Old 08-23-2015, 08:44 PM   #1
Slide out on 2005 Classic 30'
I'm looking at a 2005 Classic in 30'. It has a slide out on the driver's side for the dinette. Have there been problems with leakage around the slide, or problems with the slide getting stuck in, or OUT?
fredflyer is offline   Reply With Quote
Old 08-23-2015, 10:10 PM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I've got a 2004, same size and configuration. There are a few threads regarding slides. Airstream did these right and if it hasn't been abused, it should be good. Remember that the trailer should be level with the stabilizer jacks down prior to extending the slide or when retracting it. Those slide units are heavy and can exert a lot of torque on the frame if the stabilizer jacks aren't down. That can cause damage. Let us know if you have other questions.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 08-23-2015, 10:24 PM   #3
WOW!! Quick response!! Thank you bunches! I've heard all kinds of horror stories about slide outs on other brands, especially motor homes. I was hoping AS did this as well as they do everything else. I have thought about using those drop-down jacks that go on the corners of pickup campers, attached to the outer corners of the slide out. Do you use the hand-crank stabalizers? Or is there an electric add-on? I'm considering using a battery powered drill to run them up and down. I've had hydraulic jack levelers on a motor home and really liked them.
Old 08-23-2015, 10:34 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I use a Ridgid battery powered drill successfully for 3 years.
Do NOT 'move' the AS with the stabilizers.. only 'hold' the AS in place.
If you can manage to get one, go for it! I would if I were you..
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-23-2015, 10:58 PM   #5
Thanks, cwf!! I've got a craftsman 20V drill and impact driver to do that job. Does anyone install jacks onto the spring mounts to level the coach side to side?
Old 08-23-2015, 11:15 PM   #6
I have not seen the thing in person, only pictures. But it looks like the coach can be used without extending the slide out. So a short stop would be doable without undue effort. But the slide out will make the coach more livable on longer stays. Our first major trip will be a move from N CA to Florida, then house hunting between Tampa and JAX!
Old 08-24-2015, 06:16 AM   #7
jcanavera's Avatar
Fenton , Missouri
Images: 143
Mine came equipped with electric stabilizers. I'm not sure if that was standard on the Classic slides or not.
The stabilizers are there for support, not leveling. Trying to level an Airstream with a stabilizer will torque the frame causing all kinds of problems. Save that kind of leveling for motor homes.
Here's a couple of pictures when mine was new on the lot with the slide retracted. Also a picture of the slide extended. It needs no additional supports under it.
Jack
ID:	246208   Click image for larger version
ID:	246213   Click image for larger version
Jack Canavera
STL Mo.
AIR #56
Old 08-24-2015, 07:58 AM   #8
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Don't fear the slide. If the rig is in good shape look real hard at getting a truly unique and enjoyable AS.
We can advise of other inspection points if you need help.
As with any trailer water leaks ain't no good. Look under and behind everything.
Level first then stabilize then slide out.
What state are you in?
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 08-24-2015, 10:34 AM   #9
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
We have a 2002 30' Classic and have not had one problem with operation or leaking. I use 303 on the rubber seals about once a year to keep them from cracking. Since you can't buy a new slider, the demand is way over the supply. Airstream only made 84 slide units from 2001-2009; according to the info from the factory.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 08-24-2015, 10:34 AM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
To "level" on the "Y" axis, we use "blocks". I then use screw jack tripods to "fine tune" the level and stabilize under the axle area. In our 34' there can be a lot of "bounce"... This stops most of it.
Channing
WBCCI# 30676
Old 08-24-2015, 12:41 PM   #11
1979 29' Ambassador
ruston , Louisiana
I own a 2005 30ft Classic with the slide out. I have only one problem with my slide out. There is a small leak on the front when the slide is in. The leak is so small I haven't done anything to correct it. I just place a small towel and it absorbs the small amount of water. I'm sure the gasket needs replaced or reinforced. The slide works great and we realy enjoy the additional it provides.
One point I would make is the tongue weight on the AS w/so is approximately 1100 pounds. I have a 2014 1794 Toyota Tundra. I talked to a Toyota engineer abt the weight and was told I was very close to being over. I chose to add Firestone air bags and the trailer tows great with no bottoming out. My Tundra tows the AS very well and gets between 13 and 14 mpg.
wcgnemi is offline   Reply With Quote
Old 08-24-2015, 03:06 PM   #12
jcanavera's Avatar
Fenton , Missouri
Images: 143
That hitch weight is important to note. My Gm van when built only came with a 1000 lb receiver. I had the dealer put on a 1,400 lb Hidden Hitch along with a 1,400 lb rated Equal-I-zer. The 30' slides are heavy and don't under estimate the vehicle you will need to pull with. Since the Ozarks have their share of steep grades, I opted a GM van equipped to tow up to 9,900 lbs.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 08-24-2015, 08:15 PM   #13
Richard
2006 30' Classic S/O
Merced , California
I have a 2006. No leaks, no problems, Use your stabs. Yep it's heavy on the hitch. If you have a GM product get a better hitch. I use a Reese Straight Line and it tows straight. If you have Disk Brakes let me know for some hints and fixes.
kleimanr is offline   Reply With Quote
Old 08-25-2015, 02:30 AM   #14
Thanks kleimanr! I'll get the dealerships (GMC and AS) to look at the factory hitch and let me know what is actually installed. I expect to need an upgrade to my installed hitch, or maybe a new one altogether. Guess I should goto the hitch threads to read up on them! Somewhat more complicated than just buying a new SUV!
fredflyer
One Who Flies/Flew FRED
FRED is the C-5 Galaxy
1991 Fleetwood Limited
AR# 100575
2005 airstream 30 classic limited slide out eBay Watch Airstreams on eBay 0 08-12-2013 08:00 PM
2005 Airstream Classic 30' SO Travel Trailer with Slide out and Hensley Arrow eBay Watch Airstreams on eBay 0 03-19-2013 07:10 PM
2005 Airstream Classic 30' SO Travel Trailer with Slide out and Hensley Arrow eBay Watch Airstreams on eBay 0 03-06-2013 05:00 PM
2005 Airstream Classic 30' Travel Trailer w/slide out eBay Watch Airstreams on eBay 0 02-02-2013 05:50 PM
2005 Airstream 30' Classic w/Slide Out, Beautiful Trailer. LOADED! Must See! AZ. eBay Watch Airstreams on eBay 0 05-24-2012 06:30 PM
