Old 07-10-2018, 04:12 PM   #1
1978 31' Sovereign
Elk Mound , Wisconsin
Skin Preperation
Greetings All;
I recently removed the inner skin so I could pound out and repair damage from a tree falling on our Sovereign. Things are looking pretty good. I was thinking of coating the whole front skin (on the inside) with something to stiffen it and quiet it. Something like automotive rubberized undercoating. I also need to apply something to help the insulation stay in place while I re-install the inner skin. Any ideas? Thanks for the help.
DrJimmy is offline   Reply With Quote
Old 07-10-2018, 08:36 PM   #2
1966 22' Safari
Fredericksburg , Texas
I’m sure there are dozens of recommendations on the Forums. I can just add what we’ve done.
-layer of Prodex (applied with 3m spray adhesive to the inside of outer skin)
-1/2” x 2” wide strips of styrofoam (spacing for wiring and part of a dead air space, applied with double stick tape)
-layer of Prodex and tape any joints with aluminum tape (creates the dead air space, applied with double stick tape)
-final layer of 1/2” styrofoam sheet insulation
-I’m painting the inside of the inner skins with Thermocels Insulating Paint additive mixed into Kilz 123 Bullseye. This is supposedly a thermal break, sound barrier and a bit of insulation. Sounds like a lot and overkill. It is. But I have the time and the 55 is what we’ll use on most of our trips. Good luck, Bubba
Bubba L is offline   Reply With Quote
Old 07-11-2018, 10:00 PM   #3
Eric 26 Argo's Avatar
Knoxville , TN
Hey Doc. You may want to look up Lizard Skin Ceramic Insulation as an option. Once you do that look up options for Lizard skin on youtube. The concept is sound and provide a thermal barrier. I was looking at the idea when I was building a Ramcharger expedition vehicle for the ceiling. Didn't get past concept because I was talked out of the vehicle.
Eric 26 Argo is offline   Reply With Quote
Old 07-15-2018, 05:18 PM   #4
1978 31' Sovereign
Bed Liner
Thank you for the ideas. The Lizard Skin idea brought me to look at spray-on Bed Liner for trucks. My thinking is that the bed liner would add rigidity to the compromised aluminium skin, and add some sound isolation. My concerns are that it would stay bonded to the aluminum, that heat would not break it down, and that it would not give off toxic fumes.
I figure, once I get a good base of bed liner on the aluminum, I could use spray adhesisve to hold the fiberglass batting in place to do the thermal insulation.
I am still researching this, but I hope I am on the trail to a solution. I picked up some Loctite Gutter and Flashing caulk to seal my seams again, and then we will take it from there.
Old 07-23-2018, 06:38 PM   #5
1978 Argosy 27
1976 Argosy 26
Elk Rapids , Michigan
I have heard good things about the Flex-Seal type of rubberized paint as far as sealing leaks.
I would use two layers of Reflectix for insulation. It's easy to work with and pretty cheap. If you want to get fancy use some foam insulation material to make an air gap between the layers. Tape should hold it in place while you rivet.
There's no way I would ever put that pink fiberglass back into one of these trailers. I just removed the front half of my belly pan and that stuff gets pretty nasty....
John
matthewsx is offline   Reply With Quote
Alum. Skin Repair 74Tradewind Ribs, Skins & Rivets 16 07-20-2018 02:55 PM
interior skin scrap for exterior skin patch? whatsherface Ribs, Skins & Rivets 1 06-12-2010 08:56 AM
Sealing exterior skin panels with Lizard Skin BB 55 Bubble Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 11-21-2006 05:50 PM
Under Belly Skin Restoration... Andy R Cleaning, Stripping & Polishing 2 04-08-2002 12:46 PM
Re-attaching cabinets to the interior skin. Andy R Cabinets, Counter Tops & Furnishings 5 04-07-2002 03:54 PM
