Old 10-15-2008, 03:54 AM   #183
Baltimore , Maryland
Here are my questions.....
Does the tank hang down below the frame and belly?
Are the tanks going to be removable from below incase anything might occur to them or do they drop in from the top?
I used a grey water tank very similar to yours. It hangs down below the belly and can be dropped from below incase of some troubles. I do not like the use of pumps to empty the tanks though. I think gravity should do the work for you. That side discharge will empty the tank in about 30 seconds.
Old 10-15-2008, 06:35 PM   #184
toastie's Avatar
1955 22' Safari
Great Lake State , .
Originally Posted by 3Ms75Argosy View Post
Just a thought about no traps... will that allow smells from the grey tank to go up into the shower? There is a small low profile L fitting that has a trap built in by Camco.. it has a 1/2" barb off the end.
So the grey will pump into the black after if flushes.. is this the plan?
Marc
Marc
The only water that goes into the front gray tanks is antibacterial soapy water, there will be no feedback from the rest of the system, plus there will be a rubber stopper if needed. Our 1965 Caravel has no gray tank just a black, and with 3 trap and we get no feedback from those trap with stagnate water in them.
Toastie
toastie is offline   Reply With Quote
Old 10-15-2008, 08:45 PM   #185
toastie's Avatar
1955 22' Safari
Yes they will hang down, the tanks are 9" deep and they will be removable from the bottom.
Old 10-15-2008, 11:45 PM   #186
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Toastie,Nice progress I am trying to get caught up on your project,it looks real good.I am trying to find a good place to get an axle and tanks for my 54 cruiser,I think I found an axle place today locally,I didn't want to pay those big shipping charges,I want to do the same as you and bring them the old axle for measurements.Where did you find your tanks,cost? Our 54 didn't have any tanks so I have been trying to find work like yours to go by.
Thanks for all the pictures and notes it helps a lot and is very encouraging to us new guys.
Doug
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 10-16-2008, 06:23 PM   #187
toastie's Avatar
1955 22' Safari
Doug
Thanks Doug
I bought my tanks from RV Parts and Accessories for Sale and they get there tanks from Recreational Vehicle (RV) Trim, Tanks, Covers & Live Wells from Ameri-Kart Ameri Kart has an on-line catalog, with a large selection. I went with ABS vac. tanks, the larger tank was $98.00 and the 2 smaller ones where $127.00 ea. with a total of $19.00 for shipping. I called Ameri Kart and they recommend supporting the tanks using the lip around the tank along with metal straps, make sense since the larger tank filled would weight about 200 lbs., they also recommend not to tight with the straps because of expansion and contraction, I ask how tight and they wouldn't say. My goal is not to use straps...............
Toastie
Old 10-16-2008, 08:18 PM   #188
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Toastie,
I've installed similar tanks, but mine are supported on the long sides... this way there is no need for added straps.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 10-18-2008, 12:33 PM   #189
toastie's Avatar
1955 22' Safari
Started to work on hanging the tanks today. First thing was to mock-up one of the cells, and I found this very helpful, I must went thru a dozen little designs. Want to be able to move or remove the tanks from below with the floor on, this will help to fine tuning the plumbing and also fastening the floor to the frame. The pictures show that the tanks will hang from 1/2" steel rods, then a 14" strap with rubber backing will wrap around the tank and fastened to top of angle iron with rivets. Using rubber fittings for the toilet and vents, once the floor is on will have about 1/4" from bottom of floor to top of rubber gaskets. Will locate tank to frame width wise using spacers. The goal here is not to stress the tank, have to be very careful with the fasteners on how they are applied.
Toastie
ID:	69765   Click image for larger version
ID:	69767   Click image for larger version
Old 10-19-2008, 11:09 AM   #190
toastie's Avatar
1955 22' Safari
Adding some fitting to the black and gray tanks today, this is a 3 day process for me.
Cut hole using a variable jigsaw (measure 3 times then cut) glued fitting, let dry for 24 hours. Picture shows first glue app. on black tank
Add more glue, let dry for 24 hours
Add more glue, let dry for 24 hours, should be good to go.
Toastie
ID:	69839   Click image for larger version
Old 10-21-2008, 05:42 PM   #191
toastie's Avatar
1955 22' Safari
Have all 3 tanks in, will put the finishing touches this weekend, then the floor will go in for the second time.......
ID:	70005   Click image for larger version
Old 10-21-2008, 06:58 PM   #192
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
That looks like a great job; I'm thinking of doing much the same thing. 2 fresh tanks in front of the axles except oriented inline with the length of the trailer (if welding surgery allows) and a large grey aft of the axles. I'm really interested to see if you manage to get some sort of belly pan- protective sheet worked around them.
truckasaurus is offline   Reply With Quote
Old 10-22-2008, 04:49 AM   #193
toastie's Avatar
1955 22' Safari
Thanks, I'm going to weld some angle iron on the sides of the frame and create a box, then this winter I will make a box in the basement that will match the box to the frame, will post some pictures this weekend.
Old 10-22-2008, 08:02 AM   #194
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
closely following....
Great job Toastie! I am following your work closely and starting my own project. I just worry about the ground clearances. I have dragged the skid protector a couple times on my Caravel, even with the increased height provided by the new axel and tire/wheel selection. (drags occurred on those steep gas station drives.) Are you planning on some type of protection for your dump system? Your photos really help. Thanks.
Old 10-22-2008, 09:23 AM   #195
1960 33' Custom
Is there a good way to evaluate the ground clearance required? I mean I don't have an Airstream dealer anywhere near me but when I look at SOB's they can be jacked up super high or barely of the ground. I want to use the same depth tanks (9" 39 gals) and have them extend 48" in front of the first axle, does anyone have an opinion as to whether this is sensible? Option 2 is to have 3 or 4 shallower tanks but stretching further towards the tongue and option 3 is to use shallower tanks (say 6" 26 gals) plus move one tank (26 gals) inside under the front window. I like options 1 and 3 the most but is there a problem with having multiple tanks dotted around a trailer for fresh water only?
Old 10-22-2008, 09:34 AM   #196
Eliminator46's Avatar
1970 25' Tradewind
Cleveland , Texas
Images: 45
26Gal tank under front window will add 200+lbs to the tongue weight. Plus any added weight from in front of the axle. Most hitches are designed for around, what, 500lbs?
Eliminator46 is offline   Reply With Quote
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
