Old 05-23-2004, 06:33 PM   #15
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Originally Posted by psychpw
When you say through the belly pan but not the outer skin what besides the belly pan are they attached to, the rib?
U-channel and ribs. The pan is on before the body.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 05-24-2004, 08:48 AM   #16
funchucky1
funchucky1's Avatar
Profile:  Currently Looking...
Riverhead , New York
Help again!!
OK.
The rear and the middle are up....
But the front's stuck.
I suspect it has to do with that reinforcing plate.
Do I need to drill out all the rivets that hold it from the front???
Other ideas?
(What does the plate attch to, beside the outer skin?)
Help!
-Chuck H
funchucky1 is offline   Reply With Quote
Old 05-24-2004, 09:24 AM   #17
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
The front plate holds the shell to the A-frame and chassis.
All of those rivets must be removed.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 05-24-2004, 09:26 AM   #18
funchucky1
funchucky1's Avatar
Thanks, Andy.
It'll be done in 20 minutes.
I should probably drop my jacks a little first, and take the stress off.
Anyone wnat to tell me - again - when to use Vulkem, and when to use Sikaflex?
My local A/S dealer carries Sikaflex....but not Vulkem.
Old 05-24-2004, 09:27 AM   #19
59toaster
59toaster's Avatar
Atlanta , Georgia
Images: 22
Ohh yeah...got to drill all those out. Thanks Andy!
1959 22' Caravanner
Atlanta, GA
Old 05-24-2004, 10:23 AM   #20
funchucky1
funchucky1's Avatar
It's off!!!!!!!!!!
Old 05-24-2004, 11:02 AM   #21
Commercial Vendor
Whoooooopeeeeeeeeeeee.
Now your fun really starts.
"Don't" lose the reference points, or change the dimensions of the floor, or it's thickness.
Inlandrv.com
800-8777311
Old 05-24-2004, 12:56 PM   #22
upallnight
upallnight's Avatar
Profile:
When I removed the floor in my 63 Soverign it was 5/8" plywood, I ordered Service Bulletin#1 and #29 from A/S, in the cutaway drawing on #1 it shows 3/4" plywood, What do you recommend for replacement?
Leonard
Leonard
LotalaborAZ
upallnight is offline   Reply With Quote
Old 05-24-2004, 01:36 PM   #23
Commercial Vendor
Changing the plywood to a greater thickness is OK, provided you are willing to refit the entire shell to the floor again.
If you expect to use the same rivet holes with an increase in floor thickness, it cannot be done.
New holes will have to be made.
Inlandrv.com
800-8777311
Old 05-24-2004, 01:38 PM   #24
funchucky1
funchucky1's Avatar
Andy, your sarcasm hurts. Owww.
Well, I know the floor is 5/8". And I can get good 5/8" ply here, so I'm good with that.
I can imagine what the dimensions should be.....but the floor is nonexistent in the front and the back (where it counts). Thank the P.O. for that. I did make decent cardboard templates of the floor (to the U-channel) before I took out all the rivets. Hopefully it will work out.
I do sincerely dread attempting to reassemble it.
I plan to count my fingers every few minutes.
Andy, do you refer to the imaginary reference points that you're imagining I'm making?
Or do you mean to suggest that it's good that I didn't remove the little steel angles, for instance, and that I'll measure where they are and replace them on the new floor?
Old 05-24-2004, 02:01 PM   #25
Tripp
Profile:
Images: 55
Andy,
I'm going to be doing this on my 56 this fall. When you refer to making new holes, are you referring to holes in the "c" channel or in the body itself? I assume its the "c" or "U" channel.
Tripp
Tripp is offline   Reply With Quote
Old 05-24-2004, 03:52 PM   #26
Commercial Vendor
Tripp.
And the shell.
Inlandrv.com
800-8777311
Old 05-24-2004, 06:53 PM   #27
59toaster
59toaster's Avatar
Atlanta , Georgia
Images: 22
Tripp.
And the shell.
Guess I did it all wrong.
I did not drill a single new hole in our exterior shell when I went to 3/4 ply. The U-channel also moves up when the deck gets thicker. Only thing that doesn't move up is the belly pan.
I enlarged the existing holes to 5/32 to accept the Olympic Rivets. I then drilled through the new belly/bannana and into the U-Channel. I ended up having to pay a machine shop to make 8ft of new to replace some that was beyond salvage. Much of it was relocated because hte new material U-Channel was made of a thicker material so I use to old in the corners since I needed to notch it for the curves.
The front plate needs to be redrill because it sits on the frame
Where in the shell was I supose to drill new holes and why?
1959 22' Caravanner
Atlanta, GA
Old 05-25-2004, 08:37 AM   #28
Commercial Vendor
If a person wanted to use "all" the original underbelly material, then increasing the thickness of the floor will not allow the original holes to match.
Different story if new metal is being used. In that case, is doesn't matter.
Inlandrv.com
800-8777311
We're back from Colorado! KY Girl Our Community 4 08-06-2004 07:10 PM
I wanna come back, but don't think I can. Impala SS Guy For Sale & Wanted 13 08-03-2004 01:42 PM
There and Back Again:) maxandgeorgia Off Topic Forum 2 05-10-2004 09:43 PM
math wiz's: how steep a slope can I back up? Chuck Towing, Tow Vehicles & Hitches 12 05-05-2003 01:18 AM
