Old 05-30-2004, 09:41 AM   #71
Images: 59
Chuck,
I think installing the plywood lengthwise makes more sense. Plywood has twice the bending strength lengthwise than it does across the width. Lengthwise (parallel to the frame) installation would make the chassis stiffer in the fore-aft direction.
I think using the elevator bolts, staggered, spaced every six inches on the new center strip would give you a very strong connection. I don't think biscuits would add a whole lot.
I believe Airstream laid the sheets crosswise for ease of assembly, not for strength.
Added thot: You could stagger the sheets from side to side, by installing the first sheet with the edge on the steet side and a narrower (40" wide) sheet on the curb side. Then the next pair, put the 48" width on the curbside and the narrow piece to the streetside. And the third pair is the same as the front. This requires moving moving the 'center strip' from side to side, but it avoids having any "four corner" joints, which a flooring installer will tell you is a boo-boo.
Also, if you can get 7-ply 'plyform' or similar plywood rated "Struc-1", the floor bending strength is twice what you would get from 5-ply sheathing.
Old 05-31-2004, 07:56 AM   #72
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Don
Is 5/8" plyform or struc-1 easy to find at most lumber yards?
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 05-31-2004, 09:01 AM   #73
Images: 59
Ken,
Not really. Some lumber yards have Struc-1 in OSB if you want to use that. I had to look around and finally e-mailed the manufacturer for a list of local yards. I went to a company in Minneapolis that stocks only plywood, for large contractors.
I guess I'm lucky to have time to look for stuff like this.
Here's some info on plywood. http://www.apawood.org/pdfs/managed/X505-R.pdf
Old 05-31-2004, 09:28 AM   #74
Ken J's Avatar
Durango , Colorado
Images: 14
Don
You are just an enyclopedia of information! I don't want to use OSB - I'll have to ask around here. Don't expect to find much here in the middle of nowhere, but you never know.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 05-31-2004, 05:47 PM   #75
funchucky1's Avatar
Riverhead , New York
Hmmmm.
I'll be shopping for ply tomorrow.
I'll let you know what I come up with around here....
funchucky1 is offline   Reply With Quote
Old 06-03-2004, 07:20 PM   #76
funchucky1's Avatar
OK. I can get CDX ply for $22.99 a sheet.
Or AC with a mahoghany face for $43.20.
Or BC pine for $29.99.
Or AC pine for $32.99.
Or AB marine for $72.31 (but that's 3/4"...I haven't found 5/8" here...
Or I can get lots of OSB.....
Anyone? Anyone?
Old 06-04-2004, 02:39 AM   #77
upallnight's Avatar
Chuck
Looks like you'll be using CDX or BC Pine, where did you get the prices? Home Depot? If your like myself and a few other poverty stricken A/S owners you won't be using marine grade.
Leonard
Leonard
LotalaborAZ
upallnight is offline   Reply With Quote
Old 06-04-2004, 04:40 PM   #78
funchucky1's Avatar
I have yet to decide.
The AC is nice stuff...supposedly has superior glue, according to the lumber guy....
No, all prices were from lumberyards, except the best CDX deal, if I recall, was from Menards.
I may not worry so much - I plan to epoxy the edges and one face....
I think I'm going to go lengthwise for two sheets per side, then one across. Suggestions - do the one across in the front or the rear?
Old 06-04-2004, 05:00 PM   #79
Images: 59
Chuck,
I would defintely go at least BC, although AC is only $3/sht more. Try to get "Group 1" face ply. Group 1 is Doug fir, pine, and some other plies. They are stronger than group 2. Stay away from the Luan faced.
Running the two center sheets lengthwise and the end panels crosswise sounds like a good idea. Most of the bending stress is over the axles, and placing the center sheets with their highest strength perpendicular to the load is a good plan. On the other hand, I'm planning to run all the sheets parallel to the frame so that I don't have a joint located near the axle. I don't think it will make much difference though.
Old 06-04-2004, 08:14 PM   #80
till's Avatar
Lisle , Illinois
Images: 108
5/8 void free. You are going to want at least one side to be smooth for your floor surface. You are also going to want to make sure that there are no spaces where you attach to the frame and outrigers.
Just my .02.....
That and when you change the floor thickness, you change how the belt line attaches and how the belly skin ataches. Many new holes to seal....
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 06-04-2004, 11:37 PM   #81
upallnight's Avatar
Chuck
Here is the way I am replacing my floor
http://www.airstreamphotos.com/photo...sort/1/cat/500
Leonard
Leonard
LotalaborAZ
Old 06-05-2004, 06:31 AM   #82
Images: 59
Leonard,
I love picture #4. You should figure out a place to mount them permanently.
MORE POWER!
Old 06-05-2004, 07:13 AM   #83
Ken J's Avatar
Durango , Colorado
Images: 14
Leonard
Great pictures! First I've seen a jack from floor to ceiling - thats innovative - most floor replacements I've seen just shove the plywood under the body - did you find that the jack lifted the body a bit?
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 06-05-2004, 08:58 AM   #84
upallnight's Avatar
Don
The only problem is I would need a Kenworth to pull my A/S. MORE POWER!!!!
Ken
The jack is a large screw jack out of a pickup I assume, it came with the stuff in the trailer, I just screwed it by hand so i could control the lift better, the shell came right up.
Leonard
Leonard
LotalaborAZ
We're back from Colorado! KY Girl Our Community 4 08-06-2004 07:10 PM
There and Back Again:) maxandgeorgia Off Topic Forum 2 05-10-2004 09:43 PM
math wiz's: how steep a slope can I back up? Chuck Towing, Tow Vehicles & Hitches 12 05-05-2003 01:18 AM
