Old 10-31-2008, 05:07 AM   #211
toastie's Avatar
1955 22' Safari
Great Lake State , .
Originally Posted by clancy_boy View Post
HAIL - very lucky it was small.....
We had one this past spring that if it had passed over the house it would have done real damage to the AS - golfball size. Instead it was 1/2 mile down the road..... Whew.
Great progress, let me know when I can bring the Caravel up for a referb.
Thanks clancy
We rarely get hail here in October, nothing to compare what you went through this summer, hope everything is ok.
Toastie
toastie is offline   Reply With Quote
Old 10-31-2008, 06:26 AM   #212
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Originally Posted by toastie View Post
Permanently installed back 2 tanks, here are a few pictures, used plenty of trempro 635...............toastie
Toastie,
The picture in the upper left looks as though you screwed through the flange of the tank... Is that true?
I like the idea of "bedding" the tank flange in tempro. In my set-up I was concerned about the tank shifting, but the tempro would greatly prevent that.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 10-31-2008, 06:41 AM   #213
toastie's Avatar
1955 22' Safari
Originally Posted by byamcaravanner View Post
Toastie,
Steve
Not screwed, I used 4 small bolts, one at each corner, I made sure that the drilled holes are large enough for the bolts to freely drop in, hand tighten only. I original was going to use brackets to fasten the angle iron to the rods, but when torque is applied would twist the angle iron putting stress on the tanks. The main goal here is not to stress the tanks at all, if I can achieve that, the tanks should out live me.
I really like your refrigerator
Toastie
Old 10-31-2008, 03:17 PM   #214
1967 28' Ambassador
1970 29' Ambassador
...I really like your refrigerator
toastie,
I looked back a little to see that your tanks appear to be built differently than mine... thus the reason for my "bolt" question. the flanges on may tanks are 3" deep and are part of the contents holding portion of the tank. Drilling a hole as you have would have meant I would need to seal the tank where the bolt exited the bottom of the flange. I see now that your flanges are formed by extending the top sheet of the tank thus they can be drilled without penetrating the tank.
Regarding my fridge... I am very happy with the NovaKool. It adds significant functionality with a level of reliability and simplicity not found in the Ammonia charged units. I am also happy that even though I purchased it for our Ambassador, it will fit very nicely under the existing counter in our Globetrotter.
I've immensely enjoyed your posts... thank you.
Steve & the crew
Old 11-01-2008, 06:09 AM   #215
toastie's Avatar
1955 22' Safari
Originally Posted by jewelcofsc View Post
Hey Toastie...Just wondering, do you sleep? Do you eat? Do you have a job you go to?!!!!!!!!!! Your doing a great job, I've been following your progress. I can't wait to see what you do for the interior! We hopefully will be doing a similiar, not-so-detailed retro to a 1959 24' tradewind. I have gota lot of great ideas from you, thanks. Keep them coming! By the way, what do you do professionally? Is it some kind of fabrication?
Thanks, Jewelcofsc
Thanks, well, I just woke up, need to lose a few pounds, and I work for one of the big 2 auto companies advance engineering powertrain groups in the Detroit area. I was going to say the big 3 but it looks like Chrysler is going down. The wife is in charge of the interior design and it looks like today we are going retro, we both design as we go and we are constantly changing things, nothing on paper at all.
Toastie
Old 11-01-2008, 06:23 AM   #216
toastie's Avatar
1955 22' Safari
toastie,
After doing some reading about the NovaKool I would like to go with one untill I saw the price......wow......will be looking for a deal.
Old 11-01-2008, 08:14 AM   #217
toastie's Avatar
1955 22' Safari
Applied silicon to the rubber bushing groove and around the edge.
ID:	70619   Click image for larger version
Old 11-09-2008, 12:39 PM   #218
toastie's Avatar
1955 22' Safari
Floor, 1 black and 2 gray tanks are in. Will probably wait for spring to install the belly pan/floor permanently, wheel wells are permanently attached to side walls. Started work on the electrical.
ID:	71128   Click image for larger version
ID:	71130   Click image for larger version
Old 11-09-2008, 02:43 PM   #219
toastie's Avatar
1955 22' Safari
a BIG learning curve is about to start
Went to Lowes today and bought my GE electrical box and circuit breakers.
1) 125 amps TL412C main lug box
1) 15 amp GFCI
1) 20 amp GFCI
1) 15 amp breaker
1) 20 amp breaker
1) 10' of #8 wire that I will run from Marinco 30A 125V to Main 30 amp breaker.
This will be a BIG learning curve for me. Will need to come up with a wiring diagram on paper so I can balance out the question marks below. Then I will go to the 12v system.
Wire 5 will be for the main
Wire 4 to the 20 amp will be only for air conditioner
Wire 3 to the 15 amp will be Intellipower and ?????
Wire 2 to 15 amp GFCI will be kitchen, exterior and ?????
Wire 1 to 20 amp GFCI will be bath, refrigerator, exterior and ?????
ID:	71133   Click image for larger version
Old 11-09-2008, 03:14 PM   #220
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
125 amps? Wow! Seriously, tho, looks like you're headed down the right path. One thing I did was to add a seperate dedicated 15 amp breaker & circuit just for the microwave. Something to think about if you are going to install one those.
www.nesa.org
Air No. 6427
Old 11-09-2008, 03:15 PM   #221
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
You've got a great plan, already. Nice box--a little bigger than usual, but it sure gives you the ability to go GFCI without having to do it "backwards."
One thing I've noticed in my Overlander is a dearth of outlets up front, especially around the door (on the inside). I would also recommend an outlet outside on the street side and one outside on the front.
Zep
Old 11-09-2008, 04:45 PM   #222
toastie's Avatar
1955 22' Safari
Zep
Thanks Zep
In the picture, the upper receptacle is for a plug in light, and the lower will be a power outlet, have a extra power outlet receptacle that I will add.
Toastie
Old 11-09-2008, 04:49 PM   #223
toastie's Avatar
1955 22' Safari
Thanks Jim
Yes we will have a microwave and will take a look at it.
Toastie
Old 11-12-2008, 04:58 PM   #224
1973 31' Sovereign
Portland , Oregon
Images: 22
Really cool power panel...
It may be too late for you to want to change and maybe you already have your charger but I decided to change. I originally bought a 30amp box at Lowes or Home Depot but decided not to use it when I discovered the following combination 120v/12v panel with integrated charger. The really cool thing is that my wife bought me one for my 60th birthday. I have not yet had time to install it though.
XADC 30A Distribution Center
What I especially like about the panel/charger combination is that it has a nice front panel accessible arrangement to all the fuses and the charger itself.
See what you think.
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
