Old 06-03-2004, 04:40 PM   #1
mbatm01's Avatar
1963 22' Safari
Broomfield , Colorado
Shell Off vs Shell On Summary
All,
I am the proud new owner of a 63 Safari, and have just joined this forum, and am amazed at how much knowledge there is out there. I have been going through all of the floor replacement forums and need to get a summary and a reality check from you.
My PO had completly stripped out everything, including the floor (just tore it out - some places under the U channel have wood, others are floating). So, very quickly I was able to tear out thier Psuedo Floor and get a look at the frame and the task of replacing the floor. The frame needs work - some welding at the old bathroom area, definately sand blasting and paint. I also need a new axle.
So with the existing conditions of frame repair, new axle, can I do a Shell ON floor replacement? I have a sloping drive way, and to take the shell off would require getting/renting a shop space.
Are these the correct steps for these potential methods?
Shell On:
1 - leave belly pan on, clean frame, weld were needed (possibly add stringers necesary to stagger floor joints - no 4 corner joints), POR-15 treatment
2 - remove inside wall sheeting to gain access to floor bolts, wiring etc.
3 - install new foor, piecing it together with staggered joints in the middle, bolt as needed around perimeter - can I get at the bolts in the middle without dropping the belly pan?
4 - Once floor is complete, take to shop to have new axle installed. Do they need to have the pan off to install the new axle?
Shell Off: rent shop space
1 - Remove Rub guard, and perimiter rivets
2 - Drop belly pan
3 - Remove inside wall sheeting
4 - Install cribbing and stringers to the exposed wall studs
5 - Raise shell, remove frame, tie down shell
6 - Repair frame, sandblast and paint.
7 - Install new axle
8 - Install new floor and insulation
9 - Reattach shell to new floor
10 - Reattach bellypan and outside skin.
I know this is very simplified, but with my logistics and other requirements, I am not sure if I have the processes in the right order, or whether or not I can do a Shell ON floor replacement.
Let me know what you think. Thanks in advance for taking the time to read this.
Kevin
mbatm01 is offline   Reply With Quote
Old 06-03-2004, 06:46 PM   #2
Images: 59
Shell on/shell off
Kevin,
You have the basics well in hand. I understand your sloped driveway problem.
The problem with a shell on floor replacement is not the floor bolts in the center of the floor. The problem is the bolts at the perimeter. The belly pan should be in two pieces, split down the centerine. The difficulty is reaching all the way from the center, where the pan is split, to the bolts on the perimeter.
If your trailer is assembled the same as my '59, the bellypan is under the body sheeting, and both are riveted to the U-channel at the floor.
On option is to cut out the center of the belly pan along the main frame rails, fold down the remaining bellyskin enough that you can reach up and put nuts on the floor bolts. The other option is to use self-tapping screws and work from the top.
With your situation, unless cost is not a constraint, I would forgo the shell off idea.
You do not need to remove the belly skin to replace the axle.
Good luck with your project. Everyone will be looking forward to a progress report. Welcome to the Airstreamforum.
Old 06-03-2004, 07:16 PM   #3
funchucky1's Avatar
Riverhead , New York
Hey, Kevin, welcome!
Come on, you KNOW you want to take your shell off .
It sure would be mice to have gotten away with a shell-on deal.
If you CAN go that route, try it.
Like Don said, you may have to open the bellypan along the frame rails so you can reach in around the edge.
But if the PO took the floor out, all the way to the walls, then he did much of the hard work for you, in my opinion.
Good for you ...
I'm doing the shell-off idea (believe me, it wasn't my original plan)...my shell is now off, sitting atop a few sawhorses. My frame, well, I took it to the welder today for the welding and sandblasting.
And I've been shopping around for satisfactory plywood. I've got the POR-15 ready. I need to buy some epoxy (tomorrow). This is when the cost is shooting up...
Welcome!
If I can add here...that if you DO go the shell-off route, and you can rent a shop...and you've got some time on your hands...you should be able to get away with a shop rental for a month or less.
I can't wait to see if I can actually get my shell back on!
Chuck
funchucky1 is offline   Reply With Quote
Old 06-03-2004, 09:15 PM   #4
mbatm01's Avatar
1963 22' Safari
Wow, you guys have some great ideas, and thanks for the quick replies. Chuck - no worries on getting my first airstream with this much work required, this is the learning experience I needed (according to my wife). From what I have seen on my first one, I think I would find a way to look at the frame no matter what, that rust and leaking is an evil thing, I am amazed at how much damage it did, and had this Safari had everything still in it I would be oblivious....
First - good to know that I can replace the axle without dropping the belly pan, which means I can get the floor done first.
Second - I went out and checked - my pan is made up of 3 strips - 2 along either side about two feet wide that curl up, and 1 down the middle about 4 feet wide. Thanks for that info Don. So now, I could remove the center strip of the belly pan - have enough access to reach bolts on the side and middle, and also do any frame repairs from the bottom.
With that said, I will drop the middle section of pan, begin repairs to the frame. Chuck where did you find a sandblaster and welder? and how expensive is it to sandblast the frame? So repair the frame, weld in stringers to allow me to offset the new joints, insulation, decking, and bolts.
Any ideas on how jack up enough to slide in the new sheets?
Kevin
Old 06-03-2004, 09:30 PM   #5
Images: 59
jacking up.
Kevin,
Jacking up is easy. Use a 1x4 or 2x4 across the width, about 4 inches above the floor. Put a couple of screws thru the ribs and into the 2x4. Jack it up with a bottle jack, or just lever it up with a crowbar. Place cribbing where needed.
Old 06-03-2004, 10:03 PM   #6
funchucky1's Avatar
Well, word of mouth or the Yellow Pages.....
Alot of it is labor.
Just brought the trailer there today....
Estimated:
1300 lbs Silica beads for blasting - $6/100 lb
$50/hr or so for labor.
I'm expecting about $500 total -
for sandblasting the whole thing, Cutting off a few things (like the old friction sway mount), Adding a strip for bolting down the center (my trailer doesn't have one at all), replacing the first and last crossmember entirely, repairing the doorstep (common break), repairing two crossmembers I nicked with the Sawzall , reinforcing the aft end of the framerails, repairing the coupler, blasting a few other pieces of rusty steel, taking out the few elevator bolts that I cut off but couldn't punch out.....
....and when I go to pick the trailer up, I'm going to ask the guy if I can slap my coat of POR-15 on in his shop.
He also said he has some extra POR-15 around that I can have.
Don's a good one to ask regarding floor repairs...his advice has helped me a ton!
-Chuck
Old 06-04-2004, 06:46 AM   #7
Images: 59
Kevin,
Re: sandblasting.
If you're willing to work at it, you can get a lot of the existing paint off with a wire wheel and paint thinner. The original frame paint is a very poor grade chassis paint that comes off pretty easily.
I only used 50# of grit to sandblast mine, in the corners where it was hard to get at with the wire wheel. Bought a sanblast gun at Northern for about $30. You need a big compressor if you DIY.
Old 06-04-2004, 07:11 AM   #8
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
How slopped?
The slop actually aided me in my removal. I removed the body becide my drive in the yard. I have a tall truck and adjusted the hitch so the coach was level . The back bumper was about to touch the lawn. I built a suport frame inside like Don showed. Pounded some 2x4's into the ground to suport the body. Lifted it off and screwed it to the suport stakes.
The slope alowed the frame more clearence in the front and I pulled it right out.
The Picture is deceiving but to put it into prespective on how sloped my yard its. The hitch on the front of that truck is about 34 inches. That truck is over 7ft tall. The back bumper was dragging the lawn.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 06-04-2004, 07:22 AM   #9
greg176's Avatar
Gabriola Island , British Columbia
If you want to do the work yourself on the frame you can do it under the trailer body.I made a new frame under mine, it made a good shelter.Check your yellow pages for sandblasting.Here in Vancouver there are several outfits that sanblast machinery and are reasonably priced.There is one outfit that rents a shelter ,set up with a heavy blaster,by the hour.
greg176 is offline   Reply With Quote
Old 06-04-2004, 07:41 AM   #10
Craftsman
Guest
Posts: n/a
Another option that you may want to consider is having your frame galvanized. The cost is very reasonable. When I built my Series111 Land Rover the frame, firewall or bulkhead, radiator grill and wheel rims were hot dipped galvanized. These are the only body parts that are made from steel. It cost me about $250.00 and it will pretty much last forever. You'll find places that galvianize in the yellow pages. By the way these were brand new parts that came with a primer coat and I didn't have to remove it first. The place that did the work pre-dipped them in a solution that stripped the paint and treated the steel before the galvanizing process.
Jack
Old 06-04-2004, 08:30 AM   #11
upallnight's Avatar
Kevin
Can you post any pictures of your project?
Leonard
Leonard
LotalaborAZ
upallnight is offline   Reply With Quote
Old 06-04-2004, 09:47 AM   #12
Craftsman
Guest
Posts: n/a
Land Rover photo's
Don't know if these are going to upload correctly, but I'll give it a try.
Jack
Couldn't upload to this post because the file was to large, but it should be in my photos section
Old 06-04-2004, 10:38 AM   #13
Craftsman
Guest
Posts: n/a
take alook in my photo gallery. you can see some of the Rover parts that I had galvanized
Jack
Old 06-04-2004, 12:41 PM   #14
1973 31' Sovereign
Portland , Oregon
Images: 22
Body on floor replacement.
mbatm01,
I suggest you check out my post of yesterday about replacing the floor without having to remove the body, belly wrap or bananna wrap. It could be just the technique you are looking for. The name of the post is:
Body and banana wrap on floor replacement technique.
Given the above technique you should be able to replace your floor without removing any of the bottom skins if you want to. Of course you may wish to remove some of them to be able to do a better job of working on your frame. If the steps or reasons for them are not clear in my posting please let me know and I can clarify.
By the way my driveway has a definite slope. It drops 9" per 8'. I have the back end of my 1973 31' trailer sitting about 36" above ground.
Malcolm
malconium is offline   Reply With Quote
HELP! Don't Make Me Pull The Shell Off! funchucky1 Repairing/Replacing Floor &/or Frame 32 04-25-2004 02:44 PM
Opinons wanted on truck shell or cover? Safari Tim Our Community 20 07-15-2003 04:46 AM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 10:21 AM
