Old 08-03-2016, 09:43 PM   #1
1973 31' Sovereign
hallsville , Missouri
Shell weight of 1973 Sovereign LY
Hello AF gurus!
I am a complete AS newb, and in my usual form I dug in deep and bought a beast in need of the Full Monty. In the interest of bragging rights as much as economy I want to do as much of the restoration as possible my self. I've been gutting and as I had suspected the subfloor wants replaced, so the body must come off.
I have a horse barn with a center isle that will easily accomodate the AS, and working in there will make the winter much more productive. I was wondering if I could take further advantage of the bulding by using the cross beams of the barn to hang the shell from (after bracing the inside of course).
Any clue how much the outer skin and windows of a 31ft 1973 Sovereign Landyacht might weigh? It'd be real handy, unless I pull down the barn on top of the trailer. Then not so much...
themostream is offline   Reply With Quote
Old 08-15-2016, 09:21 AM   #2
ericpeltier's Avatar
Superior , Colorado
My estimate for my 33' Streamline shell with window glass intact was 20lb lineal foot. In Missouri you might have snow load requirements of 20lbs sqft, so 600-700 lbs is really not much.
1972 33' Streamline Emperor Crown Imperial
1949 30' Spartan Royal Mansion
2012 Nissan Armada
Most of China
ericpeltier is offline   Reply With Quote
Old 08-15-2016, 09:35 AM   #3
1977 31' Sovereign
2005 30' Safari
North Port , Florida
Under 1000#s definitely. I scrapped a WB 34' years ago and didn't have a 1/2 ton
cliffcharb is offline   Reply With Quote
Old 08-15-2016, 09:43 AM   #4
Al Boondy's Avatar
1973 31' Excella 500
Vicksburg , Mississippi
Was barn intended to store hay on top floor? Do you have a picture of inside barn?
If you can you use 3 points to lift shell it might help to build one gantry and pick front and back using barn.
I how did you determine 20#/ft? I've been wondering what my shell weighs!
Al Boondy is offline   Reply With Quote
Old 08-15-2016, 10:01 AM   #5
Superior , Colorado
I just imagined a 1 ft section, and what it might weigh if I picked up a 1' section. On the high side, I guessed at 20lb. VERY scientific.
2012 Nissan Armada
Most of China
Old 08-15-2016, 10:51 AM   #6
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
What has become the default standard home-made set of wooden gantry frames is usually executed with a 4x4 as cross bar located over the fore and aft roof vents. I have seen many pictures of shells your size being lifted with such a frame and have heard of no mishaps.
So judge your barn construction: Do the cross beams you intend to use equate to the strength of a pair of horizontal 4X4s? Consider current loading as well (ie., is the hay loft full of hay, or are these just rafters). Also, most people who lift their shells from above (myself included) do not use any bracing, and everything works out just fine. The shell really will hold its shape without bracing.
good luck!
Old 08-15-2016, 12:03 PM   #7
Superior , Colorado
I have my 33' streamline in the air right now. I have it braced on the inside. I had to temporarily move a brace, and, I can attest that there's quite a bit of force on the brace. For a long trailer like mine, I think bracing is required.
2012 Nissan Armada
Most of China
Old 08-15-2016, 11:55 PM   #8
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
.032 aluminum weighs in about .46 pounds per square foot, .040 about .57sqft. There are plenty of overlaps and there is a .040 panel above the hitch A-frame. Your wiring harnesses will probably be around 100 pounds, add in roof A/C if you have it, 5x or better sqft for the entry door. I think 4x the sheet weight for the window openings would be close enough. You'll be leaving the C and double-C channel on the floor, guesstimate the ribs and stiffeners...
My '73 27' weighed more than I thought it would, you'll appreciate having the shell safe but might be missing the best part of using portable derricks to pull shell off... using them to manipulate the frame for ease of access. Don't think twice, shimmying around on your back trying to weld and paint is such a pain and time waster you'll kick yourself for not doing it once the bruising and soreness has faded.
Old 08-16-2016, 07:23 PM   #9
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
My 27' shell weighed a lot more when I first hoisted it because it was still somewhat attached to the frame. Oops. Those hidden rivets are tough to find.
TheGreatleys is offline   Reply With Quote
Old 08-17-2016, 10:16 AM   #10
Superior , Colorado
Oh, I know that problem too well. I'm still baffled what the last thing holding mine down was. I worked for an hour to find it, and then it just popped off when I was doing something else! 81 lineal feet of trailer perimeter has a lot of rivets and surprises.
Eric
2012 Nissan Armada
Most of China
Old 08-23-2016, 07:08 PM   #11
1973 31' Sovereign
[/QUOTE] My '73 27' weighed more than I thought it would, you'll appreciate having the shell safe but might be missing the best part of using portable derricks to pull shell off... using them to manipulate the frame for ease of access. Don't think twice, shimmying around on your back trying to weld and paint is such a pain and time waster you'll kick yourself for not doing it once the bruising and soreness has faded.[/QUOTE]
I am wanting to hang the shell in the barn so I can pull the trailer out from underneath it and flip it over, weld, paint, or whatever it needs. I thought I would still build some gantries for that. I'm also looking forward to working on putting it back together INSIDE this winter.
I have considered building gantries in the barn, but didn't want to take up the whole isle way. But just using one as a central support is a great idea Al.
Now I just have to climb on top ant take off the AC without leaving a big butt shaped dent in the roof!
Thank you all for helping me hash this out.
Old 08-23-2016, 07:14 PM   #12
1973 31' Sovereign
I'm also curious about the most logical way to detach the shell and get to these "hidden rivets". Belly skin, banana wrap, interior skins? What order? Where do I start?
sovereign
Camper Shell or No Camper Shell for Pickup TV KJRitchie Tow Vehicles 28 03-14-2017 07:23 AM
Shell on shell off? Newbie Dustycowgirl Repairing/Replacing Floor &/or Frame 28 03-12-2015 12:12 PM
HELP! Can I fix sagging Outriggers with shell on? Or just pull the shell? Mixter Repairing/Replacing Floor &/or Frame 3 01-24-2013 11:59 AM
Shell on? Shell off? Althea68 Repairing/Replacing Floor &/or Frame 55 04-01-2011 09:35 PM
Shell Off vs Shell On Summary mbatm01 Repairing/Replacing Floor &/or Frame 82 01-09-2006 05:46 PM
