Old 01-28-2018, 07:43 PM   #1
1976 25' Tradewind
Cottage Grove , Oregon
Shell on floor replacement question
Working on removing the old wood rot sub floor. Question for one of you Airstreamer that have removed and replaced there sub floor before with the shell on approach. Can you remove all of the plywood at the same time ? or is it better to remove and replace half the floor at a time ?
The weather looks good today and its my day off so time to work on the Airstream
Toolmanbt is offline   Reply With Quote
Old 01-28-2018, 08:10 PM   #2
1977 31' Sovereign
Sunset Valley , Texas
Id say thats a case by case decision.
First thing, if you dont plan on moving the trailer mid resto is to level the trailer really well. Fore, mid and aft. Front to back and side to side. Secure that, then begin your adventure. Little blocks about 2-3 square are nice (same thickness as the subfloor you removed is) to put under the points when a vertical run lands on a piece of the frame. Temporary of course.
Lots ahead for you!
Iansk is offline   Reply With Quote
Old 01-28-2018, 09:48 PM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I replaced it in halves, back half first. Removed flooring from the middle to aft then replaced aft to middle. Front the same way, middle to forward the replaced front to rear. I unbolted the entire trailer from the shell and the shell would flex out enough to replace the new floor section in one piece.
Old 01-29-2018, 04:08 AM   #4
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I saved some small pieces of the old subfloor to use to clamp between shell and outriggers.
Just to keep things where I wanted them after the floor was out.
Dingo Girl is offline   Reply With Quote
Old 01-29-2018, 11:27 AM   #5
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
I started at the back and worked my way to the front, repairing the frame where needed, painting the frame, then replacing the floor as I went. I left small pieces of floor in place at the C-Channel to help secure the shell to the frame because I was working outside and wanted to make sure there wouldn't be damage from wind.
Iansk suggestion of making sure the floor is level is important! I had it supported front back and middle and made sure everything stayed straight and level as I worked
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 01-29-2018, 01:12 PM   #6
vanster's Avatar
1967 17' Caravel
Oakland , California
It's a good idea to make the corner pieces of the belly pan and install them before bolting down the new floor. Wrap the new aluminum around the C channel then install the new floor. Remember that AS built these from the bottom up then flipped them over to install the interior.
vanster is offline   Reply With Quote
Old 01-30-2018, 09:29 AM   #7
1976 25' Tradewind
1/2" blocks between the shell and frame
1/2" blocks between the shell and frame and clamp in place for stabilizing the shell while replacing the plywood floor. Thanks so much for the advice, Iansk, Dingo Girl and Davidson Overlander.
Also Aerowood thanks for the advice on the half floor at a time, at this point I have three of the five pieces of plywood out. So I will stop for now and work on what I have removed. Frame cleaning, POR, holding tanks location and new axles.
And to figure out how and the timing of reversing the lap siding. (skin on top of the belly pan ) Looks like Aerowood and Vanster have already done this on there Airstream. Any advice on this ?
So I have some work to get done, just time and money.
Old 01-30-2018, 10:33 AM   #8
1970 29' Ambassador
Santa Rosa , California
Hi BT, All,
This is great -- BT, thanks for posting the picture with the belly pan still on... I am following all of this with great interest as I am trying to tackle nearly the identical task. Thanks for all of the expertise that is shared here!
David
2002sheds is offline   Reply With Quote
Old 01-30-2018, 07:57 PM   #9
1976 25' Tradewind
The blocks between the body and the frame
The blocks between the body and the frame, thanks for the info.
Old 01-31-2018, 09:23 AM   #10
rowdyATX's Avatar
1956 26' Cruiser/Overlander
1961 28' Ambassador
Why the 1/2 gap??
rowdyATX is offline   Reply With Quote
Old 01-31-2018, 11:29 AM   #11
vanster's Avatar
1967 17' Caravel
We had taken the shell completely off and I media blasted the frame, repaired a few out riggers and then used POR to prevent more rust. I used marine plywood with 3 coats of epoxy and everywhere I cut a hole in the floor I went back and made sure the new cut was coated. The biggest problem we had was once the new tanks were in ( one fresh and one grey ) on either side of the axle, I had guessed on where to put the fillers holes and I forgot one. I bought ready made tanks from Ronco and they will spin weld anywhere you spec. Just make sure you know exactly how many and were. Adding a new outlet is tricky as us mortals cannot spin weld without taking the tank out. Another issue was that once we had the shell back on the gaps around the corners were really tight. It took hours and hours and hours and lots of tries to form the belly band corners ( per corner) . We did it at long last but plan ahead.
Old 01-31-2018, 07:17 PM   #12
1964 26' Overlander
Milton , ON
Originally Posted by rowdyATX View Post
Why the 1/2 gap??
The blocks are just taking the place of the floor plywood to keep everything together. It's not creating a gap, just filling the C-channel.
Grant Davidson
Milton, ON
1946 Spartan Manor
1964 Overlander
1974 Sovereign
TAC ON-5
Old 02-01-2018, 10:20 AM   #13
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
It should be a 5/8 or 3/4 space depending on heat of trailer.
Old 02-01-2018, 10:21 AM   #14
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Sorry heat should be floor thickness.
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 795 07-22-2018 10:28 AM
floor and belly replacement (shell off) cdmagda Repairing/Replacing Floor &/or Frame 10 11-13-2004 05:43 PM
Shell-on, frame repair/floor replacement all at once?? pinkflamingoes Repairing/Replacing Floor &/or Frame 12 09-13-2004 05:11 PM
Pictures of shell off floor replacement... williamhenshall Repairing/Replacing Floor &/or Frame 23 08-08-2002 05:05 AM
