Old 04-25-2009, 11:19 AM   #43
truckasaurus's Avatar
Profile:  1961 26' Overlander
Airdrie , Alberta
Images: 24
Plywood sealant question. Has anyone tried POR15 on plywood at all? Under my tanks I'll have 3/4" plywood and I was going to use West Epoxy but maybe POR15 would be good too, thoughts?
preparing for the maiden voyage in 2010...
truckasaurus is offline   Reply With Quote
Old 04-25-2009, 11:45 AM   #44
pbearsailor's Avatar
Profile:  1957 22' Caravanner
Blaine , Washington
I've been using West System on the boat for years and years. Definitely going to use it on the new subfloor on mine. One of the penetrating epoxies might be even better, but I'm so used to West that it'll be my choice.
pbearsailor is offline   Reply With Quote
Old 04-25-2009, 12:47 PM   #45
Profile:  1963 26' Overlander
Can't comment on POR over wood, not sure how that would turn out. I think it actually uses the metal in its bonding process, but I'm no chemist.
I'd stick with the epoxy. West System works well on boats, should be plenty good for a ravel trailer. And I believe it was Uwe who said there are other less expensive options than West System, and that his research showed they were pretty much the same manufacturer, just different labels go on them. I think the outfit he uses is out of Florida. You might try searching for his comments, or just PM him, he's always very helpful.
Old 04-25-2009, 01:37 PM   #46
Airdrie , Alberta
Images: 24
Thanks Marcus I'll get searching. I might even tint the epoxy greyish.
Old 04-25-2009, 02:42 PM   #47
Airdrie , Alberta
Images: 24
Change of plan, whilst reading Uwe's excellent posts I noticed his 30" metal brake and found one on sale $55 so I bought it and pick it up later in the week. So with a 1/2 sheet of utility grade Aluminum at $28 I can nix the $229 channel quoted last week of the list, make my own and get to keep a "free" tool.
Old 04-27-2009, 11:36 PM   #48
Airdrie , Alberta
Images: 24
Very, very nearly finished with the welding
Minimal snow today allowed us to nearly finish up.
The tank frames are all in. One end is removable on each cavity, we attached a bracket inside and tapped it to accept the bolts you see. (must remember to add goop so they don't seize up in a few years).
Added angle iron under the propane mount in case I want to wiggle it around and re-position it sometime. Filled all the P/O holes for plumbing etc.
All that's left is to buy a leveling jack so I can see the best way to alter the chassis to accept them after the belly is on. Then some clean up and sandblasting.
ID:	79367   Click image for larger version
ID:	79369   Click image for larger version
Old 04-28-2009, 08:13 AM   #49
Profile:  1974 31' Sovereign
beautiful downtown Aurora , Ontario
Send a message via ICQ to Aage
Wow, that's looking great, Truck! You are making it better than new. I don't recall what battery storage you had, do you plan to make space for extra batteries as you re-assemble?
The road to a friend's house is never long. (Old Danish Saying)
Old 04-28-2009, 05:25 PM   #50
Airdrie , Alberta
Images: 24
Aage, thanks, I'm thoroughly enjoying the frame set up work. No fixed plan for the battery location yet, given their weight they are lore than likely going to end up inside just under the front window or very close to the axles. Vented through the floor if needed.
Having double checked the Airstream Bal jacks (online only) no strengthening of the chassis appears to be needed so that means all the welding is complete.
No progress shots today, I cut down trees instead, much less fun.
Old 04-29-2009, 03:56 PM   #51
Airdrie , Alberta
Images: 24
I tried to buy the POR15 today but with no luck. Of the two stores I tried neither had enough; even at $64 a quart, gulp!
I did chat to the sandblaster and it looks like about $300 to sandblast and a further $200 to $300 to spray it up with their primers and paint. It seems tempting. The best stuff they have is called Endura. They primarily work on oil rigs so I imagine it's a reasonable product.
I'm sure POR15 is better but with me painting it on outside with a brush versus a pro spraying in a heated shop maybe it evens out a little. Plus it's cheaper and I won't be inhaling anything. What's the forums opinion?
I picked up 100 1/4" x 2' elevator bolts and about 50 self tapping floorboard screws along with washers and stuff.
I could only get Vulkem 116 locally (Western Canada) so I bought that and butyl tape. If I need to step up to 636 It's a 30 tube case as minimum order.
Old 04-29-2009, 05:25 PM   #52
Airdrie , Alberta
Images: 24
For some reason I thought the rivet gun would be small like the air drill but it's not. In fact it's a pretty hefty lump of metal. (Aircraft Spruce stuff arrived today). Just under two weeks to Canada by post is great especially with no bogus UPS brokerage charges.
Old 04-29-2009, 05:38 PM   #53
Awesome, I really love riveting, there's something very solid and satisfying about it.
Your progress is looking good, keep up the great work.
Old 04-29-2009, 05:43 PM   #54
Do you have any Fastenal stores near you? I know they have a decent presence in Canada, but not sure about your area. They should carry, or at least be able to order, the 636 for you, if you have one nearby.
Can't help on the POR-15, I ordered mine from VTS, but I know that shipping into Canada can be problematic. As far as the oil rig painters, I'd say if their stuff can hold up directly to those conditions, then it should hold up at least as well as POR-15.
Old 04-29-2009, 06:33 PM   #55
Airdrie , Alberta
Images: 24
Thanks for the Fastenal tip, I'll check them out.
Shipping across the border is often tricky and stupidly expensive, I'm currently hunting a local source for the BAL stabilizers ($270 shipping seems crazy ( from Outofdoorsmart)). I think the trick is to only buy North American made products so there's no import duty and avoid UPS like the plague. The postal service seems great so far. Worst case I'll be in Seattle in July and California in September so I'll see what I can pick up then.
Not having an Airstream dealer in the province, which is huge, seems to make this project extra hard.
Old 04-29-2009, 07:26 PM   #56
Jim & Susan's Avatar
Profile:  1973 27' Overlander
McDonough , Georgia
Truck, I bought my POR-15 from a local automotive paint store for about US$35 per quart. I'm pretty sure that you can get it from Vintagtrailersupply.com for a pretty good price. Same with the Vulkem. I bought some Vulkem from them for about US$7 per tube (buy plenty). I sandblasted my frame myself by renting a sandblaster and buying the sand locally. Seems like that cost about $200 total. I'll try to look it up. You might do best to have the POR and Vulkem deleverd to a US address and pick it up when you're down here. Just a couple of other ideas.
Keep up the good work. Following along with interest.
Can somebody remind Susan that I really do want bagpipes for Christmas?
www.nesa.org
Air No. 6427
Jim & Susan is online now   Reply With Quote
factory new shell? finalcutjoe 2007 Classic (all lengths) 17 05-16-2007 02:21 PM
How big a shell off has been done? tbrom Repairing/Replacing Floor &/or Frame 1 10-12-2006 10:45 AM
Shell on or off??? Bradjun1 Repairing/Replacing Floor &/or Frame 3 09-20-2006 12:19 AM
Shell Off vs Shell On Summary mbatm01 Repairing/Replacing Floor &/or Frame 82 01-09-2006 06:46 PM
Replacing the shell ?? William8979 Repairing/Replacing Floor &/or Frame 2 05-11-2005 09:22 AM
