Old 11-14-2008, 11:22 AM   #225
toastie's Avatar
1955 22' Safari
Great Lake State , .
Originally Posted by malconium View Post
It may be too late for you to want to change and maybe you already have your charger but I decided to change. I originally bought a 30amp box at Lowes or Home Depot but decided not to use it when I discovered the following combination 120v/12v panel with integrated charger. The really cool thing is that my wife bought me one for my 60th birthday. I have not yet had time to install it though.
XADC 30A Distribution Center
What I especially like about the panel/charger combination is that it has a nice front panel accessible arrangement to all the fuses and the charger itself.
See what you think.
Malcolm
Lucky, that is one slick box. Yes to late, decided to go with what I have since I've already ripped into everything.........thanks very much
toastie is offline   Reply With Quote
Old 11-16-2008, 12:13 PM   #226
toastie's Avatar
1955 22' Safari
Starting my second of 3 compoundings, nuvite G6 is working great.
ID:	71426   Click image for larger version
Old 11-16-2008, 03:24 PM   #227
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Wow, that's shiney in there! Hard to tell what's been skinned and what hasn't. I'm not sure if I want to see the top of my head though!
Marc
Old 11-16-2008, 06:33 PM   #228
Baltimore , Maryland
... mirrors on the ceiling, pink champagne on ice.... it keeps going through my head when I look at that.
Old 11-17-2008, 07:59 AM   #229
GR8DANE's Avatar
1966 22' Safari
1964 24' Tradewind
1956 18' "Footer"
Southern , Minnesota
...we are all just prisoners here...of our own device...
life is too short to drink cheap beer...unless that's all we've got and then pass me a cold one!
Steve "Dancin" Hansen
TAC MN-31
visit my almost yearly blog http://www.bluessafari.blogspot.com
GR8DANE is offline   Reply With Quote
Old 11-27-2008, 10:00 AM   #230
toastie's Avatar
1955 22' Safari
Started work on the layout shown in blue and getting a feel for what the wife wants.
ID:	71839   Click image for larger version
Old 11-27-2008, 11:26 AM   #231
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
After doing mine I thought I should have used some old carboard to make temporary walls and counter tops on mine to get a real feel for the layout and how it impacted space and functionality. It would have taken an hour or two at most and would have put things into truly visual perspective for us. There are a couple of things I'd have done differently to give a more open feel and better leveraged what is now almost dead space.
Barry
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
safari57 is offline   Reply With Quote
Old 11-27-2008, 11:37 AM   #232
toastie's Avatar
1955 22' Safari
Barry
Barry
Thanks, I agree, before we start the carpentry everthing should be planned to the 1/2". There is no closet in this design.
Toastie
Old 11-27-2008, 03:45 PM   #233
64TrotterAtl's Avatar
1964 19' Globetrotter
Decatur , Georgia
Electric Diagram
Originally Posted by toastie View Post
Went to Lowes today and bought my GE electrical box and circuit breakers.
1) 125 amps TL412C main lug box
1) 15 amp GFCI
1) 20 amp GFCI
1) 15 amp breaker
1) 20 amp breaker
1) 10' of #8 wire that I will run from Marinco 30A 125V to Main 30 amp breaker.
This will be a BIG learning curve for me. Will need to come up with a wiring diagram on paper so I can balance out the question marks below. Then I will go to the 12v system.
Wire 5 will be for the main
Wire 4 to the 20 amp will be only for air conditioner
Wire 3 to the 15 amp will be Intellipower and ?????
Wire 2 to 15 amp GFCI will be kitchen, exterior and ?????
Wire 1 to 20 amp GFCI will be bath, refrigerator, exterior and ?????
I have been following your thread off and on. I am glad you are wiring thins now. I have attached a wire diagram that I picked up here on the forums. Maybe it helps with the design phase of things.
I have a question. I am wiring all of my 110 now also. So for "wire 1" mentioned above, you will run a wire to the bathroom receptacle, then from there, a wire to refrigerator, then that same wire to an exterior outlet, ending there.?? I am new to electricity, can you educate me a little. Will there be a junction box at each connection?
Do you have a diagram since these posts have been made? I am just trying to figure out mainly about the junction boxes and running all the 110 wire. Will all of your outlets inside be 110?
Andrew
64TrotterAtl is offline   Reply With Quote
Old 11-28-2008, 07:52 AM   #234
toastie's Avatar
1955 22' Safari
Andrew
Andrew
Sorry, If I where a electrician I could help, I can't give advice on this subject due to its nature and my lack of electrical knowledge.
Toastie
Old 11-28-2008, 10:13 AM   #235
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
...I have a question. I am wiring all of my 110 now also. So for "wire 1" mentioned above, you will run a wire to the bathroom receptacle, then from there, a wire to refrigerator, then that same wire to an exterior outlet, ending there.?? I am new to electricity, can you educate me a little. Will there be a junction box at each connection?
...Andrew
Andrew, once you decide which outlet boxes will be on which circuit, you chain them together, eg, run the wire to the first box, then from there to the second box, then on to the next, etc. You can use the 1" deep plastic boxes or any box that will fit in the shell thickness. You don't need a "junction" box as a separate box--the outlet itself has enough screw terminals for the incoming and outgoing wires, except the ground, which you can splice using either a wire nut or a bare metal crimp-on splice. Splice the two grounds together with another short piece of wire--the short piece goes to the ground screw at the bottom of the outlet.
Using a wire nut in the thinnest box will be a little cramped, but you can do it.
When you attach the wires to the outlet, the silver screws are for the white wire and the brass screws are for the black. This is important, as it keeps your neutral and hot sides properly oriented. I also recommend that you use the screw terminals, not the push-in connections on the back of many outlets.
Zep
Old 11-28-2008, 12:20 PM   #236
toastie's Avatar
1955 22' Safari
Zep
Thanks Zep................Toastie
Old 11-30-2008, 10:05 PM   #237
1973 31' Sovereign
Portland , Oregon
Images: 22
Zep
Hi Zep,
Have you found a source for a box that fits the same as the original boxes? I have noticed that the ones on my 73 are wider than a single box but not as big as a double box. Of course they are somewhat shallow too because of the limited wall thickness.
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
Old 11-30-2008, 10:21 PM   #238
1975 31' Sovereign
1977 23' Safari
No, I haven't added or replaced any boxes yet. When I get back into the Safari I will be doing that, so I hope someone finds the right box before I need them.
Zep
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 12:11 PM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 06:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 01:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 02:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 07:26 AM
