Old 07-27-2008, 06:11 PM   #127
vhord's Avatar
Images: 96
Wow!!! What a difference you have made!
Now, can you come do mine?
vhord is offline   Reply With Quote
Old 07-27-2008, 09:03 PM   #128
63Silver's Avatar
1963 28' Ambassador
Smiths Grove , Kentucky
Images: 43
Wow!!! What a great looking job!!! The windows look super. I noticed you also did a lot of polish work as well. What did you use and how did you use it? We are trying "Truck Box Polish", looks better but not great. I think I may purchase some Nuvite and give it a try.
63silver
63Silver is offline   Reply With Quote
Old 07-27-2008, 10:17 PM   #129
Lauderdale , Florida
Ok - congrats with your nes safari.I got a Ponitac 1960 safari and it has got some dazzling features on floor replacements.
1960 Pontiac Catalina 4 Door Sedan Carpet In Tuxedo
$207.95
Tell about cost and afcours hsare some pictures.
michell is offline   Reply With Quote
Old 07-29-2008, 03:32 PM   #130
toastie's Avatar
1955 22' Safari
Great Lake State , .
63silver
Thanks very much, no polishing just compounding so far. I bought Truck Box Polish and what a waste of money. If you want professional results go to Home and follow them to the tee, you won't be sorry
toastie is offline   Reply With Quote
Old 07-29-2008, 03:39 PM   #131
Baltimore , Maryland
you are so right about the tool box polish. I just shines the surface and does not polish the surface. I learned the same sad lesson. Wait till you use the Nuvite A on the cyclo...
Old 07-31-2008, 11:48 AM   #132
1967 22' Safari
South East Idaho , South East Idaho
When I get my floor up I have some tonge and grove 5/8 pine to put down. Guess it would need a sub floor huh????
Grad67 is offline   Reply With Quote
Old 07-31-2008, 12:28 PM   #133
Our panel pro friend will be so disappointed to read this...
Old 07-31-2008, 08:06 PM   #134
1973 31' Sovereign
Portland , Oregon
Images: 22
Are you talking about taking up and replacing old flooring or are you talking about removing the existing sub floor too? If you remove the sub floor you will have to replace it before you put in your 5/8 pine.
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
Old 08-02-2008, 09:40 AM   #135
toastie's Avatar
1955 22' Safari
Prepping for a shell off
Prepping for a shell off. On the 1955 Safari it appears that they ran bolts thru the channel, wood floor, and each outriggers and little metal bracket at the ends. When the shell goes back on should have a good shell to frame alignment. (will use alignment pins)
ID:	64912   Click image for larger version
Old 08-03-2008, 05:54 PM   #136
toastie's Avatar
1955 22' Safari
Braced evething up today and actual lifted it a couple of inches, it went up smooth. Removed the side windows to help reduce weight since I will be doing all the lifting.
ID:	64993   Click image for larger version
Old 08-03-2008, 09:03 PM   #137
1967 22' Safari
Malcolm
That was a dumb question for me to ask. Of course a sub floor is needed
Old 08-05-2008, 05:32 PM   #138
toastie's Avatar
1955 22' Safari
I have lift off
I have lift off, everything is level, squared and secured. Had to buy a Hi-Lift Jack, well worth the $64.00. Will tackle the outside support tomorrow.
ID:	65129   Click image for larger version
ID:	65131   Click image for larger version
Old 08-07-2008, 01:28 PM   #139
1973 31' Sovereign
Portland , Oregon
Images: 22
That looks like it is working just great...
I think as an alternative that you can also use a small hyrdralic bottle jack on top of the frame if you don't have acess to the type that you used. What I did was to mount my cross pieces just high enough above the floor so I could fit a jack in below the cross brace to lift from the floor. In my case I really had to do that since I was doing a body on floor replacement and was not intending to take off all of the belly pan.
Malcolm
Old 08-07-2008, 04:54 PM   #140
toastie's Avatar
1955 22' Safari
Malcolm
Thanks Malcolm, I was going to raise just high enough to put the floor down, but what the heck, if I can raise a few inches, I can raise 2 feet with a 48" jack, faster, plus working on the frame is much easier. The frame will be going in for a new axle, plan on using the existing left spring. For a complete axle 5000 or 5200 (?) will be about $750.00 complete, and that is for everthing.
Toastie
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement Can-O-Pabst Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
