Old 08-17-2008, 04:36 PM   #141
toastie's Avatar
1955 22' Safari
Great Lake State , .
Frame removed
The frame is much easier to work on when removed. Removed the axle and took it to a local rv repair shop for new axle. Will be going with a Dexter 5200 lb straight axle, but will be using the existing leaf springs. The bushings will be rubber with outer and inner steel bushings, just like I took off. While waiting for the axle will be working on the black and gray water tanks.
ID:	65791   Click image for larger version
ID:	65793   Click image for larger version
toastie is offline   Reply With Quote
Old 08-17-2008, 10:49 PM   #142
1967 22' Safari
South East Idaho , South East Idaho
I am ready to lift the shell off my Safarie. I am concidering grinding the heads of the fasteners that hold the shell to the frame. Good idea or bad????? How is the best way to remove these fasteners??
Grad67 is offline   Reply With Quote
Old 08-18-2008, 03:59 AM   #143
toastie's Avatar
1955 22' Safari
Reciprocating Saw
Craftsman 10 amp Reciprocating Saw with Soft Tool Bag & 3 pc. Blade Assortment - Model 17184 at Sears.com
Old 08-18-2008, 05:11 AM   #144
Baltimore , Maryland
just grab on to them with vise grips and break them off....
Old 08-18-2008, 06:50 AM   #145
1958 26' Overlander
Lander , Wyoming
For many of the 50 and 60 trailers most of the bolts are so rusted that, Frank is right, you can just break them off. On some if in good shape a sawzall may be appropriate. On many of mine all I used was a dremel tool with a cutoff wheel on it. You have a little more control especially if near the outside shell. Make sure you've got your glasses! Ed
n2batr is offline   Reply With Quote
Old 08-18-2008, 12:06 PM   #146
1967 22' Safari
Thanks I will experiment. Actualy I was looking down at the floor from inside the shell when I ask the question.
Old 08-18-2008, 02:07 PM   #147
do not use glasses use goggles if you cut metal. Take it from a guy that was wearing safety glasses and still got metal in his eye. Eye surgery is not fun, I know.
Old 08-20-2008, 05:33 PM   #148
toastie's Avatar
1955 22' Safari
2 coats of por-15, will put the top coat on tomorrow..........
ID:	65956   Click image for larger version
Old 08-21-2008, 05:26 PM   #149
toastie's Avatar
1955 22' Safari
Finished with top coat today............3 coats total
Old 08-24-2008, 11:32 AM   #150
toastie's Avatar
1955 22' Safari
Decided to go with 3/4" AC plywood at $44.00 a sheet, a few voids but very solid stuff, happy with the selection. Will be sealing the edges and bottom with liquid wood, there appear to be other brands but I chose liquid because the store is 5 miles from my work. On the ends, I had no existing patterns to work with, will lower the shell enough to trace a pattern.
My axle and black and gray tanks should be in next weekend.
http://www.airforums.com/forums/f474...ler-44632.html
http://www.abatron.com/cms/buildinga...iquidwood.html
ID:	66141   Click image for larger version
Old 08-29-2008, 06:01 PM   #151
toastie's Avatar
1955 22' Safari
Wheel tubs
Was going to have new wheel tubs fabricated but decided to rework the original ones, a big cost saving.
ID:	66527   Click image for larger version
Old 08-30-2008, 08:13 AM   #152
1958 26' Overlander
Lander , Wyoming
I think you will be happy you went up to 3/4" AC. I did that on my project and have been happy with the more solid feel. A little extra weight but probably not that much for the added support. How was the framing(outriggers) around your steps? I had to double mine to get enough support/rigidity there. Now they are much more solid. Great job thus far! I'm following with interest. Ed
Old 08-30-2008, 09:54 AM   #153
toastie's Avatar
1955 22' Safari
Ed
Thanks, I plan to seal the edges and bottom of the plywood with Liquid Wood. There was no step there when we bought it, on our 65 Caravel we use a step that we bought from Camping World and we love it.
Aluminum Folding Step - Item - Camping World
Steve
Old 08-30-2008, 10:02 AM   #154
toastie's Avatar
1955 22' Safari
Seal them, a good coat of paint........done
Seal them, a good coat of paint.............done
ID:	66561   Click image for larger version
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
