Old 09-08-2015, 09:22 AM   #15
Eric H's Avatar
1974 23' Safari
1947 25' Spartan , Manor
I would say shell off. Everything will be much more solid if you start at the frame and work up. You'll be more easily able to check and repair where the shell meets the floor and get a good contact. Once you open everything up the frame could be worse than expected... this is both good and bad, bad because now there's a lot more work to do, good because now it will be solid.
Eric H is offline   Reply With Quote
Shell on? Shell off? painterfam Repairing/Replacing Floor &/or Frame 11 05-30-2015 03:44 PM
Shell on shell off? Newbie Dustycowgirl Repairing/Replacing Floor &/or Frame 28 03-12-2015 12:12 PM
HELP! Can I fix sagging Outriggers with shell on? Or just pull the shell? Mixter Repairing/Replacing Floor &/or Frame 3 01-24-2013 11:59 AM
Shell on? Shell off? Althea68 Repairing/Replacing Floor &/or Frame 55 04-01-2011 09:35 PM
Shell Off vs Shell On Summary mbatm01 Repairing/Replacing Floor &/or Frame 82 01-09-2006 05:46 PM
