Lions 0-16 season.
Toastie
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
