Old 06-10-2004, 03:20 PM   #29
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Hmmmm - not sure - part of the purpose is to keep the frame from twisting - I would use steel - the only good reason I have is because it was done that way.
I really don't have a strong argument against the wood. I do know someone who used wood for his entire belly pan..............
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 06-10-2004, 03:29 PM   #30
upallnight's Avatar
Originally Posted by mbatm01
Okay - here is an update:
I removed all of the base interior panels using the Paint scraper method to cut them - worked like a charm! Thanks for that tidbit of info. Since the walls were not attached to anything after the PO removed the floor, they have a lot of play, and are slightly out from thier original position - Do I make the new deck end at the end of the outriggers? And then suck in the wall when I reattach them?
My banana wraps have a lot of small holes in them, that I could patch. But what about this idea - I am thinking of taking the shell off - but instead of taking out all of the rivets and sliding the banana wraps off, what if I cut the banana wraps leaving 3" of the original sheet still riveted to the side to be used as a strip/fishplate to attach new banana wraps to?
So, I would cut the wraps down, pull back the remaining, lift the shell and pull out the frame. What do you think?
Leonard - your photos are great. What was the sequence? You show the jack in place and then the new floor in place - did you do one side at a time moving the jack over between pieces? Also, how did you clean and paint your frame, wire wheel and primer or POR-15?
Kevin
I put the jack far enough to one side to allow one sheet to be laid next to it. Then I bolted down that sheet and moved the jack on top of the sheet just laid and repeated the process on the side just vacated by the jack, so on and so on forward. I have one sheet left to install tonight, I'll take some pictures and post them when I'm done. I cleaned the frame with a wire brush on a 9" angle grinder, then used a hand brush on what I couldn't reach. I then used spray on auto primer to coat the frame. Krylon has a primer that has great track record and rust inhibitors.
Leonard
LotalaborAZ
upallnight is offline   Reply With Quote
Old 06-10-2004, 03:38 PM   #31
upallnight's Avatar
Ken
I am not an engineer "but". I think the frame and floor work together as an integral part of the monoque (not sure of spelling) design. When I replaced the crossmember on my frame it was a simple matter to weld it in. The crossmember's are welded on the bottom side so the weld doesn't stick up into the flooring material. I welded mine top and bottom, I believe in overkill. And I would hold it up against any wood or plastic made.
Leonard
LotalaborAZ
Old 06-10-2004, 03:46 PM   #32
1973 31' Sovereign
Portland , Oregon
Images: 22
What size, etc.?
What did you use for your cross memebers? Were you able to find metal with the holes punched out or did you just use channel? What size and guage of metal? Was it readily available or did you have to have it made up?
Malcolm
malconium is offline   Reply With Quote
Old 06-10-2004, 03:50 PM   #33
1973 31' Sovereign
Portland , Oregon
Images: 22
60.5" wide aluminum?
I think I asked this somewhere in the forums before but don't remember getting a reply...
Has anyone found a source for 60.5" wide belly pan aluminum? I understand that the aluminum can be a relatively low grade for belly pan use but where to get such wide stuff? Lowes and Home Depot go up to 20" or 24" wide.
Malcolm
Old 06-10-2004, 03:51 PM   #34
Ken J's Avatar
Durango , Colorado
Images: 14
FYI - on my 58, those cross members are solid, whereas on my 75 they do have the holes in them and are thinner material. You could use C channel and have the welder cut some holes in it.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 06-10-2004, 04:12 PM   #35
1973 31' Sovereign
Portland , Oregon
Images: 22
Great photos indeed...
Leonard,
I just found your photos of your floor progress and they do answer some of my questions about your new cross members. It looks like you cut out the center of the channel. Am I interpreting the phot correctly?
It also appears that you did all your repair work without entirely removing the body from the frame. Is that correct? Are you then just using the jack to open up enough space to slide the plywood into place?
What type of plywood did you end up using for your floor? Did you coat it?
Malcolm
Old 06-10-2004, 10:24 PM   #36
upallnight's Avatar
Originally Posted by malconium
Leonard,
Malcolm
Yes I did cut the center out. There was enough of the old crossmember left to use for a pattern when I cut it out. The material was standard 4"X1/4" channel iron, Alot heavier than what A/S used but all I could find at local mom&pop iron supply. I didn't remove anything but the belly pan, put the last sheet in tonight. I forgot to take my camera so no pics yet. I place the jack under a shell rib then place a long piece of plywood on top of jack stud then raise shell to where plenty of room exist for floor to be slipped under wall channel. I used CDX treated with Thompsons water seal. You might want to countersink the elevator bolts with a forstner bit. Pictures to follow tomorrow.
Leonard
LotalaborAZ
Old 06-11-2004, 09:03 AM   #37
mbatm01's Avatar
1963 22' Safari
Broomfield , Colorado
Leonard,
That clears it up for me. Sounds like we have a lot of the same issues - were your sides bowed out a little at the baseplate? If so, did you just run the new floor to the edge of the frame stringers and pull in the walls before bolting? What did you do around the wheel wells -did those have to be disconnected from the shell?
Kevin
mbatm01 is offline   Reply With Quote
Old 06-11-2004, 09:05 AM   #38
mbatm01's Avatar
1963 22' Safari
Leonard,
Sorry, one more question, how did you end up insulating your floor?
Kevin
Old 06-11-2004, 09:21 AM   #39
upallnight's Avatar
Smile
Leonard,
Kevin
After welding in the center strips I snapped a chalk line down the middle by measuring to the center from the outside of the frame in the back and the front. markdoane (Don) gave me the original measurement of his floor which was 88" wide. When I cut the wood for the floor I cut it 44" wide and left it full length, I then laid the sheets on the chalk line assuring they were centered in the coach. Yes the walls had sagged out a little and will have to be pulled in before attaching to the floor. The way I replaced the floor you can't attach the wall channel to the floor until you have all the floor in and bolted down because you have to raise the shell to get the floor in. I am really sorry about getting behind with the pictures, I'll try to make up for it tonight. I didn't do anything to the wheel wells other than to make sure they were back in the same position when I laid the new sheets around them. You can see the old bolt line from underneath when you are drilling the holes. I will be securing the shell to the floor tonight, and I won,t forget my camera. Now that the floor is in I can start to see a little light at the end of the tunnel.
Leonard
LotalaborAZ
Old 06-11-2004, 09:26 AM   #40
upallnight's Avatar
Leonard,
Kevin
I haven't decided on what type of insulation I'm going to use yet, all I know is that I didn't lay it on the frame like A/S did. There were some serious rust issues I had to deal with and I think it was directly related to the insulation being compressed between the frame and the floor. When it gets wet I don't think it would dry out in a month of perverbial (spelling ?) Sundays.
Leonard
LotalaborAZ
Old 06-11-2004, 12:36 PM   #41
1973 31' Sovereign
Portland , Oregon
Images: 22
Question Caution about Thompsons Water Seal?
Leonard,
I had thought about using Thompsons Water Seal so I explored their website to see what they said about toxicity for interior use. There was nothing that I could find mentioned on the site so I emailed them a question about it. They replied that they did not recommend it for interior uses since it contained some chemicals that were a bit toxic for interior purposes. It seems to me that treating the sub-floor with something toxic would not really matter that much as long as the material was fully isolated from the inside. I remember doing some remodeling once on a bathroom (house not an airstream) where I had to replace much of the floor. At that time I was told to treat the wood around the rotted areas with some pretty nasty stuff for which I had to wear a chemical mask. Of course the crawl space of the house was ventilated.
What are you going to be covering your plywood with on the inside of your trailer? Are you intending to ventilate your under floor area? Do you think this is an issue for concern? I like the idea of using Thompsons for treating wood because it seems to be a fine product for the purpose.
Malcolm
Old 06-11-2004, 12:40 PM   #42
1973 31' Sovereign
Portland , Oregon
Images: 22
Leonard,
I posted a question about Thompsons Water Seal but it seems to be in a part of this thread where I was not intending for it to go. Did you find it anyway?
Malcolm
HELP! Don't Make Me Pull The Shell Off! funchucky1 Repairing/Replacing Floor &/or Frame 32 04-25-2004 02:44 PM
Opinons wanted on truck shell or cover? Safari Tim Our Community 20 07-15-2003 04:46 AM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 10:21 AM
