Old 05-25-2004, 01:49 PM   #29
Tripp
Profile:
Images: 55
Andy & Toaster,
Thanks! Got it! I too will end up replacing the majority of my "c" channel as there are some poorly done repair attempts and some of the channel is actually missing. Once I get started, I'm sure I'll have some questions!
Tripp
Tripp is offline   Reply With Quote
Old 05-26-2004, 05:51 PM   #30
funchucky1
funchucky1's Avatar
Profile:  Currently Looking...
Riverhead , New York
Stuck Again!
OK, almost ready to roll the frame out from under the (lifted) shell.
Plan today was to take off the inner wheel humps. Then roll 'er out. (There's enough clearance for just the tires, I think, but not for the humps....I'll have to lift the front an extra foot or so, and that's not too easy or safe)...
How do I get these out / off??
Inner wheel wells have been out....insulation out....screws holding floor down around wheel wells out....what are they attached to??
My time is short nowadays, I'm in a crunch. These holdups are killin' me!
-Chuck
Thanks in advance!
funchucky1 is offline   Reply With Quote
Old 05-26-2004, 05:55 PM   #31
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
The wheel wells are held down by the floor. There is no removing them till the floor is up. The have to go on first to seal them to the frame to protect the floor.
How much do you lack from clearing? You can get about 3 inches by letting the air out of the tires.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 05-26-2004, 06:05 PM   #32
funchucky1
funchucky1's Avatar
Thanks, Toaster.
Well, you can see the lumber holding the front up. It is a couple inches (maybe 5) off the floor as it sits. But see the wheel well zone? The high point of the wheel wells is several inches above the wheel well cutouts that you see (in the shell) - and those cutouts are also several inches (additional) higher than that 2x4 in the front, under which the deal needs to pass.
Whew.
Letting the air out sounds very good. It will lower the frame 3 inches or so, as you say. And I need to replace the tires eventually, anyway.
But it will still require at least 5 inches of additional front lift, I expect.
I can lift one side (or the other) the 5 inches or so that I need myself, but I don't know that I have a neighbor capable of lifting the other side at the same time. And then I'd need someone else (the wife, I suppose) to drive the truck at the same time to pull the frame out....
Old 05-26-2004, 06:10 PM   #33
funchucky1
funchucky1's Avatar
But I do suppose that if I can't get 'em out, then I can't get 'em out.
Are they steel?
They seem more steely than aluminumy.
Guess I'll just have to lift it higher....
Old 05-26-2004, 07:16 PM   #34
markdoane
Profile:  , Minnesota
Images: 59
Chuck,
I feel your frustration. I went through the same when I lifted mine last fall. It was the scariest part of the whole operation. It was a real struggle to lower it back down. Be careful. If it slips you could lose an arm or leg.
Non-contributing deadbeat.
Old 05-26-2004, 07:22 PM   #35
summerkid
Profile:  1962 16' Bambi
1959 18' "Footer"
1964 19' Globetrotter
Kankakee , Illinois
chucky1 ....
... are you SURE you can't just wait till the moraine view rally, when some of us probably would be happy to scoot over & help with either the off or on part?
summerkid is offline   Reply With Quote
Old 05-26-2004, 08:27 PM   #36
funchucky1
funchucky1's Avatar
Rivet
Well, Don, compared to mine, it looks like your floor is in great shape! You obviously took your shell off for fun, not out of necessity .
I have said many times that the worst part, I expect, will be lowering the shell.
I'll be counting all limbs frequently.
Well, Summer, I don't know.
I'm REALLY short on time now (not that I don't have time to do it, but I need to get it done quickly).
I expect to lift the shell and pull the frame out on friday. This friday.
That'll give me time to get the floor off, have the sandblasting & welding done, and POR-15 the frame. And then replace the floor, U-channels, and bellypan.
THEN, I'll be ready to put it all back together.....hey, maybe you've got a good idea. I probably can do the shell replacement during the rally.
In fact, I can put 6 full-grown Airstreamers in my truck and get 'em here!
You're really thinkin'!!!
Old 05-27-2004, 07:48 PM   #37
funchucky1
funchucky1's Avatar
WooHoo!
Or...."Oh, no!"
Well the shell is off. it's up in the air on the lawn...
And the frame is on the street.
What a pain!
In large part, though, to the creative place I had chosen to park the trailer.
We'll see how much I can get done in the next 2 days-- floor removal and bellypan removal.
Who's going to the rally at Moraine View that wants to come help put the shell back on??
Old 05-27-2004, 07:52 PM   #38
summerkid
1959 18' "Footer"
Kankakee , Illinois
I'll help, Chucky1!
How much time, how many bodies, are you talking? Friday or Saturday?
Old 05-27-2004, 08:01 PM   #39
funchucky1
funchucky1's Avatar
Talking Thanks, Summer!
Well, as many people as would like to see a shell off
I don't know. I'll supply the pizza and beer.
The challenges, I expect, will be:
-Getting the frame under the shell....properly lined up.
-That includes getting the shell up high enough to get the frame under.
-Lowering the shell....slowly!
-A person at each corner (minimum!) when placing the shell would help ensure that the skins don't snag (on each other, the U-channel, etc).
I just have to get the frame ready by then, and THAT will be the biggest challenge!
I'd make the plan for whatever day people would like to come!
And...I'm expecting to go to the rally (at least to visit). I'd be happy to pick up 3 or 4 or 5 people and bring 'em here to do it (hopefully just for a couple of hours) and then bring them back to the rally! I'm less than 40 miles from the park.
Old 05-27-2004, 08:03 PM   #40
funchucky1
funchucky1's Avatar
Ahhh, yes. I know the pics are crappy, but...
Old 05-27-2004, 11:00 PM   #41
upallnight
upallnight's Avatar
Profile:
Question Floor Width
Chuck and Don and anybody else that has done a floor replacement :
Do you guys think you could post the measurement of the width of the floor? ie the plywood. I didn't have the luxury of having a complete floor to rip out. PO had patched the whole perimeter of the floor without properly attaching it to the walls, all that was holding my shell down was the wheel wells. Thanks.
Leonard
Leonard
LotalaborAZ
upallnight is offline   Reply With Quote
Old 05-27-2004, 11:12 PM   #42
markdoane
Images: 59
The floor width is 88.0000 inches.
(Make sure the plywood is very dry)
We're back from Colorado! KY Girl Our Community 4 08-06-2004 07:10 PM
I wanna come back, but don't think I can. Impala SS Guy For Sale & Wanted 13 08-03-2004 01:42 PM
There and Back Again:) maxandgeorgia Off Topic Forum 2 05-10-2004 09:43 PM
math wiz's: how steep a slope can I back up? Chuck Towing, Tow Vehicles & Hitches 12 05-05-2003 01:18 AM
