Old 11-06-2011, 09:05 PM   #1
1995 25' Excella
ocala , Florida
Skid plates?
Hello,
My wife and I just purchased a 1995 25 ft Excella Classic.
Under the rear on each side there is a short section of 1/4 inch angled steel about 12 to 15 inches that seems to come off of the frame. Are these skid plates ? One is very rusted and I was wondering if it is hard to replace and where I can purchase one. This is my first post here and I will appreciate any advice.
Thanks, Scott
mybyebye is offline   Reply With Quote
Old 11-06-2011, 09:08 PM   #2
Originally Posted by mybyebye View Post
Hello,
Thanks, Scott
Those "are" skid plates.
You can use most any kind of steel "C" channel, as long as the height stays the same.
Old 11-06-2011, 10:38 PM   #3
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
You should be able to go to any welding shop and they can cut off the old rusted/damaged skid(s) and weld on new ones.
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 11-07-2011, 06:01 PM   #4
1995 25' Excella
ocala , Florida
Thank you for your help with this. I have another question. The skid plate that is rusted out has a pretty heavy gauge ground wire attached to it. I guess it is coming from the 110 volt breaker box above in the rear. Is is possible that this is causing some type of electrolysis? I am also worried that the rust might be carried on through to the frame member above.
Thanks again, this is a great resource.
Scott
Old 11-07-2011, 06:47 PM   #5
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
You need a digital camera and use the add-a-photo option to share the scene - one picture is worth 1000 words and all that rot!
My 1973 has the primary ground connection about two feet in on the frame in the same area - there is an extra chunk of 'U' shaped steel frame welded on that protects the black tank as well as acting like a drag shoe... and yes, that was corroded up pretty fiercely from the city water connection being right there as well as the holding tank and the corroded ground lug...
Old 11-07-2011, 07:50 PM   #6
1995 25' Excella
ocala , Florida
link to photo of skid plate with ground wire in center. Other skid plate is like new.
Is it possibly electrolysis ?
Thanks, Scott
https://files.me.com/vispro/ub1zar
Old 11-07-2011, 08:37 PM   #7
CanoeStream's Avatar
St. Cloud , Minnesota
They're kinda like squealers on your auto & truck brakes. When they make noise, don't go any further. They will deform thank goodness. You'd tear off your rear bumper if they weren't there. Don't push 'em too far.
5 meter Langford Nahanni
Old 11-08-2011, 07:20 AM   #8
Wabbiteer's Avatar
1972 29' Ambassador
I'm not familiar with the 90's layouts... where is the black & gray tanks?
I found a split in the top of my '73's BW holding tank, the not-so-small amounts of salt & acids usually contained therein had destroyed the galvanized BW tank outer box and gravity led it to the street side... maybe its just that piece of iron had oil on it and the paint failed early... or something more sinister..
Old 11-08-2011, 09:26 AM   #9
1995 25' Excella
ocala , Florida
This is sounding very scary to me. We just bought this unit. Do I need to peel the skin off the bottom and expose frame to see what is going on.
Old 11-08-2011, 10:22 AM   #10
If the trailer has been near salt water, it's then "very wise" to inspect the chassis.
It does not take salt very long to cause frame damage.
Old 11-08-2011, 12:19 PM   #11
Scott J-24's Avatar
Andy,
When you say "near" how near do you mean? Are you talking <1/4 miles, 1 mile, 3 miles?
WBCCI #1215
Air #54601
Old 11-08-2011, 12:37 PM   #12
1995 25' Excella
ocala , Florida
It does look like a leak from the bumper seal might have caused this. When I pull out the storage drawer on the rear bumper and look inside I can see where water has leaked into the area in the past. Some surface rust on frame members but does not look to deep. Do I need to remove bumper cover to drop the bottom skins for a better look? 1995 25ft Excella Classic.
Thanks for the help.
Old 11-08-2011, 12:55 PM   #13
Originally Posted by Scott J-24 View Post
Andy,
Parking within 50 miles of salt water, can and does harm an Airstream and Argosy.
Depending on how close, the damges happen slowly or fast.
The first damage is to the aluminum, since salt is an acid to that metal.
The next is the chassis.
Look at any older Airstream that has aged out clearcoat, that has been exposed to salt in the air, or salt water, and is very easy to see all the little zigzag etchings in the metal.
Same happens to the chassis.
Old 11-08-2011, 04:13 PM   #14
Wabbiteer's Avatar
1972 29' Ambassador
Acid rain is another silent killer - pH readings in rain and fog water of below 3 are seen in industrialized areas. Aluminum will self-protect with its oxide layer but Iron will disappear into a brown sludge/dust where its been incubated in a perpetually moist & acidic environment. Acid activity dispersed into the atmosphere also clings to dust or smoke and falls out dry which will give morning/evening dew cycles a double-punch.
People on the West Coast are not immune, Chinese coal power plants lob huge amounts over that Pacific puddle which falls out when hitting the mountains.
Do Henschen Axles Use Standard Backing Plates? perryg114 Brakes & Brake Controllers 27 10-23-2011 07:07 PM
Texas Year of Manufacture License Plates Bambi_Bandit Title, VIN & Registration 15 06-18-2011 10:52 PM
'65 Texas Plates bwaysteve Clearcoat, Exterior Paint & Trim 10 06-13-2011 03:44 PM
Custom vintage plates SpaceEgg Title, VIN & Registration 4 06-08-2011 04:42 PM
