Old 11-13-2015, 11:31 PM   #1
FlyingCloud3's Avatar
1950 21' Flying Cloud
1960 22' Safari
Newland , North Carolina
Question shell replacement without a floor template
I've got the shell off of my 1950 Flying Cloud #7002. The floor it was lifted off was almost entirely rotten. I do have a decent piece that was the rear curve. But I'm pretty much going to be starting from scratch to determine most of the footprint of the new sub-floor.
I can see that there is some potential flexibility as far as exactly where the edge of the floor/c-channel could wind up being. I suppose to some degree it doesn't matter exactly where it lands as long as it is all fairly square and level and the width is about right. I recall the width was not consistent front to back originally.
My plan is to set the shell on the new floor and trace/draw what looks like a symetrical and square shape for the floor/c-channel. I'll cut the shape out then I'll set the shell back on and see how it fits.
I'm sure some of you have some tips for me. I'd like to nail it in one shot if possible. I'd rather not have to set the shell down more than twice if I can help it.
Thanks!
Ryan Franks
1974 Sovereign Land Yacht 31'
1950 Flying Cloud 21'
1960 Safari 22'
Newland, NC
FlyingCloud3 is offline   Reply With Quote
Old 11-13-2015, 11:42 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
IMHO, the only way you are going to get it truly right is with trial assembly.
All in all placing, marking, cutting, repeat.... Etc.. Isn't going to add a lot of time and effort to the project as a whole.
Resign yourself to doing this several times, and if you only have to do it once or twice it will feel like a big win...
Brevi tempore!
Old 11-13-2015, 11:46 PM   #3
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Oh, By the way, if your front c channel is off and true to shape, it will make a nice template for your front cut, you have the back, and the sides are straight. This will give you most of what you need.
Brevi tempore!
Old 11-13-2015, 11:48 PM   #4
1960 22' Safari
good point J.
I agree that's the right attitude!
the c-channel is all just bits and pieces...not much to go on there.
Ryan Franks
1960 Safari 22'
Newland, NC
Old 11-14-2015, 04:48 AM   #5
2005 25' Classic
1986 32' Excella
1965 22' Safari
Newark , Delaware
I made a template of the floor curves out of cardboard. I made sure it fit correctly under the C channel. Then I traced it and made the floor with 3/4 inch plywood. Fits perfectly.
Chatooga11 is offline   Reply With Quote
Old 11-14-2015, 05:00 AM   #6
65CV's Avatar
Western , Massachusetts
Frank Yensen does a great blog on restoration topics. It might be a little late to refer you to this post, but hopefully it has some tips that may help.
I learned a lot about scribing and making panels from him.
65CV is offline   Reply With Quote
1976 tradewind can you replace floor without taking the shell off? jeffshaw Floor Finishes 3 06-03-2015 07:57 AM
Creating a replacement floor template from a sketchy predecessor... KCN Repairing/Replacing Floor &/or Frame 5 08-09-2012 09:10 PM
Help --need a '67 floor template pinkflamingoes Repairing/Replacing Floor &/or Frame 17 08-01-2006 02:11 AM
removing floor without removing shell nevisstudio Repairing/Replacing Floor &/or Frame 11 07-24-2005 10:47 PM
When lacking a floor to make a template... JrnymnJay Repairing/Replacing Floor &/or Frame 6 11-30-2002 06:28 PM
